fridge users please help
Sam Walker
City/Region: Wherever the RV is today
State or Province: SD
PostPosted: Sat Jun 19, 2004 4:33 pm    Post subject: Reply with quote
Hi C-Trial and the Group,
While I do not yet have a C-Dory Crying or Very sad , I have a fair amount of experience w/ a portable refrigerator Very Happy . I use my AC/DC 64 qt. Engel tub style refrig. about 3 days per week Shocked . Most often it is in the DC mode in my Ford Diesel truck Razz . Like some of the other models mentioned here it advertises a draw rate around 2 amps. I have never been able to tell if that is an average w/ a duty cycle or if it is 2 amps only while running Disgust . In any event, I have run some tests to see how long it will run on the 2 starter only (Group 65 size) truck batteries. What I have found is that I can run the refrig for about 3 days and still start the motor. Granted the starter cranks slower than normal, but it still starts. I am thinking that it should be easier to start a Honda 40 or 90 than a 7.3 L Diesel Embarassed .
After using my Engel for about a year and a half, I would not go back to an ice chest. All that water mixing w/ my steaks and other goodies Angry Cocktail . My Engel is very cool. (pun intended) Also there is something about the style points awarded by having a refrig. instead of an ice box Thumbs Up .
Engel makes several different sizes of tub units. They will also freeze if you prefer.
Sam on C's The Day or maybe Marinauty (Someday)
It does not matter how many moments that you take a breath, It is how many moments take your breath away.
Sawdust
City/Region: Oak Harbor
C-Dory Model: 22 Classic
Photos: C-Salt
PostPosted: Sat Jun 19, 2004 7:56 pm    Post subject: Reply with quote
Howdy TyBoo Mike,
You pulled my chain, so right back. Wouldn't steer ya wrong, buddy. Those little Harley batteries in old TyBoo22 and the minimum output of the 75 Honda would make an overnighter squeeky... if nothing else in the boat runs too.
Agree that with larger cranking batteries and the output from the 130 you have a good thing going. And I'm going to do the same thing in the new Sea Salt. (Launch in the ayem!!!!)
We are starting with group 27s, and with shore power and a good battery charger I should be okay. But my next purchase (other than a whole bunch of gas) will be a little Honda 2000 gen set. Those rascals are jewels.
I'm not familiar with the unit that Jammin Dennis uses, but it could be the answer. If it works down where Jammin has been Jammin, it should be loafing up here.The math on this electrical stuff is real easy if you do math -- I don't. I do know I've been battery dead many times because of refers in my past life.
Look forward to meeting your gang when you come this way!
Dusty
1984 22 Classic
PostPosted: Sun Jun 20, 2004 11:20 am    Post subject: Reply with quote
Marineparts.com lists this puppy at $992.60 - so I think I can stand letting my steaks mix with thawed ice water for just a TAD longer...Actually, I have been thinking about some kind of false floor, so block ice can be underneath and the food up out of the water...
While I do not yet have a C-Dory Crying or Very sad , I have a fair amount of experience w/ a portable refrigerator Very Happy . I use my AC/DC 64 qt. Engel tub style refrig. about 3 days per week Shocked . Engel makes several different sizes of tub units. They will also freeze if you prefer.
Steven Dore
City/Region: Ocean Marine - Portsmouth, VA
Vessel Name: Orca
Photos: Orca
PostPosted: Sun Jun 20, 2004 10:49 pm    Post subject: Reply with quote
My local grocery store sells 20lb blocks of packaged dry ice. Has anyone tried dry ice in the standard icebox unit? I wonder if this would keep the contents cold longer than bags of ice?
Steve
Cheers
City/Region: Vancouver
Vessel Name: Cheers
Photos: Cheers
PostPosted: Sun Jun 20, 2004 11:52 pm    Post subject: Reply with quote
I've put a 7 pound of dry ice in my cooler with 3 bags of ice - things were still cold after 3 1/2 days in boiling sun. Seems to prolong the melting.
Bob Bilyou, Cheers©
Molly Brown
City/Region: Punta Gorda
C-Dory Model: 24 Tomcat
Vessel Name: MOLLY BROWN
Photos: Molly Brown
PostPosted: Mon Jun 21, 2004 6:48 am    Post subject: Reply with quote
Hey All:
We have an AC/DC Norcold and wouldn't boat without it here in Florida. We use ours even on day trips and just got back from an 8 day trip in the Dry Tortugas and didn't stay in port at all. We've never had a dead battery but must admit that we manage ours daily and we keep the kids out of the fridge whenever possible. Those 5 day coolers sure don't work here either. Seems to work better if you keep the drain plug slightly cracked open. If anyone needs more info let us know.
Completed 01/2025
gotjm3
City/Region: Middle River
State or Province: MD
Vessel Name: C's the Day
Photos: C's the Day
PostPosted: Tue Mar 08, 2005 12:11 am    Post subject: Batteries/Fridge Reply with quote
Just ordered a 25 with the factory fridge, and will be cruising the Cheaspeake in the sweltering mid-atlantic summer. We'll have the Honda 150 + 15 kicker with electric start (for the bigger alternator). We'll have 3 batteries (one for kicker), but 2 connected with the typical 1, 2, or 1+2 switch to the 150 which has the 40 amp alternator. Is a separate house bank recommended somehow wired to recharge, or perhaps one deep cycle and one cranker on the 2+1 switch (my happy boater brain thinks that sounds great but my engineer brain is thinking this isn't a good idea). We'll have a gel cell on the kicker. The kicker will have a 12 amp alternator, which should give us a little bit of back up, but at this point I am not planning on having this wired into the main electrical system. Not sure how to do it if we chose to anyhow... Any all words of advice are welcome. Just want to keep the Beer cold! Thanks and cheers.
TJ
Hailing from Middle River, MD
A drinking town with a boating problem...
PostPosted: Tue Mar 08, 2005 12:46 am    Post subject: Reply with quote
TJ -
Your description of the battery setup is identical to mine, including the gel cell for the kicker that is not wired to the others.
Your other two batteries that are charged through the switch by the big Honda should both be the same size/type if you ever plan to charge them both at once. Les says the marine cranking batteries are great, and that they are sort of a step between a deep cycle and a starter. My setup has one battery for the Honda 130, and the other for the house. I have a battery combiner wired between the two (the 50 amp model of this), so when either one reaches a voltage of 13.something, indicating it is being charged, the combiner switches itself on and parallels the two batteries. That way they both get charged whether running the motor or using the on board battery charger. Some folks don't like the combiners, but I love 'em. It has always worked for me. The only thing I use the 1-2-All switch for is to disconnect the battery from the motor when left sitting for any length of time.
Your fridge will probably have the automatic switch over to AC if the shore power is plugged in. Mine is strictly DC, but when the shore power is on, the battery charger is also going, so the AC switchover is not needed. If for some reason I want to run the fridge on AC separately from the shore power, I have a little converter that I can plug it into. I have run the fridge for a good 12 hours without recharging the battery several times, and it never is a problem.
I think the gel cell (mine is actually an Optima spiral wound) for the kicker is great. It will sit for much longer periods without a recharge than a lead acid type, and generally takes a lot more abuse. But it is sitting right there for use as a jumper battery if ever needed. The chance of needing it is so slight that providing the wiring to let it switch over to the other system is a waste of time. If I ever need it, I can swap the positive cable to it in less than a minute.
Congratulations on your new boat! Let me know when you want a photo album for it, because we gotta see the pictures!
C-WEED
City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Tue Mar 08, 2005 10:53 am    Post subject: Reply with quote
gotjm3:
I took the easy, simple, cheap poor mans route. Might give you some ideas. I have a 22 and only two batteries in the starboard lazaret. I chose a rope start kicker for maximum startability in case batteries are down/stolen? And somewhere down the road will use the kicker on another small craft.
I put aligator clamps on the charging leads and just clamp them to the steering cable in the lazaret when not used. I clamp them to the battery I want to charge when I run the kicker. This bypasses the 1-2 switch and any other engine/charging configuration you may have. If you want, you can run house items off one battery while you charge the other by using the switch for house and clamps for charging.
Not a good idea to have the clips on the same battery when the main engine is running/charging that battery. Or when using the shore power charger. So it takes a bit of disipline. As a remider/safeguard I use one fuel line for both engines. When I put the fuel line on the kicker, it reminds me to check the charging leads.
Not sure where all your batteries are located but with charging leads from your kicker being able to be connected to the other batteries: You could start the kicker on the gel and charge any other battery with the leads if needed. Or use a three position switch to route only the kicker charging to any of the three batteries instead of clamps. Then off when not used.
Chris
flagold
City/Region: Abbeville
Vessel Name: C-Dawg-E
PostPosted: Tue Mar 08, 2005 12:24 pm    Post subject: Reply with quote
Agree with "Molly Brown" -- after having the Norcold, absolutely would not be without it.
Since I "cruise" and "anchor" on land much more than water, the Norcold really gets a workout. I have a dedicated start, and a single deep cycle for the house (80/amp/hour).
Fairly easy to manage the fridge -- power it up and set to max and get the box cold -- back down to #4
-- at night turn it off (it'll act as an ice-box overnight). In the morning -- turn it on to #4. That single battery will last over a week that way. Just a matter of power management.
All the straightline power graphs, curves, figuring, re-figuring, don't work with the Norcold. The compressor is off -- more time than it is on. It is very well insulated. It has been no problem, I run mine a lot.
As someone once said: "turn it on, use it, turn it off." Just like a Mercury.
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Wed Aug 10, 2005 10:57 am    Post subject: Reply with quote
Although I am new to this site, and am still looking for a c-dory I am not new to this topic. I lived aboard a sailboat for 10 years and batteries and refrigeration were right up there in the topics list at every dock or gathering. Seldom will you see a front opening icebox or fridge on a sailboat. Those folks know their refrigeration and charging and go to extremes to manage and generate electricity. When bombardier came out with e-tec I was extremely pleased to see all those amps in from the alternator. Something like 65 amps. If I buy a c-dory with an ice box it will come out. But if I repower or power new I will try to make it e-tec and a adler-barbour or similar unit will go back in. I remember my first adler barbour I put in a sailboat. After planning my voyages around the availability of ice I was finally able to make ice, what an incredible luxury. BIG ice cubes in my drink. It is great. My last system was powered by 2 6 volt golf cart batteries. Manageable size, and they would run the compressor for at least two days at the hook without starting the diesel. Then when I did start the diesel I had a bypass on the regulator so I could charge up in an hour or so. C-dory boats are big enough, with enough storage to have some of these amenities.
flagold
PostPosted: Wed Aug 10, 2005 12:44 pm    Post subject: Reply with quote
The Norcold for my boat is one of the best additions there was. I can vouch for the 3 days on the house battery if you switch it or turn to low at night -- it does not run continuously at any setting. Ice is great -- flexibility is great. With a small generator aboard, no worries.
ffheap
City/Region: Hingham
C-Dory Year: 1983
Vessel Name: Inn-The-Water
Photos: Inn-The-Water
PostPosted: Wed Aug 10, 2005 7:22 pm    Post subject: Reply with quote
Hi Folks,
I did not see this mentioned, but if you add a Solar Panel to your cabin top, it just might keep things cold with an AC/DC Fridge. Worth looking into.
Fred Heap
Fred
PostPosted: Thu Aug 11, 2005 9:31 am    Post subject: Reply with quote
Pat - a few years back I found some shelves at Target that were designed for use in school lockers. They're made out of two plastic pieces that nest one within the other and are designed so that one can be pulled out and locked at many different lengths to allow one to adjust it to the width of the locker and jam in place (rubber feet on the end retain it). The pieces are about 1" thick honeycomb material - they made a great false bottom for a cooler. Look for them this year during the back to school sales...
Roger on the SeaDNA
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Thu Aug 11, 2005 9:03 pm    Post subject: Reply with quote
Good topic... I will have to do some searching... Pat/Daydream: we just use about 9 cans of our favorite beverage in the bottom of our "food" cooler to keep stuff out of the water. They make for a very easy cleaning shelf...grin. We also keep one cooler on board with nothing but ice in it. Open it about 2 hours after dark and transfer ice from it to the "beverage" cooler which is opened often, and the food cooler which is only opened 1 to 3 times a day depending on meals.... I have saw some real commercial grade coolers that are for real long term coolers used on the commercial fishing vessels on the Gulf Coast. They have to be tuff to take the direct sun light, heat and humidity down here. They are spendy .... I am going to have to look into this refrigerator deal. Would be nice to keep one in the back of the Excursion with condiments and stuff to make these day or two trips to the boat a little easier...and tail gateing at the football games a bit nicer too.
Page 2 of 4
Page generation time: 0.0714s (PHP: 58% - SQL: 42%) - SQL queries: 28 - GZIP disabled - Debug on
