Fresh Water Rinse
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Mon Jun 11, 2007 7:16 pm    Post subject: Reply with quote
When we bought our boat, I was warned by the dealer that Honda
published some manuals with incorrect info with regard to running
the motor with the garden hose attachment.
You probably do not want to run the motor with this method of providing
water unless you are certain the water is going to flow through the
impellor.
You can run the motor with muffs, of course.
The salt line does not extend to where I slip our boat and I've never
seen anyone flush an outboard in any local marina, so I do not
worry about it. If we come in at low tide, I'll raise the motor (but keeping
the intake in the water) and allow it to run for a while.
Mike
ahpeterson
PostPosted: Sun Feb 10, 2008 7:00 pm    Post subject: Reply with quote
So this may be obvious to some, but when running with earmuffs or the garden hose attachment on the motor, is the motor tilted down in the water, or up?
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger MSN Messenger
Dreamer
Photos: Dreamer
PostPosted: Sun Feb 10, 2008 8:47 pm    Post subject: Reply with quote
The engine should be in the down position when running. This has nothing to do with flushing but with the engine oil level in the crankcase.
When running my Honda 150s on the earmuffs while on the trailer, my overheat alarm sounds after about 10 minutes. The temp indicator doesn't show overheat however. Question Question
Dreamer- Sold 25 Feb. 2013
mwilson
City/Region: missoula
State or Province: MT
Vessel Name: STORMY
PostPosted: Fri Mar 21, 2008 7:50 pm    Post subject: Cooling system on Honda 40 Reply with quote
Its that time for antsy folks to pull some maintenance and I wonder if some one might have and answer to a cooling system issue? I wanted to run the motors to check everything after a tuneup but couldn't get water to come out of the pee tube.. I checked everything and tried a flush nozzle and still wouldn't come out.
The impellers were only a year old, so didn't seem like that would be the problem so I eventually had to fill a tub with water that completely covered the inlets and finally water came out fine.
Shouldn't water come out with just muffs on or with the flushing nozzle? thanks michael
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Fri Mar 21, 2008 7:57 pm    Post subject: Critters Reply with quote
You may have a spider or another such critter in the pee tube. A pipe cleaner or something of that nature usually cures the issue. It happens to my kickers all the time.
Steve
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Fri Mar 21, 2008 9:41 pm    Post subject: Reply with quote
I keep my boat in a lift and it's nearly impossible to reach the flush port on a Honda 50. When I bought it I had the dealer Big Boys rig a flushing hose that tied in somewhere under the cowling a exited the motor along with the controls. It had a standard female hose end on it with a screw in plug and it worked great for flushing. I'm not really sure where he tied in and no longer have the engine. I flushed with the engine NOT running. I'm also a big believer in Salt Away. You can literally see it sort of disolve the salt when you wash down the engine and I use it on my trailer axles also.
marvin
westward
C-Dory Year: 1985
Vessel Name: TBD
Photos: Steady Eddy
PostPosted: Fri Mar 21, 2008 11:07 pm    Post subject: Reply with quote
Mwilson: Not sure of your engine type, but when flushing with muffs (Honda 40) I don't get peeing unless I block the 3rd water inlet under the cavitation plate with duct tape. I'm hoping my Permatrims allow me to use one of those flushing bags as I believe that total lower unit immersion is the best way to get water to the engine. Mike.
Page generation time: 0.0433s (PHP: 42% - SQL: 58%) - SQL queries: 20 - GZIP disabled - Debug on
