Taking Apart The Wallas 95 DU
Post new topic   Reply to topic    The C-Brats Forum Index -> Documents
PostPosted: Sun Apr 20, 2008 2:05 pm    Post subject: Reply with quote
Pat Anderson wrote:
I would throw this sucker overboard but Patty won't let me.
Pat, with your luck the ##!@@# Wallas probably floats.
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Sun Apr 20, 2008 4:55 pm    Post subject: Reply with quote
Hi Pat,
Last Sept. while cruising the SJ and Gulf islands I had a similar problem. When I replaced the 2amp fuse with a 5amp the stove worked fine for dinner. The next morning I started it and went out to the dock. When I stepped back in the cabin was filling with smoke. I had to pull off the power lines to stop the burning of the components on the main circuit board. Scanmar said it should not have done this even with the 5amp but I won't do that again.
I stopped at Scanmar and they replaced the circuit board at no cost and I was very relieved. I would suggest leaving the fuel line on and sending the control knob on/off switch assembly. They run the stove after repair to test it and this will test the entire system.
I was on my way home when I stopped and they fixed it while I waited - again great service that I was thankful for. I re-installed the stove and tested it before leaving. It worked fine but I did not wait for it to completely shut off before I went on down the road. About 2 hours later when I stopped the fan was still running and it had not shut off completely. I call the tech. and he said it had tested fine and it could only be the on/off assembly that I had left in the boat. I did not have the time to go back so I went on home.
At home I checked the on/off assembly which is just a variable resistor and switch and it looked fine. I tested the stove again and it worked fine and has ever since.
Good Luck,
Steve
Dreamer
Photos: Dreamer
PostPosted: Sun Apr 20, 2008 11:39 pm    Post subject: Reply with quote
Tom and Rene,
That's an awesome piece of work, Thanks. I printed it out and it will go in my on-board file of equipment manuals. Roger
Dreamer- Sold 25 Feb. 2013
PostPosted: Tue Apr 22, 2008 9:34 am    Post subject: Reply with quote
Well, I got the Wallas out without destroying it, Patty hauled 'er into Scan Marine yesterday, we'll have it back by the end of the week. The boat goes down to LUSR as soon as we can get her down there for electrical troubleshooting, since Bob Austin does not live next door. I have every confidence in Aaron and crew at LUSR, as Patty says, "It's only money"...
PostPosted: Fri Apr 25, 2008 9:44 am    Post subject: Reply with quote
Scan Marine turned the Wallas around in a couple of days, Patty brought it home yesterday. Bill was $278 for the service and N/C for the circuit board, which was replaced under warranty. It would have been $591 if not under warranty (plus the $278 I guess), so kind of dodged a bullet. Now the boat is in at LUSR Fife for the electrical troubleshooting, so I can't stick the Wallas back in to try 'er out...but hopefully we'll have Daydream back soon, Friday Harbor is coming up quick!
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Fri Apr 25, 2008 10:39 am    Post subject: Reply with quote
Pat, any reason why the failure? Bad circuit board component, voltage, pump overload (causing board failure)? Doesn't seem reasonable to just replace the circuit board.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
PostPosted: Fri Apr 25, 2008 3:31 pm    Post subject: Reply with quote
Patty here. The boys at Scan Marine told me these stoves need regular maintenance---every 1000 hours. They also said they are meant to be run on diesel, not kerosene or Kleen Heat, and especially not with kerosene that has been stored a year or more. Beware of bargain kerosene. They also said our stove had quite a bit of salt on it and they recommended we spray the entire bottom with a product called Boeshield made by Boeing. It seems our stove needed some maintenance at the same time we were having our electrical issues and it was just a coincidence. I'm glad they replaced the circuit board while it was still under warranty
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Fri Apr 25, 2008 3:35 pm    Post subject: Reply with quote
2 questions:
1. What is the nature of the regular maintenance? Is there info somewhere on this?
2. Re: Boeshield. Is this to be sprayed on the printed circuit board and other components?
Doryman
M/V Lori Ann
Anacortes, WA
PostPosted: Fri Apr 25, 2008 5:06 pm    Post subject: Reply with quote
Patty here. The nature of the maintenance is too technical for me but it involves cleaning the carburetor (right?), cleaning out soot build up, and I don't know what else. The boys told me the regular maintenance reference is "in the manual."
charless
City/Region: Bozeman
State or Province: MT
C-Dory Year: 1998
Vessel Name: Vagabundo
Photos: Vagabundo
PostPosted: Tue Aug 07, 2012 7:13 pm    Post subject: Thanks Tom and Rene Reply with quote
Sorry we didn't get to meet when we were in Portland in June. Hope your transom project is progressing.
I made a copy of your manual on the Wallas and took it with us when we trailed "Vagabundo" to the San Juan's in July. I carried a propane stove since our Wallas was failing to work most of the time.
The first rainy day after we launched in Anacortes I got out the copy of your manual, took a deep breath, and following your helpful descriptions, took the burner apart.
The burner, glow plug, temperature sensor, etc. looked fairly clean to me. I removed and re-inserted every electrical plug I could find, blew out the fuel line and installed fresh red diesel.
I thought Scan Marine might be my next stop. However, the stove worked PERFECTLY for cooking and heating for the next three weeks! I have no idea what I did but your manual gave me the confidence to take it apart.
Thank you.
Charless and Marjorie
"Small things are not small if great things come from them" Blaise Pascal
Chris Bulovsky
City/Region: Washburn
C-Dory Year: 1998
Vessel Name: SCOUT
Photos: SCOUT
PostPosted: Tue Aug 07, 2012 10:10 pm    Post subject: Reply with quote
Shocked I'm exhausted just reading this. I am so thankful I don't own one.
Way to go for doing it yourself! I admire that. I would probably fix one with a hammer. Your a better man than I. Thumbs Up
ShellBack
City/Region: Victoria
Vessel Name: Thalassa
Photos: Thalassa
PostPosted: Wed Aug 08, 2012 10:16 am    Post subject: Reply with quote
Thanks very much for the manual. It was done up great and clear. I work in the Appliance Service industry and the manufactures should take lessons from you. Thanks Again. Terry Very Happy
Duke
City/Region: Old Saybrook
State or Province: CT
Vessel Name: Happy Ours
Photos: Happy Ours
PostPosted: Wed Aug 08, 2012 11:02 pm    Post subject: Wallas Stove Reply with quote
Super job on your Wallas experience!!! Thanks for sharing!!!
primative
City/Region: Portland
Vessel Name: Primative
Photos: Primative
PostPosted: Fri Aug 10, 2012 2:50 pm    Post subject: Reply with quote
WAY TO Go! I'm glad it worked out for you. Sounds like you were not sure what fixed the problem but fuel was maybe a factor.I'm curious, your boat is a 98, is the stove of that year, (85DU)?
My transom repair is complete, motor, and kicker reinstalled. Now finishing details, reinstalling up-grading some equip.. Oh the devil and his details. Should finish GPS and transducer mounting this wk. end..
Thank You one and all for your kind comments
Tom
(Primative)
Post new topic   Reply to topic    The C-Brats Forum Index -> Documents All times are GMT - 5 Hours
Page generation time: 0.0729s (PHP: 45% - SQL: 55%) - SQL queries: 27 - GZIP disabled - Debug on
