Towing with motor up or down
Pandy Girl
City/Region: Westfield, NC
Vessel Name: Pandy Girl
Photos: Pandy Girl
PostPosted: Sun Mar 18, 2007 10:45 pm    Post subject: Engine up or down Reply with quote
Thanks all I may get back with the dealer and ??? him about long miles towing.
Pandy Girl
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Wed Mar 21, 2007 12:39 pm    Post subject: Reply with quote
I was talking with a Honda dealer about this, and he says:
trailer down as far as is safe. If the main support bar of your trailer is 8" above
the ground, give yourself a foot at the skeg.
He said the flip down brackets are there in case the hydraulics need to be
worked on. Flipping down the supports allows the trim-tilt to be safely removed.
If I were going to trailer a long distance, and if the lower unit would be too close
to the ground in full down tilt, I would probably put a piece of wood in between
the lower unit and the transom in case the hydraulics leaked or the motor otherwise
could get lower than originally set for. (Someone walking by and hitting the
down switch, etc.)
I trailered the boat with the motor in this position for the first time yesterday, and the motor
certainly looked more secure on the transom. Also consider that this is
how the boat is designed - to have the motor in the down position and generating
enough thrust to pick up the boat and hurl it along at 30mph.
Mike
Not For Hire
City/Region: Cadillac, MI
Vessel Name: Not For Hire
Photos: Not For Hire
PostPosted: Wed Mar 21, 2007 1:34 pm    Post subject: Reply with quote
I trailer down. I move the adjustment bar to the highest hole when trailering and lower the motor back down onto it to relieve strain on hydraulics. I have to redo this at the launch site because when running I have the adjustment bar in the lowest hole. Many others, including El and Bill use a thick wooden dowel. Does the same thing. Raises skeg some inches but still trailer down.
Regards,
Mark
Mark S
Cadillac, Michigan
mikeporterinmd
Photos: Shelly-IV
PostPosted: Wed Mar 21, 2007 5:18 pm    Post subject: Reply with quote
Regards,
Mark
The Honda mechanic pointed out that these hydraulics will accept the force of
the motor pushing the boat along at 30 mph. I suspect they are strong enough.
But, you could loose pressure and have the motor drop down.
Mike
Alasgun
Guest
PostPosted: Wed Mar 21, 2007 8:02 pm    Post subject: Towing with the motor up or down Reply with quote
I think that is the purpose of the lock, to keep the motor up during transit so it cant fall.
Mike on Huda Thunkit
mikeporterinmd
Photos: Shelly-IV
PostPosted: Wed Mar 21, 2007 8:29 pm    Post subject: Re: Towing with the motor up or down Reply with quote
Dunno. Guy claimed he was Honda certified and that's what he was
taught. The brackets (I'm only talking Honda...no other motor) are
only for holding up the motor during maint. on the motor trim/tilt.
Honda manual says "down" if possible or use one of those support bars.
Mike
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Wed Mar 21, 2007 8:52 pm    Post subject: Re: Towing with the motor up or down Reply with quote
Mike
Your right Mike--just read it myself. Yes I am a Doubting Thomas. Can't remember where I got the info to transport in the tilted position. Should have read my manual more thoroughly. I got stuck on the prop clearance thing. Honda does have a lot of built in forgivness. We've trailered in the tilted position against the stops for almost 30000 miles mostly on poor road serfaces. Many miles on dirt roads, 2 trips to Alaska and so far all is well. This years Alaska trip will be the El and Bill way. Can't be much of anything there way that isn't tried and true on a 22 with twin Hondas.
Page generation time: 0.0284s (PHP: 63% - SQL: 37%) - SQL queries: 19 - GZIP disabled - Debug on
