Tomcat fuel capacity vs. gauge readings
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Mon Apr 25, 2011 10:17 pm    Post subject: Reply with quote
http://www.ssitechnologies.com/FUEL_LEVEL_MEASUREMENT.html
Anyone using an ultrasonic sensor?
Brent Barrett
billtwymank
City/Region: Pinehurst - New Bern, NC
Vessel Name: Lady KC
Photos: Lady KC
PostPosted: Tue May 03, 2011 4:13 pm    Post subject: TomCat Fuel Sensor & Guages Reply with quote
I have looked at these SSI Technology Ultra Sonic Sensors.
QUESTION............
Before I head back to Lady KC,
I was wondering if anyone call tell me
where to find each of the two existing in the fuel tank sensors
and is it easy to remove their covers screws/bolts,
and then physically be able to remove the sensor assembly completely out of both the port and starboard fuel tanks.
What tools would be required to remove these fuel tank sensors.
Does anyone know if the existing in tank sensors are the 33-240 ohm type of resistive float arm.
Begining to wonder about the return on investment........lol
Bill & Karan
Lady KC
PostPosted: Tue May 03, 2011 5:19 pm    Post subject: Reply with quote
Can't answer the other stuff but in or around the cockpit step (at the forward end of the cockpit (port and stbd) you should find one or more round access ports, they screw out. Get a flashlight, screw them out and you should see the fuel hose connections and the level sensor attachments. My gauges are extremely inaccurate, I don't use them. Different model years have different access holes/locations.
Tom Little
City/Region: Punta Gorda
Vessel Name: TomCat
Photos: TomCat
PostPosted: Wed May 04, 2011 4:08 pm    Post subject: Reply with quote
The top of the tank connections on our TomCat are at the rear of the tanks nearest the stern. Access to this area is through the screwed in side storage areas. Once removed, the rear of the fuel tank is visible.
That is why the gauge reads empty at rest and 1/4 underway.
Tom Little
2008 TomCat 255
Evinrude 150 E-Tec
Punta Gorda FL
PostPosted: Wed May 04, 2011 7:23 pm    Post subject: Reply with quote
This is what happens when you have a bunch of companies building the same model of boat!
c-ness
City/Region: Bellingham
C-Dory Model: 24 Tomcat
Vessel Name: C-weetness
Photos: C-weetness
PostPosted: Thu May 05, 2011 10:56 am    Post subject: Reply with quote
On the TC24 the access hatch is under the cockpit step. When opened the sensor units are immediately visible. Had to replace one this spring. I learned that you don't want to do this with a full tank of gas.
1990 Grand Banks 32 2012-
2002 Tomcat 24 2010-2012
Page generation time: 0.0345s (PHP: 53% - SQL: 47%) - SQL queries: 19 - GZIP disabled - Debug on
