Lobster
PostPosted: Wed Oct 03, 2007 1:25 pm    Post subject: Reply with quote
Jeff-
Do you have a PC or MAC type computer? The process is somewhat different:
If you have a PC, the paragraphs below will help along with the thread
Attaching Photos to a Reply
(From Lyle T)
Here's a quick tutorial for IE - the procedure is similar for all OS's and browsers. It's a little tougher than a regular link, but once you do it a few times, you'll get the hang of it.
- Go to the picture you want to include. For this excercise, we'll assume it's in a C-Brat photo album, although it could be anywhere on the Internet. Here's a link to Digger's puller bracket in the Snoopy-C album.
- When you see the image on screen, move your mouse over it and click it with your right mouse button, then select Properties. In the window that pops up, you'll see an "Address" field - it starts with "http://". This is the text you need to make the image link work.
- Drag your mouse across the Address text to highlight it. Note: it may span more than one line, so make sure you get it all.
- On your keyboard, press Ctrl+C - this will copy the text to your clipboard. It will look like nothing happened.
- In the window where you are entering your new message post, position your cursor where you want the image to appear. Press Ctrl+V - this will paste the Address text you highlighted earlier into the message window.
- Drag your mouse across the Address text you just pasted into the message window to highlight it, then click the button that says "Img". The text for the picture on the linked page above will look like this in the edit window:
Code:
Click the Preview button, and you should see the picture in the message. If everything looks OK, click the Submit button to post your message, and as you'll see below, the pic makes it into the message.
Lyle
_________________________________________________________________
(from Joe again)
Jeff-
If you have a MAC, the procedure is a little different:
Go to the photo you want to include.
Press the "control" key. (bottom left)
A drop down menu will appear.
Click on "Copy Image Address" with the mouse.
Return to your text message.
Go to where you want the photo.
On One Line
type [img]
add the photo address
type[/img]
The finished line will look like-
[img]real photo address here[/img]
and give you :
*****Be sure to use the right [ and ]. They're the one's nest to the letter "P" AND DO NOT CAPITALIZE!
Hope this helps! Questions? Let us know!
Joe.
C-Pelican
City/Region: SoCal
C-Dory Year: 1992
Vessel Name: C Pelican
Photos: C-Pelican
PostPosted: Wed Oct 03, 2007 2:19 pm    Post subject: Reply with quote
Thank you gentlemen.
J
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Thu Oct 04, 2007 1:37 am    Post subject: Reply with quote
4-5 pounder? Hoopnetted? I'm jealous...
(thanks for the offer to do better catching, we'll be all eyes and ears when we can get schedules to match)
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
Page generation time: 0.0408s (PHP: 62% - SQL: 38%) - SQL queries: 20 - GZIP disabled - Debug on
