Alok
Joined: 19 Mar 2005 Posts: 291 City/Region: League City
State or Province: TX
Photos: Top Cat
Posted: Sat May 24, 2008 12:12 am Post subject: |
Doryman wrote: | Alok wrote: | Twin counter-rotating Suzuki 150s.
Top speed 45 mph with full gas, water, and bottom paint.
After adding a bimini, Permatrims, and the usual stuff that collects on a boat, top speed is 43 mph. |
How are you propped, and what RPM are you running at WOT? Do you have a weight figure for your boat in the water?
Warren |
Warren: My boat is set up the same way as Dr. Bob's (see his info above). I do not have a weight for the boat. _________________ Alok
C-Dory Tomcat (Topcat) sold January 2012 |
Wefings Dealer
Photos: Cruise Ship #4
Posted: Sat May 24, 2008 8:52 am Post subject: |
3X16"X21.5" Genuine Suzuki Props for Bob and Alok and Matt. Port motor on Stbd side and Stbd motor on Port Side.
Marc _________________ Wefings Marine Website
Since 1909 |
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
Posted: Sun May 25, 2008 10:53 am Post subject: |
Wefings wrote: | Port motor on Stbd side and Stbd motor on Port Side.
Marc |
Please explain the benefit of this.
M/V Lori Ann
Anacortes, WA
Doryman
Photos: Lori Ann
Posted: Sun May 25, 2008 11:05 am Post subject: |
Maybe I am propped OK after all. On the way to Cap Sante I opened her up to WOT and trimmed as best I could. Reached 5700 RPM (did not get that high when trimmed incorrectly before) and 39 MPH. The RPM published range is 5000-6000. Does the fact that I get to 5700 RPM mean I am propped correctly or are there other measurements I should be taking?
Warren |
Dora~Jean
Joined: 09 Mar 2004 Posts: 1506 City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
Posted: Sun May 25, 2008 11:38 am Post subject: |
I don't know if cats are different, but mechanics say you want to be on the high side of the range, gives some range for higher loads and higher altitudes if needed. Sounds perfect! _________________ Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
+4 Previous, 1/2 sail, 1/2 power |
Wefings Dealer
Posted: Mon May 26, 2008 8:57 am Post subject: |
To answer the "backwards turning" prop question , We have found with planing type catamarans that there is a slight gain in speed [probably related to "bite" in cleaner water,or lack of slip] and no steering downside as you would have with closely spaced props on a monohull . Not exactly sure why , but we have done it this way for years on our Tomcats and Twin Vees and Sea Cats , and it works ! Dont know if it would make a difference on a pure displacement Cat like a G.B.
5700 is quite acceptable [ for a 4 stroke Yamaha] RPM with a load in the boat . The pitch Vs. Diameter you have is good . What you can gain by changing blade shapes is the ability to trim the bow higher . That is important on Cats . I usually suggest folks to trim up [ at speed] till the motors cavitate , and then back it down till they bite again and note those positions if you have trim gauges or "time it" if you dont . You need to drive by feel . Dont be afraid of the trim buttons ,they are your friend.............
Marc |
Discovery
Joined: 08 Dec 2003 Posts: 1240 City/Region: LOA, UTAH
Vessel Name: Discovery
Photos: Discovery
Posted: Tue May 27, 2008 9:04 am Post subject: |
Marc
Just be sure you know how your boat is equipt . I launched at Punta Gorda, after putting on the props. I had removed them to trailer cross country- too easy to have stolen. I put the boat in reverse to back off the trailer, and nothing but frothing the water. After a couple of trips up and down the ramp to look at the props. I finally realized that the right turning motor was on the port side and the counter turning motor was on the stbd. side. I removed the props and reversed the placement, and all was well again. I had always removed the props to trailer on our TC 24- mostly in Mexico- and that boat had the CC motor on the port side. _________________
Brent and Dixie,
1984 22' Classic sold 2003
2003 24' TomCat sold 2005
2006 CD 22' Angler Sold 2014
"Free men do not ask permission to bear arms." ~ Thomas Jefferson |
Wefings Dealer
Posted: Tue May 27, 2008 9:40 am Post subject: |
Brent , you oughta try it with 2 righthanded props , I had the pleasure of trying to get one off the trailer that way once . Its pretty twisty and torquey...........
Marc |
matt_unique
Vessel Name: Napoleon
Photos: Napoleon
Posted: Sat Jun 07, 2008 10:34 pm Post subject: More trim today |
Today the water was calm and I decided to experiment with trim a bit more. I brought the engines up until cavitation then back a pinch with WOT. I was able to get 6000rpm on the port engine and 5700 on the starboard engine, max speed 40.5 knots or 46.64 mph on the GPS. My boat lists to starboard right now (I assume from water tank) and I suspect if I trimmed the starboard engine up a bit more to compensate I would get a little more rpm.
I'm curious what others are reading for an exact max speed on the GPS? Bob I don't know how you are "well over" 40 knots! Your engines must be supercharged!
It was warm and humid today so perhaps in crisp fall air I might get a bit more. The top end is not particularly important to me but I want to make sure I'm in the right ballpark with other Tomcat owners. I'm very pleased to be running just under 47mph on a 28' (stem to stern) boat! _________________ Captain Matt
Former owner of Napoleon (Tomcat) Hull #65 w/Counter Rotating Suzuki 150's. |
Wefings Dealer
Posted: Sat Jun 07, 2008 10:48 pm Post subject: |
You are indeed at Fenway as far as the RPMs go.
Your transducer could be affecting the RPMs between the motors as well if its close to the middle of the sponson .
Marc |
Doryman
Photos: Lori Ann
Posted: Sun Jun 08, 2008 1:12 am Post subject: |
My last run, trimmed but not to perfection, through a very slight chop, was 39 mph at 5700 rpm WOT. Wonder if salt water is slower than fresh?
Warren |
matt_unique
Photos: Napoleon
Posted: Sun Jun 08, 2008 7:39 am Post subject: WOT |
My transducer is an in-hull (shoot thru hull). Also my boat only sees salt water unless she is being rinsed!
I have bottom paint of course. I'm trying to remember now if Bob has bottom paint since Thataway is kept on a lift? If no, that would definitely explain a few knots at top end.
Warren, what are the specs on the Yam 150's? You're running those with peratrims if I interpret your pictures correctly. What are your props? I know the Suzuki 150 has the largest engine block for all 4-stroke 150's right now. I'm sure as with all technology this will change in 10 minutes but I wonder if that difference is enough to cause a 7 knot difference between our vessels? It could be several things though....props, amount and possibly type of bottom paint (my paint is hard, perhaps ablative paint would be slower through the water), gear aboard, etc.
As an aside, I learned what just a little slime can do to a boat. My former boat developed a bit of slime, not much at all, and my rpm was down about 1000rpm and the top speed to match. I thought for sure it had to be an engine problem. I had the engine checked out...compression...the whole 9 yards. No problems were found and nothing was done. I power washed the vessel and my rpm's and top speed returned. It was a significant change in performance, way more than you would think with just a little slime on the hull. I'm sure sail boat racers already knew what I had to learn but it was an eye opener. |
Tom Little
Joined: 20 Jan 2007 Posts: 51 City/Region: Punta Gorda
Vessel Name: TomCat
Photos: TomCat
Posted: Sun Jun 08, 2008 8:01 am Post subject: |
On sea trials on our month old TomCat, the Evinrude Etec 150s had 3X15 1/2X15 counterotating props. We hit 46 mph with a relatively light boat. After filling the tanks, installing air conditioning, and all the other stuff for cruising, the max speed dropped of to 38 mph with the max rpm at 6200. Friday, the dealer installed 3X15 1/2X17 inch props. Now the top speed is 43 mph at 5500 rpm. This is for a relatively heavy boat in a two foot chop. These engines max out on torque at 5300 rpm so this must be the right prop for this boat at this time. _________________ Tom Little
2008 TomCat 255
Evinrude 150 E-Tec
Punta Gorda FL |
Wefings Dealer
Posted: Sun Jun 08, 2008 8:39 am Post subject: |
We did one with Suzuki 175s , and the owner tweaked the heights and brackets and is a 50 MPH plus Tomcat .He is a performance type of guy . Matt,the paint is probably the difference for you . In terms of top speed , Honda will be the slowest ,surpassed [and passed] by Yamaha and E tec , and Suzuki will be the fastest . All good motors , different characteristics .
Marc |
Doryman
Photos: Lori Ann
Posted: Sun Jun 08, 2008 1:57 pm Post subject: |
Wefings wrote: | In terms of top speed, Honda will be the slowest, surpassed [and passed] by Yamaha and E tec, and Suzuki will be the fastest. All good motors, different characteristics. |
Interesting. Can you tell us more about your opinion of the different characteristics of each in the 150 hp model?
Warren |
