Surge brake frustrations backing uphill
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Fri May 23, 2008 7:24 pm    Post subject: Reply with quote
Something else you could do is to wire in a toggle switch on your dash that provides power directly from a switched power source to your wire on the trailer plug. This way you can be on level ground, activate the switch then pull up to your driveway and back in. You just have to make sure to ALWAYS turn the switch off when not in use as it will disable your brakes.
I would wire this in parallel to the normal backup lights. IE: When you flip the switch it will turn on the back up lights too.
Gary Johnson
KB7NFG
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Sun May 25, 2008 3:03 am    Post subject: Reply with quote
I fixed my surge brake problem last week. When checking the master cylinder after the winter I found it full of rusty water. So I took the brake line loose, unbolted the surge hitch assembly and threw it in the garbage. Replaced it with a standard 2" hitch assembly....no more brake problems.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sun May 25, 2008 10:23 am    Post subject: Reply with quote
So -- no brakes now?
Doryman
M/V Lori Ann
Anacortes, WA
Jack in Alaska
PostPosted: Sun May 25, 2008 5:16 pm    Post subject: Reply with quote
Warren,
Yes no brakes now. In 1983 I towed it to Alaska (2500 miles)on the original trailer which did not have brakes, towed it for 24 yrs. w/o brakes and bought the new trailer with brakes that failed after the 2nd salt water dunking. Back to no brakes.
I only tow it now from my house to the launch and back,
approx. 1/4 mile, with a 1 ton dually, so there is no problem in my opinion . If I towed it on the freeways at 65 mph and in big city traffic I would need brakes for sure. I did not want you to think I was being flippant about that subject.
I am just glad it is finally boating time in Alaska and I can splash my boat again.
Page generation time: 0.0316s (PHP: 59% - SQL: 41%) - SQL queries: 17 - GZIP disabled - Debug on
