Hull runners?
SENSEI
City/Region: Stanwood
Vessel Name: SENSEI
Photos: SENSEI and SERENITY
PostPosted: Sun Jul 25, 2004 2:26 pm    Post subject: Reply with quote
I have a 1983 flat bottomed clasic and I decided to gouge out a well for a bilge pump. I can verify that it was plywood. it was a real job to clean it all out and glass over it. I also had a thru hull toilet that I took out and filled in the holes. it was plywood there also.
Roger on the "SENSEI"
1993 22 Cruiser (sold 2014)
1983 22 Classic (sold 2017)
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Sun Jul 25, 2004 4:10 pm    Post subject: Reply with quote
SENSEI wrote:
I can verify that it was plywood..
Dang - wrong again. That's twice this year.... Shocked
Tux Will, C-Brat Nerd Tux
danbeaudoin
C-Dory Model: 19 Angler
PostPosted: Sun Jul 25, 2004 11:21 pm    Post subject: Reply with quote
Do you think applying the 5200 or epoxy directly to the wood and pressing (blocking) it to the hull without using any screws would last any length of time? She rests in mud at low tide and I only have her in for a couple of months a year.
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Mon Jul 26, 2004 12:38 am    Post subject: Reply with quote
Hi,
I think that either would bond if prepped properly. The natural teak oil must be washed off of the bonding area with acetone. 5200 takes a long time to completely cure, but epoxy is much faster. You need to locate the strips so they don't move during cure. They want to slide around. One small screw at each end should locate the strips.
If properly done, the epoxy will outlast the wood. Are you using bottom paint?
Larry H
A C-Brat since Nov 1, 2003
danbeaudoin
PostPosted: Mon Jul 26, 2004 9:18 am    Post subject: Reply with quote
Yes there is bottom paint. Naturally I will scrape this off first.
Thankyou,
Dan
Redƒox
Guest
PostPosted: Tue Jul 27, 2004 12:46 am    Post subject: Reply with quote
Hey were back! Had a great little weekend, I coulda stayed longer in the camper on the shores of Resurrection Bay, (falling asleep to the waves lapping the beach---ahh:) but had to get home. I see you got some excellent advice here.
Well, not just the bottom, but also the deck around the cabin had a plywood core! I know the transom is balsa though, (I had to replace my hull drains a few years ago) no biggy to me either way, both were good as new! I have to assume the "runners" are also some kind of wood-cored material. I like the way there glassed into the hull on the 85 model.
PS: I like the new C-B logo!!
Thumbs Up
Page generation time: 0.0427s (PHP: 44% - SQL: 56%) - SQL queries: 22 - GZIP disabled - Debug on
