Cleaning gas tanks?
PostPosted: Sun Apr 29, 2007 1:30 pm    Post subject: Reply with quote
SEA3PO wrote:
I moved my filters to the sides of the tanks...so they would be easy to see and service.... the stock location above the tanks is miserable to get to.
Joel
SEA3PO
I like the filters mounted up in the engine well and at the back so you can always see them and draining the clear bowls at the bottom of the filters can be done either from inside the boat or when standing on the ground outside. Also, accidental spillage will run out through the engine well drain holes rather than all over the cockpit floor, which is safer in terms of fire danger.
My mechanic/technician installed my Racor there when I bought the new engine in '05. Good choice!
Joe.
Unidentified photo from "Fuel Systems Detail Photos"
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Sun Apr 29, 2007 8:36 pm    Post subject: Reply with quote
This thread weighed heavily on me mind when, as we were pulling out of the slip, the motor stalled. I had just switched to the starboard tank, too.
Sorta. Actually, I turned the fuel off Smile Hondas run fine so long as the fuel is turned on!
Mike
Wayne McCown
City/Region: Rochester
State or Province: NY
Vessel Name: Little Mac
Photos: Little Mac
PostPosted: Mon Apr 30, 2007 10:55 am    Post subject: Reply with quote
I had to clean my tanks last summer. It was an easy job. The only hard part was that the gas in the tanks made them heavy to lift out of the boat. (I should have pumped it out first!)
While at it...I took apart the gas lines and blew air through them. I was advised to replace the pressure bulb (which I did), and I also installed a new RACOR filter. I used the stainless steel screw-down clamps (which are easy to install) at the end of each line.
All of this, including an hour run to the store, took about a half-day.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Mon Apr 30, 2007 12:38 pm    Post subject: Reply with quote
Which RACOR fuel filter models is everyone using?
Brent Barrett
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Mon Apr 30, 2007 1:50 pm    Post subject: Reply with quote
While the tanks are out, I cut some viewing slots in the tank cover plates. Now I can see the fuel levels in each tank.
I won't be able to re-install the tanks until May 12. My son and I are taking the motorhome up to dive for jade at Jade Cove north of San Simeon this weekend with the dive club.
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
Wayne McCown
Photos: Little Mac
PostPosted: Mon Apr 30, 2007 1:52 pm    Post subject: Reply with quote
I wish I had marked the tanks at the following levels (as I refilled them from EMPTY): 5, 10, 15 gal.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Mon Apr 30, 2007 3:55 pm    Post subject: Reply with quote
I removed the gray 18 gal tanks & replaced them with the see through 25gal tanks that the new 22's come with. Drain the racor when you see water / stuff & change the element every 100hrs & it will be all good Mr. Green Beer
Anyone interested in 18g tanks W/new senders?
tsturm
Photos: JMR-TOO
PostPosted: Mon Apr 30, 2007 4:01 pm    Post subject: Reply with quote
I use the tall S3227 Element. Your favorite marine dealer will have a kit with Base, Element & Bowl Mine is in the splashwell above the tank selector also Mr. Green
PostPosted: Mon Apr 30, 2007 10:24 pm    Post subject: Reply with quote
There is a process called "fuel polishing"--mostly applied to diesel. Basically the fuel in the tanks is recirculated thru filters with a pump.
Yes, Startron--(Soltron) has been used. It does definately seem to work in diesel fuel. I have also tried it in gas, and it seems to work there--but I don't have the dramatic proof I had in diesel. A friend's boat had gelled diesel (he forgot about one intragral tank and the fuel had been in the tank for 30 years--the tank was "found" when he repowered recently. They could not pump the fuel out--so Soltron (Startron) was added to the tank--the boat sailed across the Atlantic and the diesel was then liquid enough to be easily pumped out--the tank was clean, after that fuel was removed and fresh diesel (with Startron added) pumped thru it. The boat had been almost continously sailing all of these 30 years--and covered about 150,000 miles during this time, including several circumnavigations)
I had some "missing" with my 18 footer, which had unknown history with the tank--and the Soltron resolved the problem. (Plugs and injectors were OK). So, I do use it.
One of the problems we will be seeing is with the addition of ethanol, there will be gunk loosened and cause plugging of the filters. I would try the Soltron, and pumping out the tanks. If the fuel is real old--get rid of it. I used to physically clean out my diesel tanks (man holes)--I have never done this with gas tanks--mainly because I don't have man holes in gas tanks...
Page generation time: 0.0377s (PHP: 60% - SQL: 40%) - SQL queries: 26 - GZIP disabled - Debug on
