window a/c
dogon dory
Vessel Name: DogOnDory
PostPosted: Mon Dec 17, 2007 2:46 pm    Post subject: Reply with quote
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Mon Dec 17, 2007 5:59 pm    Post subject: Reply with quote
Good eyes Dan... Had a visitor on board that afternoon.
Byrdman
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
PostPosted: Mon Dec 17, 2007 6:14 pm    Post subject: Reply with quote
Condensate disposal: On a small Island near David, Panama, we saw a dehumidifier out in the open air, running near the bar, It was their source of distilled water for the rare time that a drink called for water, or a customer didn't want an alcoholic beverage. If you clean the coils well, the water should be fine to drink--air water maker!
In a 22 you have considerably less room for all of these appliances than in the larger boats. A lot depends on how much of the time you will be using it--but a unit which can be removed makes a lot of sense for the Carolinas.
dogon dory
PostPosted: Mon Dec 17, 2007 6:33 pm    Post subject: Reply with quote
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Mon Dec 17, 2007 6:39 pm    Post subject: Reply with quote
You don't need to drain the condensate in the two vented De Lhongi, 9,000 BtU portable A/C. The exhaust air tube picks up the condensate and blows it outside.
It does take a Honda 2,000 to operate it on a hot day, though.
PostPosted: Tue Dec 18, 2007 2:22 am    Post subject: Reply with quote
cbull wrote:
A friend with the hvac business came by this morning to check out my plan. He had a good idea. A portable room a/c. These only have to be vented with a four inch piece of flex pipe. The unit is only 22"hx22"d and does not have a drain line. Coils in unit evaporate all condensation. Also has setting for dehu only. $299.00 plus shipping. Will run off a honda 1000 gen.
Are some of you missing the point made above about using a portable unit with an exhaust flex tube because it doesn't need a drain line because it evaporates the condensation water into the stream of outgoing hot air?
ON EDIT: I missed reading page two of this discussion when I wrote the above question. Can't simply delete it for some reason (no "X" choice).
Joe. Teeth
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Tue Dec 18, 2007 3:10 am    Post subject: Reply with quote
This sounds interesting whats the brand?
marvin
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Tue Dec 18, 2007 3:46 pm    Post subject: Reply with quote
Mounting the AC in the front window has the advantage of not blowing
hot air over cockpit. Also, the noise is up front. The obvious disadvantage
is that you can not run with the unit in place.
Unless you really want to run with the unit in place, I suggest you try using
it in the front window first. We stow it on the V, behind the helm. I have
a fiberglass helm backside, so I strap it to the cover. Even in really rough
water, it has never moved.
Consider getting the unit with temp. control. Most excellent to set the
thermostat to 74 and have it stay that way. No getting up in the middle
of the night because you are freezing to adjust.
Mike
Page generation time: 0.0269s (PHP: 73% - SQL: 27%) - SQL queries: 25 - GZIP disabled - Debug on
