Posted: Tue Oct 24, 2006 10:40 pm Post subject: |
See my post about a "Tale of two fans".
The Group 31's are physcially larger and considerably more capacity than a group 27.
The Gel battery is extremely sensitive to voltage over 14.0 volts. I had an 8 D gel cell on an RV--I used it only for ham radio and a back up for the golf cart house batteries/start battery. I only charged it from the inverter, on the gel setting. I sold the RV with the caviat that the Gel cell never be charged from the main engine alternator--less than one week later the buyer called saying that the gel cell was no good. Yep, he had switched it on to charge from the alternator for about 3 hours--end of gel cell. The major advantage of Gel Cell is low self discharge--but the AGM is also low self discharge. If the boat is stored remotely, buy a small solar pannel for trickle charge.
Batteries and lights? LED's are the answer. We have several portable white LCD clusters we use specifically for reading. Basically we don't use a lot of lights on the C Dory (or on any boats)--if so we use Alpine glow lights (super effecient). Don't use red lights unless you have some specific use for them. We don't normally run red lights at night, even on ocean passages. We have a couple of very dim red flashlights and one red chart light used only when necessary. Last Sunday night we ran for 3 hours on the ICW, and up Perdido Bay--not the use of one red light--just not necessary.
Chain. For small boats, only a small amount of 1/4" or 3/16" HT chain is necessary. Even for larger boats HT chain makes sense. I don't have any more chain with a windlass than the depth of the water in which I will be anchoring (exception is world cruising boats). For a 22 C Dory, without a windlass, only a few feet of chain is necessary.
We didn't use refigeration on the 22. We have a freezer/refigerator chest type on the TC 255. Most of the food is kept in coolers--but entrees for longer trips will be in the freezer. Ice is cheap--refigeration and generation and storage of electricy is expensive. Many of the small refigerators are too small for practical use anyway, so you end up with coolers and ice. Again--size the appliances to the boat--bigger boat more appliances, smaller boat less appliances and simpler. Makes life much better! _________________ Bob Austin
Joined: 23 Oct 2003 Posts: 5315 City/Region: Warrenton
Posted: Tue Oct 24, 2006 11:13 pm Post subject: |
Mike -
I was going to stay out of this one, but there are just too many things in your last posts that I can relate to. Like budgets being spent, needing more light as time goes on, and wanting more stuff on the boat. Sounds just like home.
As for the battery system, well, I guess I am a simpleton because I could never understand the need for all the sophistication on a trailerable boat. I have two Costco marine dual-purpose batteries (about $50 bucks each), a WM 50 amp combiner with VSR (about $30 on sale), analog voltmeters (about $15 each) and an RV style charger that was on board when I got the boat. I never have a problem with it and I never worry about it. The VSR combiner has a switch to turn it off, force it on, or run it in auto. The windlass is hooked to the starting battery, and everything else inside is on the house batt. I always start the motor and disable the combiner when I use the windlass so the electronics don't take a hit, but beyond that I never worry. And if the house batt is below 12.5v, I run the motor when starting the Wallas but turn it off after the stove ignites. No worries. Nor do I fret about the house battery voltage dropping below the recommended level - in fact I have my Garmin low-voltage alarm set for 11.8v and never worry about it until it beeps. The refrigerator and everything else I leave on when on board with the motor shut off will run all night and half the morning without draining the battery to the beeping Garmin point. It and all the other expensive stuff inside is OK down to 10v, so I never worry about it. The VSR combiner will protect the starting battery from draining, and even if it did I can always get the motor started. The kicker will bring the main battery up high enough to start the big motor in about ten minutes if I had to, but I never have. I replace the batteries after two years, and can even get 1/3 off the price by trading in the old batteries (3 yr. warranty and no questions from Costco). I have less money in my whole battery system than one of those Link10 gizmos costs (excepting the charger - but it came with the boat). And I never have a problem. Furthermore - I even use a low-tech inverter to run the TV and DVD, and the kids have it on most of the time. Never a problem. The only thing I am hurting with this is the batteries, and they are still strong when they are replaced after two years of their three year life. _________________ TyBoo Mike
Sold: 1987 22' Cruiser |
oldgrowth
Vessel Name: C-Voyager
Photos: C-Voyager
Posted: Wed Oct 25, 2006 12:15 am Post subject: |
Mike – I tend to agree with you. The C-Dory is a basic and simple boat. I believe when items are added to my boat, I do not want to complicate the task by trying to get the last 10% out of its usage by spending three to four times the money I would spend to get the first 90%. It just does not seem like a good return on my dollar. _________________ Dave
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
Posted: Wed Oct 25, 2006 9:25 am Post subject: |
Hey Mike, good thinking for a guy who is so low tech he keeps horses --- ostensibly for his grandkids, but Dodge Ram owners do need occasional backup protection ....
I had AGM batteries installed, ONLY because I hate battery acid. When it came to chargers I figgered the Bass Boat trolling motor guys were smarter than me about small boat chargers, so I picked up a Minn-Kota three stage two bank charger for under $100 bucks. Frankly, because of the length of time AGM's hold their charge when not in use and the bigger alternator on my Yamaha outboard, the charger's only been used twice in two years, other than the times I chose to run all my electronics while testing things in the driveway. When the AGM's go, I'll prolly switch back to flooded - only because I discovered the nice clean easy to use auto-fill system they sell for RV's. _________________ Mary & Don Anderson
Brat #483
"C-Brat" 1993 C-16 angler/50 hp |
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
Posted: Wed Oct 25, 2006 10:22 am Post subject: |
Long rambling post warning:
TyBoo wrote: | Mike -
The kicker will bring the main battery up high enough to start the big motor in about ten minutes if I had to, but I never have. I replace the batteries after two years, and can even get 1/3 off the price by trading in the old batteries (3 yr. warranty and no questions from Costco). I have less money in my whole battery system than one of those Link10 gizmos costs (excepting the charger - but it came with the boat). And I never have a problem. Furthermore - I even use a low-tech inverter to run the TV and DVD, and the kids have it on most of the time. Never a problem. The only thing I am hurting with this is the batteries, and they are still strong when they are replaced after two years of their three year life. |
So, you have a $1500 backup system in the form of a kicker?
The Honda manual implies I can pull start the 90. That should be
fun to try.
And you already have a charger...which is what I'm trying to buy.
I've boiled the water out of batteries a few too many times to be thrilled
with low tech chargers. The end result is having to replace the batteries.
Yes, under warrantee, usually. But, still, it's annoying. And the 22
is not self bailing, so it's nice if the batteries don't fail completely.
I doubt I will go to the extreme of a Link 10 battery monitor.
I don't like running the engines to charge. We often raft up, and it's
annoying to be swimming around someone running their engine for
one hour to charge their batteries. It can also be dangerous near
swim platforms and the like. I love the guys that run their engines
for 10 minutes to charge their batteries.
I like a small fridge not so much because it can hold drinks and the
weekend's food, but because it can hold all the stuff you want every
weekend but don't feel like bringing all the time (or forgetting to bring
as the case may be). Mustard, mayo, a few beers (cooler holds the
case!), a few bottles of water. And then
we used to put into the fridge meat and the like. So, very small needs.
We've been cruising on a 30' boat for many years and have a pretty
good idea of what our needs are. The neat thing about this boat
is that is it pretty much a "clean slate". The only major choice made
for me is motor and the GPS. I don't have an opinion on the Garmin
188C yet, and the Honda 90 seems great.
So, it's a matter of finding exactly the minimum size for everything
we want, keep it lite and functional. I'm willing to try inexpensive in
some cases, but shore power and related components just isn't one
of them. There are a few guys in our marina that run 15 amp
extension cords into their boat. Usually the cheapest possible, and
usually hanging in the water too. Don't fall in the water near their
boats...
We'll almost certainly use one of the inexpensive inverters, should
we want one. Depends, though. The last inexpensive
inverter I had would not start my variable speed sander. Not that
this matters, but it was odd. It wasn't a matter of output current
either as the sander drew much less power than the inverter could
produce. If I recall, my drill worked fine.
Windlass-I dunno. Would be nice, I guess. I hated the windlass on
the 30'. It didn't have a free fall, so dropping the anchor and
backing into a raftup was a painfully slow process. So, we usually
swam the anchor out, but then it's not power set. It's best to back
down on a Danforth when anchoring in Chesapeak Bay mud.
It was wired with 8 gauge and could not even come close to moving
the boat, so it was a rather pointless device. To make matters
worse, it corroded itself into place. When I sold the boat, I told
the owner it worked. Of course, it picked that time to fail, so I had
to take $700 off the selling price and help the new owner remove
it. We bashed the pully apart with a small sledge, and then cut the
rest of the pully and most of the shaft off with an angle grinder.
I could then hammer the remains down into the locker. Naturally, it
was installed with bolts between the pulpit and the deck, so we had
to remove the bow pulpit, too. Took two of us working for five hours
to get it out of there...
Mike |
Posted: Wed Oct 25, 2006 1:03 pm Post subject: |
In the middle of the night I was thinking about this thread--and agree 100% with TyBoo. I think that you are trying to make the 22 too complex a boat. Don't spend a lot of $$ on a fancy charger--for Dtol with a C Ranger 25--the Xantrex XC series makes a lot of sense. But with your anchoring out--it doesn't. How are you going to charge the batteries when anchored? Only option is some generator--and that is going to cost a bundle--and the noise and fumes which no one likes. The power factor of the XC series may require the larger Honda 2000 (I don't know what the requirement is--so you need to check on that). With our little group 24's on the C Dory 22 we would go 10 days to 2 weeks with no other charging than the outboard as we went from place to place--and some times we would stay at the same anchorage for several days. I did carry a U1 battery (garden tractor) which would start the engine if the others were run all of the way down--and had a small portable digital volt meter to occasionally check the battery voltage. Where would you put a battery in the bow of a 22---especially if you have 100 feet of chain? I think that our 22 had a windlass (appeared to be a bolt pattern which had been filled)--and it was taken off. We never saw a need for one. (Plus you never should try and pull the boat to the anchor with a windlass--use the engine, and the windlass to take up the slack).
I guess one of the negitives of down sizing is that we are used to some of the things we had in larger boats--but I look at it as having less systems to go wrong. |
mikeporterinmd
Photos: Shelly-IV
Posted: Thu Oct 26, 2006 11:50 am Post subject: |
Well, for one thing, the chain is leaving - well except for 6-8 feet. Unless we keep it for
ballast. I haven't checked the anchor locker extensively, but it seems relatively
large. I wouldn't put a grp 24 up there, though.
Will I put a windlass on? I don't know. Probably depends on if my wife gets
tired of pulling up the anchor. I doubt I will ever want to install one. Generator?
Really unlikely. I do have a small 1200 watt generator, but I can't imagine I'd put
it on the boat. Small 400watt inverter - definately. Need it to run the
blender. Of course I'll have a small DVM on board.
Fridge - I don't know. Check out the new Coleman cooler that uses a Sterling Cycle
engine. Appears to be new since there are almost no customer reviews I could
find. One downside is that the cooler is supposed to sit level. Is a boat on plane
level enough? Anyhow, if there is interest in discussing it, we could start a new
topic.
Fans: we have this little white fan with big blades and no cover. It was relatively
expensive, but we've had it for years, and it stores really small. Works well.
As for big bucks...well, the XC3012 was $345, I think. Its front can be remoted
and it comes with one temp sensor. So, unless you want to use one of the
really inexpensive chargers, it's not too pricey. It costs about $45 more than the
Xantrex 20+ with remote and temp sensor.
I want the remote display because: a) I want the the remote display
b) I want to mount the charger in some really out of the way location where it will be
hard to see. Perhaps up next to the Wallas, if there is room and not too much heat
from the Wallas. In other words, I want to use some piece of dead space that I
wouldn't normally be able to use for storage. Note that I went with the XC3012,
not the XC5012, which is much more expensive (30 amp vs. 50 amp). I would
have bought an XC2012, but there is no such thing.
Bob, thanks for thinking about this in the middle of the night
Mike |
mikeporterinmd
Photos: Shelly-IV
Posted: Thu Oct 26, 2006 11:58 am Post subject: |
thataway wrote: | (Plus you never should try and pull the boat to the anchor with a windlass--use the engine, and the windlass to take up the slack).
I knew that. I don't know why I wrote what I wrote. I was probably taken over
by my hatred for that miserable piece of machinery and not thinking. I hated
it for 10 years, and then just when I was about to be done with it, it cost me
$700 and five hours. But, I did get to bash it with a sledge hammer and
cut it into bits with an angle grinder, so that partially makes up for it. Yes,
as I am remembering beating it and cutting its guts out, I can feel my mind
clearing up. Ah. Thanks.
Mike |
Dora~Jean
Joined: 09 Mar 2004 Posts: 1507 City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
Posted: Thu Oct 26, 2006 10:45 pm Post subject: |
One comment on the windlass. I'm on boat #15, 7 sail, 8 power, all trailerable. Never had a windlass on any previous, always wanted to pull up the anchor by hand, seemed more 'nautical' or personal to just do it that way. That is until this boat. I used the same anchor I had on my last sailboat, a Delta 22 lb with 18 lbs of chain (28'), had no trouble pulling it up and letting it down for 6 years, and during the Bahamas trip, oftentimes multiple times each day.
After about 6 months of ownership on my CD25, the wind and waves came up while at anchor, we decided to move (about 15-20 kts of wind). I sent my son and daughter (14 and 20) up forward to retrieve the anchor while I moved the boat forward to take up the slack while keeping it pointed into the wind. Bad situation, C-Dorys have a great tendency to NOT want to track into the wind, especially moving less than 0.5 kts. Everytime the bow would fall off the wind my son had to quickly cinch up the anchor rode on the forward cleat and wait for the boat to swing back into the wind. This was a very dangerous situation for fingers, arms, everything. The windlass was purchased that next week.
This experience taught me that some boats are just better to have a windlass. I know the forces are greater on my 25 than say a 22, but the windage situation is about the same. I smile everytime I use my windlass. _________________ Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
+4 Previous, 1/2 sail, 1/2 power |
Posted: Fri Oct 27, 2006 3:35 pm Post subject: |
I am all in favor of windlasses in larger boats--and I suspect that my back problems come from pulling anchors in 25 thru 45 foot racing sailboats by hand. When we started cruising full time--we found a windlass was an essential--with a good set up, if the anchor didn't seem just right, or the boat wasn't in the best location--just up and move. I remember one night off Costa Rica we moved three times during the night as the wind shifted to get the best protection--not a bid deal with a good windlass. Mike, it sounds like your experience was the minority--or that for some reason you got a bad unit. If the factory supplied unit I have goes South, I'll buy a better one--but so far it seems to be working well. |
mikeporterinmd
Photos: Shelly-IV
Posted: Fri Oct 27, 2006 4:21 pm Post subject: |
Oh absolutely. I'm sure windlass's in general work well. Whoever made the unit
I ripped out was so embarassed with their effort, there was no manufacturor's
label. Or perhaps it fell off. Anyhow, it did not look like anything sold today.
Mike |
