Running Wallas Underway?
akjack
City/Region: fairbanks
Vessel Name: OBJOYFUL
PostPosted: Tue Feb 26, 2008 7:55 pm    Post subject: Reply with quote
I have run my wallas heater while tied up to a dock, while anchored out and while underway. When underway I have run it at speeds from 7 knots to 21 knots for hours at a time and have never smelled any fumes or noticed anything but wonderful heat. It is possible that I have never had wind from a direction that would impede the exhaust flow. I start up and shutdown in the hi position. Never had any problems.
Jack
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Tue Feb 26, 2008 8:05 pm    Post subject: Re: wallas underway Reply with quote
dogon dory wrote:
terraplane wrote:
...One thing: I have always started the stove with the lid up, and the setting on the highest, 6. I also have been shutting it down with the setting at the highest level. I believe the new manual on line with C Dory says to shut it down at lowest setting..
Any advice on that?
terraplane
Adjusting the setting on the Wallas does two things. It changes the speed of the pump and proportionally the speed of the combusion air fan. The idea is to optimize the fuel air ratio for clean, efficient combustion. This is "tuned" at the factory by tweaking the control circuitry.
When the stove is turned off, the fuel pump stops but the combustion fan continues to run in order to finish burning off the remaining fuel in the combustion chamber. Personally I turn the setting on high on the theory that more air will burn off the remaining fuel quicker, burn cleaner with less carbon deposits, and help the stove cool down faster. I'm not sure if it senses flame/temperature to determine when to shut the fan down or it is just a timer. I have timed this several times on my stove and it is fairly consistent.
+1 Mr. Green Beer
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Tue Feb 26, 2008 8:20 pm    Post subject: Reply with quote
Our understanding is same as Bob's and Dan's on starting and shut down and for same reason. On the go we sometimes run it at a lower setting and then raise it back up before shut off. Only time we haven't run it is at night when we turn it off for sleeping. Both of us sleep better with cold air and good covering.
We went through 9.5 gallons on our last cruise and that was with some down time. Would likely have used more fuel but had problems with it and the last day it quit for good. Later found a shorted control board and bad pump. Works great again now.
C-Sick
City/Region: Renton
C-Dory Model: R-25 Tug
Vessel Name: Gratitude
Photos: C-Sick
PostPosted: Tue Feb 26, 2008 11:43 pm    Post subject: Learn From Others Mistakes Reply with quote
The only near disaster that I have had with two different wallis stoves. (I am a fan) I fried a fender by tying the fender where it hung right over the exhaust. It took awhile to figure out where the smell was coming from. Needless to say I was very embarrassed.
C-Sick
In A Bad Way
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Wed Feb 27, 2008 12:50 am    Post subject: Reply with quote
Jeff,
If you are getting a little smoke, check the exhaust connection at the flex to the stainless thru-hull. I had to remove the flex and apply some high temp gasket sealant.
That will take care of any smoke in the cabin.
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
jlastofka
City/Region: Vista
Vessel Name: Bossa Nova
Photos: Bossa Nova
PostPosted: Wed Feb 27, 2008 1:06 am    Post subject: Wallas stove top temperature measurement, 380 deg F Reply with quote
In case anyone's interested, I made the following measurements tonight. I placed a small black anodized aluminum plate (about 2" square and about 1/16" thick) flat on top of the stove and measured its temperature using a handheld infrared thermometer. I had the stove running with the control knob set at the 9 o'clock position, which is moderately low.
The plate quickly stabilized at 380 deg F centered on the cooler side of the stove. I moved it to the center of the 'hot' side and it immediately went above the 500 deg F limit of my meter. Back on the cooler side, I turned the knob up to about 12 o'clock and soon the plate was a little over 400 deg F. Moving it off the the rear corner on the cool side dropped the reading to around 280 F. I didn't do much investigating beyond that. I was mostly interested in figuring out which EcoFan I might want to order. I think the basic inexpensive one, built for higher temperatures, is appropriate here. The cooler range model, for gas stoves, isn't needed and it costs more money anyway.
With the knob at 9 o'clock I could just barely see the red glow under the hot side with the cabin very dark. At the 12 o'clock position it was much easier to see the glow, but it was no where near the bright glow you get with the knob dialed up to maximum warp drive.....
People have been commenting on turning the knob to high when switching off to help burn off the fuel faster, but I've turned it off with the knob set lower and I hear what I think is the stove spooling itself up to a higher heat mode anyway during the shut down cycle. I think it's taking care of things quickly by itself. That's probably why the manual says it doesn't matter where the knob is set during shutdown.
They just recommend having it on high during startup, at least until you get the steady red light.
This is what an engineer does for fun when left unsupervised.....
Jeff
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Wed Feb 27, 2008 1:23 am    Post subject: Reply with quote
I have always started and shut down in the high position. I am puzzled by something mentioned earlier about squeezing the tank to "prime" the pump. I am pretty sure my tank is vented so I don't see what good squeezing the tank would do?
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
PostPosted: Wed Feb 27, 2008 10:11 pm    Post subject: Reply with quote
My experience is the same as Dan's. In high winds on the starboard side, the wind pressure forces fumes back up the exhaust. I have also experienced some waves that covered the exhuast port with water while under way. That got my attention. I hear it through the sink drain all the time but the Wallas port is a little higher. Now when I hear the sink drain being submerged, I shut down the Wallas, change my angle of approach on waves, or turn around. In some cases it is all the above.
We also need to observe and note a completely straight post from Dogon Dory. Dan you're slipping. I had to have hurt the polar bears somehow by exhausting my Wallas into the pristine waters of Prince William Sound if only for a second or two.
Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981-
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Wed Feb 27, 2008 10:34 pm    Post subject: Reply with quote
I use mine underway, at the dock, on the trailer, in the winter, in the summer, just about all the time. It is great. I think the majority of the problems associated with Wallas stoves is they are not used enough, for a long enough duration to stay clean. I love mine and I think it works great for what it is.
jlastofka
City/Region: Vista
Photos: Bossa Nova
PostPosted: Thu Feb 28, 2008 8:50 am    Post subject: EcoFan Reply with quote
Home Depot has them on sale online now for $47 for the basic model. $58.55 including tax and shipping to SoCal. It's shipping from Las Vegas.
They have another model listed, but it's out of stock. Maybe it could be ordered, though.
Jeff
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Thu Feb 28, 2008 9:30 am    Post subject: Reply with quote
Re: Squeezing the fuel bottle - mine shrinks and buckles as fuel is used, so the vent is prob not working well.
My problem, I think, is that sometimes the pump loses it's prime. Squeezing the 2/3 empty bottle raises the liquid level so the pump does not have so much head. On one occasion, I lifted the fuel bottle up to help get flow started.
I am not a detailed expert, just a frequent user, and these were my superficial observatons.
I do appreciate the engineer's thermal analysis! Amazingly different temperature ranges in different areas.
PostPosted: Thu Feb 28, 2008 1:58 pm    Post subject: Re: EcoFan Reply with quote
Jeff
In case anyone missed that post, this is a HOT deal! We just ordered one. Thank you, Jeff, for bringing this to our attention! Thumbs Up
Brent and Dixie loaned us their EcoFan last summer when we went to Desolation Sound... and we used it most mornings and several evenings. Certainly it is more quiet than the regular Wallas fan, but it also uses no electricity and allows you to heat and cook at the same time. I meant to buy one, but without any cold weather to jog my memory, it wasn't on the "front burner." Wink
This deal was too good to pass up. The sale is good through March 26 - online only; we stopped at the closest Home Depot when we went to the TWIC office, and they had never heard of an EcoFan.
http://captnjim.blogspot.com/
dogon dory
Vessel Name: DogOnDory
PostPosted: Thu Feb 28, 2008 2:42 pm    Post subject: Reply with quote
tpbrady
Photos: Bidarka
PostPosted: Thu Feb 28, 2008 8:50 pm    Post subject: Reply with quote
I just tried to order an Ecofan from Home Depot. Guess what, Alaska is not a state they will ship to. At that point, I called their toll free number to ask for an explanation. It was quite simple, Home Depot does not ship to Alaska in spite of the fact they have 6 stores in the state. I was free to try to order from their international department, and they would ship to Alaska.
As far as Home Depot is concerned we are not part of the US. Does that mean we can drill in ANWR now?
PostPosted: Thu Feb 28, 2008 10:50 pm    Post subject: Reply with quote
Just ordered one--they do include Florida--but wonder if it will be confiscated when I attempt to bring it into Alaska by boat?
Page 2 of 3
Page generation time: 0.044s (PHP: 59% - SQL: 41%) - SQL queries: 28 - GZIP disabled - Debug on
