mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
Posted: Wed Nov 29, 2006 10:35 am Post subject: Re: Circuit breaker problems |
jstates wrote: | Mike the 15 amp breaker is the one that is tripped by the heater - the other 15 amp breaker to the battery charger works ok - though I have been turning it off when running the heater.
The GFCI seems to work ok, it is not turning off the power when the circuit breaker goes.
Jim |
I'd pull the outlet after the trip. Feel for anything hot. Check the wiring back to
the breaker panel. Look for anything loose, corroded connections, etc. Also,
the breaker swap idea mentioned before is a good idea. Make sure no one
put butt connectors in the wires between the outlet and the panel. If they
did, check them, and properly box them or replace the wire.
You shouldn't need to turn off the battery charger. You have 30 amps at the
panel; the charger shouldn't matter. You would only need to turn off the
charger if it was drawing lots of power, which it shouldn't be.
For instance, if you have a 30 amp charger, that's 30 amps at 12 volts. The
draw from 120V will be something around 4-5 amps, so you are maxing
at 15 amps to trip the one breaker, plus 4-5 for the charger, which isn't
really close to the 30 amp feed.
I'd be careful. While it's possible the breaker is bad, more likely something else
is broke. If the breaker is tripping, something might be getting hot.
Mike |
jstates
Vessel Name: Endurance
Photos: Endurance
Posted: Wed Nov 29, 2006 11:21 pm Post subject: Shore power |
Today I removed the icebox and checked out the circuit breaker from the back. - Interesting. Three breakers - 5-10-15, 15 amp for the battery charger, 5 amp wired to the outlet for regular plug ins and the then 10 amp not wired in to anything. So I changed the wires so the outlet was on 10-amps and the heater now works up to 900 watts - or level 3 of 4 -
I think I will eventually purchase a 15 amp to replace the 5+10 and hook that up to go to the dual outlets.
Thanks to all who helped on this - also my formula was wrong a few posts back - it should be E=IR The Watts = volts x amps was helpful today as it correctly calculated what level of wattage would throw the breaker - ie over 10
Jim |
Dora~Jean
Joined: 09 Mar 2004 Posts: 1514 City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
Posted: Thu Nov 30, 2006 12:20 am Post subject: |
Be careful to check the size wiring upstream of that 10 amp breaker before replacing with a 15 amp, might not be large enough. _________________ Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
+4 Previous, 1/2 sail, 1/2 power |
Joined: 02 Nov 2003 Posts: 21357 City/Region: Pensacola
Posted: Thu Nov 30, 2006 2:23 am Post subject: |
"Normally" the house hold type of outlets are on a 15 amp circuit. I suspect that someone wired the boat improperly. I have an older ferro resionate battery charger (30 amp 12 volt output) on my bench--and it takes 5.5 amps. A newer 20 amp transister unit only uses 3.5 amps. I missed what size your battery charger is--but most likely it is less than 10 amps--and 5 amp AC breaker will be fine. Rewire the plugs to the 15 amp breaker--and I agree check the wire--but # 12 will be fine--many boats will have #14 for short runs...I prefer #12. The main power cord into the boat should be #10 wire--and from the plug on the side of the boat to the breaker pannel should be #10 wire. (one of the issues is that most of these little heaters use too small a cord wire size. I just checked a 1500 watt Ceramic heater--and it has #16 two strand wire "rated for 105 deg C. If I was using this type of heater on the boat (which I am not because I have seen some arching in the Ceramic heaters) I would have # 12 wire cord.
Tools I use looking at these type of problems are the "kilo-watt" unit with an adaptor--measures the voltage, (AC 110 +/-) hz, amps, watts and comulative amps. For DC (and other AC, resistance etc) of course the digital volt meter, but another handy gadget for looking at wiring and circuit breakers is an IR thermoter. I have a couple of inexpensive Radio Shack units--they check out quite accurately and go up to 400 degrees. Great to measure wire temps, breaker temps, buss bar temps etc--plus the trailer axel bearings, tires, motor cooling equality etc. _________________ Bob Austin
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
Posted: Thu Nov 30, 2006 12:21 pm Post subject: |
Bob, I Googled "kilo-watt" and couldn't find the tool you mentioned. Can you provide additional search info?
M/V Lori Ann
Anacortes, WA
Posted: Thu Nov 30, 2006 1:16 pm Post subject: |
Warren-
The meter is a "Kill-a-Watt".
And here's a LINK to a good article on it's use .
jstates
Photos: Endurance
Posted: Thu Nov 30, 2006 1:20 pm Post subject: Wire size and amps |
Bob are you saying that even when something is rated for 15 amps it may work fine on a lower amp circuit? My C-DOry Manual said the charger needed to be on a 15 amp circuit - I will check the charger and manual again when at the Marina today?
I like your idea of reversing it - I could try it - I check the boat daily especially when its raining hard - as its my first rainy season with a power boat. So if the battery wore done from running a bilge pump and the charger blew the circuit braker due to low amp - I wouldn't flood the boat.
Also how do I determine wire size - besides reading the label on the insulation - wires are very short, and stuffed way in the back under the helm seat, and then bifocals and headlamp have to fit in there also?
Jim |
mikeporterinmd
Photos: Shelly-IV
Posted: Thu Nov 30, 2006 4:41 pm Post subject: |
The charger may output 15 amps at 12 volts, but I can't see how it would draw
15 amps @ 120V. Such a charger should output nearly 150 amps @ 12V.
However, the breaker for the charger can often be 15 amp if the wiring to the
charger supports 15 amp (ie: is 14 gauge or better) and the charger is designed
for a 15 amp breaker. |
jstates
Photos: Endurance
Posted: Fri Dec 01, 2006 1:01 am Post subject: Charger |
Mike
Interesting my CDory manual said I needed 15 amp - but today I found the Guest Battery Charger Model 2610 manual [I am 3rd owner of Dory] and it indicated put a 15 amp fuse with in 6 " of the battery - it is there, and use a 5 amp circuit breaker. So as was mentioned above - they wired it wrong from the beginning switching the outlet on 5 amps with the charger on 15 amp breakers.
This has been good experience - to learn new details about the CD. Thanks to all.
Jim |
mikeporterinmd
Photos: Shelly-IV
Posted: Fri Dec 01, 2006 3:29 pm Post subject: |
Right, you should have a fuse on the wires to the charger near the batteries
in case of a short. If that happened, you would have full battery current
flowing through the wires and surely start a fire.
BlueSea makes a line of 12V breakers that range up to around 150 Amps.
Waterproof, ignition proof, etc. Surface mount. Seem perfect for protecting the charger
wires if the charger outputs more than 15 amps or so.
Mike |
Falco
Joined: 20 Dec 2004 Posts: 164 City/Region: Flagstaff
Photos: Bucking Coho
Posted: Fri Dec 01, 2006 4:07 pm Post subject: |
Re: Charlie's land based flush system: I realize this won't help anyone at the dock, but I use something similar. It's an old poly barrel, cut to height to allow water (when filled ) to cover the cavitation plate (ie all intake ports). I added 4" casters to the bottom and sealed the bolts/holes with 3M 5200. I add Salt away to the water and store the barrel full until next needed, replenishing any amount that's evaporated with new salt away. I change out the water every 3-5 flushings. This system is worth every bit of cost and effort to make. Flush muffs are a pain spew water all over the place, don't allow easy injection of Salt Away (the adapter is junk IMHO) and I don't think provide enough water to the system.
Another idea: I routinely stop off on the way home from a salt water trip at a fresh water launch ramp. I drop the rear tie downs, loosen the winch strap and back the trailer and boat in. I start up both engines for 5 min. This also washes off the back of the trailer and wheel and brakes...
As to dock flushing: here's what I would try. Use a hose fitting which screws directly into the engine. (This can be done with engines trimmed up. The port is usually just below the cavitation plate, next to the top gear case vent screw. Lower the engine (agreed w/your mechanioc running the engine in the tilt position is not a good idea. Granted the engine will still suck up some salt water, but I believe this will still help. Trim up the engine at the end, with water still going, and kill it when it's up. |
Posted: Fri Dec 01, 2006 5:26 pm Post subject: |
Joe, Thanks for spelling the Kill a Watt and linking to it.
As long as the current draw is less than the breaker/fues no problem using it. One can measure current draw with most digital volt meters with the meter in series with the circuit. But most meters have a second connector for the power more than half of or amp or an amp. This will be fused and is often up to 10 amps. Do your first measurement on the higher current draw setting--rather than risk damage to the meter.
I use the in line blade fuses, which have rubber holders, that can be filled with a protective grease within 6" of the batteries. I also fuse protect a circuit on the other end if it is a long run. (like by the charger). Some chargers have a circuit breaker built in. I like to corrosion protect each crimp. For higher power circuits I use the larger circuit breakers. Some of the larger fuses, one has to have a cover for the fuse and holder.
There are tables on wire sizes/vs amps/voltage drop. West Marine Catalogue has a nice one it in--and you can take last years catalogue and laminate that table to keep on the boat. An on line table is at:
http://www.rbeelectronics.com/wtable.htm
Remember that the total length of run is twice the one way--if you need 10 feet of positive wire, and 10 feet of negitive wire--the total run is 20 feet--not 10 feet. I tend to be conservative and use one size up of wire if it is near the upper end of the tables.
Also as you begin to do more electrical work around the boat, you will want to have a good pair of ratchet crimpers--use marine grade connectors--which have shrink wrap, adhesive filled tubing (a heat gun or hair dryer to shrink the tubing). |
jstates
Photos: Endurance
Posted: Fri Dec 01, 2006 7:51 pm Post subject: Protective grease for electrical circuits - inside/outside ? |
Great suggestions above - thanks for the details. I do have a new tube of protective grease from Boat World but did not know how to use it - except as perhaps applied to the outside of battery terminals in my truck.
Yesterday as I opened the battery compartment - and checked all the fuses the one to the bilge pump [that had stopped working] was totally corroded and fuse blown.- the fuse holders have an orange gasket [looks like a thick rubber band] to seal out water but they are drying out, cracked and clearly not water resistant - so do I put the grease inside into the fuse contact sockets as well as outside on the drying rubber gaskets?
Also I keep the radar display at home till I need it. As a consequence when docked for a few days at the Marina I have terminal plugs [female end] that are open to salt air - do I put the grease in or on the those plugs as well. Or how do I protect them from corrosion when boat is kept in Marina?
thanks
Jim |
Posted: Sat Dec 02, 2006 11:09 am Post subject: |
Yes, you do want to put the grease in the fuse holder--what you describe is similar to what I have. If there is significant corrosion it is probably best to replace the fuse holder and fuse. Sort of false economy to try and clean it up for a couple of bucks costs.
I use "Corrosion Block", but Corrosion X, any of the water displacing sprays will keep corrosion from the electronics terminals. I do this when taking the electronics off the boat (long storage, or in-secure areas). Also when I hooked up the Radar pins and ground in the scanner dome, I put small amounts of corrosion block on the pins and ground connection. |
