mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
Posted: Sun Dec 03, 2006 11:18 am Post subject: |
flapbreaker wrote: | mikeporterinmd wrote: | Remember that
most marinas are wired for 30 amp service. So, whatever wiring
you use between the marina and your boat needs to have an
ampacity of 30 amps (meaning it can carry 30 amps without
catching on fire). Once you get to the breakers on your boat,
wiring past that point can be sized to match the breaker on your
boat.
Mike |
Well, marinco sells 30 amp to 15 amp adapter plugs. I'm assuming that I need their $50 30amp shore power cable to go between the dock power and this adapter. Then any cable I use on the 15amp side of this adapter can be rated for 15 amps. Is this thinking correct? I would be plugging my CGFI box into the 15amp adapter. |
Everything after the adapter needs to be 30 amp rated until you get
to a 15 amp breaker. I have not checked the adapter itself - I
have one somewhere - but presumably it is 30 amp rated. So, if it
plugs directly into something that has a 15 amp breaker, and
the wiring from the inlet to the breaker can carry 30 amps, you should
be OK.
I know this all sounds excessive. However, I've been in a marina
fire caused by an electrical fault. We later found out two people died
in that fire. My last boat had a fault that the surveyor found.
Every once in a while, someone dies swiming in a marina due to
stray current. If you put an inverter or generator on a boat, then
it can happen anywhere. Also, sometimes surveyors get killed because
DC neutral and AC grounding aren't bonded. They'll start checking
underwater components and come across an AC./DC leak. I know
of at least one death in Annapolis a few years ago.
Mike |
flapbreaker
Joined: 26 Jan 2005 Posts: 878 City/Region: Hillsboro
Vessel Name: Playin' Hooky
Photos: Playin' Hooky
Posted: Sun Dec 03, 2006 12:45 pm Post subject: |
Mike,
What you say makes sense. However I'm confused about the need for a power chord that's rated for 30 amps but has a 15amp plug to fit the 15amp side of the adapter. I seriously doubt I'll find it. This makes me believe that there isn't 30amps coming from the 15amp side of the adapter. I have an email into marinco to answer this quesiton. I'll report back when I hear anything. |
mikeporterinmd
Photos: Shelly-IV
Posted: Sun Dec 03, 2006 7:09 pm Post subject: |
Depends on what you are doing. I just bought a 15 Amp -> 30 amp
converter so I can plug in my boat while at home. This is safe
because the outlet at the garage, the extension cord and the connector
are all rated at 15 (20) amps and the outlet on the garage has a
20 amp breaker.
But, using a converter to convert a 30 amp dock connection down to
15/20 amp isn't safe unless you change the breaker at the dock
to 20 amps.
Basically, extension cords don't belong in the marina.
Of course, you can have a private dock with 20 amp service, or
perhaps your marina does have 20 amp available.
Mike |
mikeporterinmd
Photos: Shelly-IV
Posted: Sun Dec 03, 2006 7:12 pm Post subject: |
By the way, the adapter pic you show is for plugging a 30 amp shore
cord into a 20 amp outlet. This is safe. I have one. I decided to
get the opposite and run an extension cord at home because I don't
want the shore cord sitting outside all winter.
Mike |
flapbreaker
Posted: Sun Dec 03, 2006 9:41 pm Post subject: |
Mike,
I had the wrong 30 amp adapter pictured. I've updated my original post. Here is what it looks like now. Notice that my CGFI/breaker box has a 15 amp cord and I was planning on running it to the power inlet. Then the 15amp side of the adapter plugs into the CGFI. If I understand correctly the cable from the CGFI is the unsafe part since it's only a 15 amp chord? Even though marinco makes an adapter to downgrade (maybe it doesn't do what I think it does?) the 30 amps to 15 amps? Sorry for all the pesky questions just want to make sure we understand each other.
To
To
To
To
mikeporterinmd
Photos: Shelly-IV
Posted: Mon Dec 04, 2006 8:47 pm Post subject: |
flapbreaker wrote: | Mike,
It could be sort of safe: it depends on what breakers are installed. Think
of it this way: what is going to happen if you plug a 16 gauge
extension cord into an outlet that has 30 amp breakers, and the cord
gets caught between the dock and your rubrail? The cord will probably
burn before the breakers will trip.
There is nothing magic about the adapters. They do not, in so far
as I know, have integral breakers, fuses or current limiting devices.
At least not the ones we're talking about here.
Mike |
Joined: 02 Nov 2003 Posts: 21607 City/Region: Pensacola
Posted: Mon Dec 04, 2006 9:02 pm Post subject: |
This is probably an appropiate place to mention a common problem with boat wiring systems. Mike mentioned a fire--and I don't have any idea what caused that fire. But one of the most common reasons for 110 V over heating/fires is at the plug to the boat (female cord/boat recessed male). The boat fitting often gets some salt/corrosion and increases resistance. Often the shower power is not turned off properly before this plug is disconnected--and arcing occurs. With carbon formation, detiorration of these plugs, heat builds up--and the plug plastic softens and eventually causes a short--or enough heat build up to cause a fire. Often these plugs don't have the ring which tightly holds the plug to the boat fitting, or the ring is not tight, and the fitting works, increasing the potential of arcing.
Always turn off circuits in the boat, and on the dock breaker before unplugging the cord at the boat (and at the plug). Inspect both the male and female fittings regularly to be sure that there is no carbon build up, sign of increased corrosion and resistance, or melting of the plastic. _________________ Bob Austin
mikeporterinmd
Photos: Shelly-IV
Posted: Mon Dec 04, 2006 9:22 pm Post subject: |
This is exactly the fault that the surveyor found on our last boat. The inlet
needed to replaced.
Mike |
Posted: Tue Dec 05, 2006 12:53 am Post subject: |
I've had exactly that problem with one of my boats! Noticed the amperage and voltage meters bouncing around (surging) and traced it to that connection and a loose threaded lock ring.
Also, be sure you have the plug twisted in the lock position not the release one, or the connection will be shaky.
As a side note, I noted that with 110 volts registered on the electrical panel voltmeter, my upolstery stapler seems to work at 1/4 strength. Back at home with 125 volts, it pumps them babies in like a pneumatic tool! Amazing what the loss of 10-15 volts can do to some voltage sensitive appliances and tools.
mikeporterinmd
Photos: Shelly-IV
Posted: Mon Dec 11, 2006 11:01 pm Post subject: |
One way to nearly connect the AC to the DC ground to almost get the
shore cord under the skeg and accidently hit the down button. That
was close...
Mike |
