Sticky Sliding Windows
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Tue Oct 24, 2006 12:38 am    Post subject: Reply with quote
Jeff, just lift up until the bottom edge clears the track, tilt out the bottom and down with the screen. Very simple and easy.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
PostPosted: Tue Oct 24, 2006 12:52 am    Post subject: Reply with quote
Another way to get the screens out is to run the Columbia River from Astoria to Warrenton in 30 knot winds with the occasional gust to 40 knots. They'll both be on the floor. The window tracks will be well washed, too. That was Saturday before last - the longest three miles of river I have seen yet.
I find I need to hit the outside of the tracks hard with a hose every once in a while to get the drain gizmos cleaned out. If they get plugged (as they easiily do), all the crud stays in the tracks and makes the problem worse.
Dora~Jean
Photos: Dora~Jean
PostPosted: Tue Oct 24, 2006 12:55 am    Post subject: Reply with quote
Geeze Mike, and I thought I had the only boat with 'automatic' screen removal mechanisms -- happened on this year's Delta trip with some very harsh 4-6 footers!
PostPosted: Tue Oct 24, 2006 12:58 am    Post subject: Reply with quote
Steve - I had to edit my last post to get something constuctive in there. Forgot about what I wanted to add to the discussion.
The cool thing about the beating up the boat is once you pick up everything from the floor, the boat doesn't know it was beat up.
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Tue Oct 24, 2006 8:13 am    Post subject: Reply with quote
what can be done about windows not opening they get stuck and locked in place is there some gasket or tubing that can be put in place to keep the window from locking ? also what is the name of the silicon or teflon spray and where do you buy it thanks
seahooked
City/Region: Redmond
Photos: SeaHooked
PostPosted: Tue Oct 24, 2006 12:51 pm    Post subject: Reply with quote
The Teflon Spray I used was: Multipurpose Dry Film PTFE Lubricant, 10-oz aerosol. From McMaster-Carr (industrial supply co in CA) (562) 692-5911 or order online. $5.48 plus shipping.
Chris Brown
Redmond, WA
2006 CD-25 Cruiser "SeaHooked" 2006-2012
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Sat Nov 18, 2006 10:42 pm    Post subject: Reply with quote
Screens?! I don't need no stinkin screens! Now tell me again, how do I get the window open?
MartyP
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Sun Nov 19, 2006 2:09 am    Post subject: Reply with quote
Push the window forward and hold it in the forward position while pressing the window release, then slide the window open. CoolSmile
Dave S.
"Sea Shift"
C-Brat #16
dotnmarty
Photos: Lizzie
PostPosted: Sun Nov 19, 2006 2:38 am    Post subject: Reply with quote
Dave-Thanks for the response, but I am pretty sure tht the latch is relased. Maybe it is debris, as mentioned above. I'll try some air pressure and the teflon stuff. By the way, on this little boat I have to push the window backward to release the latch then slide it forward. At least I think I do. Thanks again.
Jeff Brigner
State or Province: TN
Vessel Name: C-Pearl
Photos: C-Pearl
PostPosted: Mon Nov 20, 2006 1:12 am    Post subject: Reply with quote
seahooked wrote:
I can move them all back and forth with one hand (my wife and kids as well).
Be careful ! I thought you could go to jail for that !
Page generation time: 0.0487s (PHP: 54% - SQL: 46%) - SQL queries: 23 - GZIP disabled - Debug on
