JT
C-Dory Year: 1990
Vessel Name: Lil Toot
Photos: Palomino
Posted: Sat Feb 23, 2008 3:31 pm Post subject: Herculiner |
You might want to check out Herculiner.
Redfox used it on his cockpit. It comes in a few colors.
You can do it yourself for a couple hundred or so. They recommend uv coating over black.
Might get a quart and try it on a scrap or something.
Most auto part stores stock black. Other colors can be ordered online.
JT |
Nine Inches
Joined: 22 Feb 2005 Posts: 24 City/Region: Clackamas OR
Vessel Name: Nine Inches
Photos: Nine Inches
Posted: Sun Feb 24, 2008 7:01 pm Post subject: |
Had Line-X applied to our 16 Angler when new in 2004, we use the boat for Scuba in the Ocean, tanks, weight belts, spearguns, still looks new, non-slip, great surface. Ours is black. Used a do-it-yourself kit, "Herculiner", about a hundred bucks, on a tri-hull prior to the C-Dory and it was the best part of the old boat. I'm a believer, will use it on next boat. Don't know about weight, the kit was one gallon and less then 15 pounds, spray-on finish might be heavier, maybe 20 pounds. |
