New engine maintenance
robhwa
City/Region: Anderson Island
Vessel Name: Marcia C
Photos: Problemadela
PostPosted: Wed Jul 16, 2025 11:10 am    Post subject: Reply with quote
one more thing...if you take long trips, you'll want to change the oil with your boat on the water. An oil change pump can do this handily and you won't get any oil in the water. If the oil looks really good after removing it, I often don't worry about the filter for a cycle or two. Your new Honda100 (a fantastic motor IMHO) will let you know if your oil pressure isn't good, but not if the oil has deteriorated. If you haven't done this yet, you'll want to hook up and use the full host of engine information that the built-in NMEA provides. It'll even tell you mpg and estimated range if you put in your total gasoline volume when you fill up. It is truly amazing the difference in mpg at different speeds from trolling below hull speed to full throttle. Here is the link to the oil pump on Amazon...
https://www.amazon.com/6L-Extractor-Automotive-Extension-Bleeding/dp/B0DRVNNSRQ/ref=sr_1_1_sspa?crid=25M1N6VOGKX2L&dib=eyJ2IjoiMSJ9.Ch-kkbJh5XJuvaGOQqUPjtqbK0e9SDNjRAfGYp6c8To65DLIxARwu3mMyj40pX_mPPlUoCWid6uqa4MZEAhD9zYkERvIm6Sh2w6GyX-EI0p54lIPL8OMRbwZ2najW-V_XxKhxEDWgMETOgeubKPz2XYoOzHkeOHUgT1FGDAPyP9KanlmD0hpM0FSQGfgNf_EBeTSoJJeLsdzM6aJQFXgrUzvSYKRNmJ9HBZ64cxKbjCs9Sea4TxmWmq8iOaNJ07_zfyqxax-VTDw4Qb59rAW6eLat_Zt-0nOn1LO8llstgU.CJS6BlvNEsrsl36erupCaNROEpyEA0lwf9-6DVa9HqU&dib_tag=se&keywords=outboard+motor+oil+change+pump&qid=1752678171&sprefix=outboard+motor+oil+%2Caps%2C242&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
Rob Harrison & Marcia Ciol
Anderson Island, WA
2003 22 Cruiser "Mar-C"
Wood Zeppelin
C-Dory Year: 1997
Vessel Name: C-Creature
Photos: Childhood Dream
PostPosted: Wed Jul 16, 2025 2:17 pm    Post subject: Reply with quote
srbaum wrote:
WZ,
Lower unit oil change is the same as with your older engine. If the oil is milky in color, then the seal below the water pump and or the seals forward of the prop are bad. As to the gasket or o’ring on the two fasteners, it’s always best practice to replace them. I also always finish the job by using a handheld impact tool to finish tightening those fasteners.
Lastly always remove the prop each year, to lubricant the shaft with waterproof grease and to inspect the area between the prop’s thrust washer and the seal forward of it, for debris like fishing line.
Thank you! I wish they sold an "oil change kit" for this..
Current boats:
1988 16' Angler - "E-fishn-C"
Also:
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Wed Jul 16, 2025 2:49 pm    Post subject: Reply with quote
I'm not sure what type of gear oil and oil filter the 2021 BF100A takes. Does anyone know how to find this info for sure?
Boats.net says they need to serial# of my motor to be sure. I don't have that right now.
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Wed Jul 16, 2025 5:41 pm    Post subject: Reply with quote
Got the oil filter. But they won't say what gear oil to use, only that it's found in the SHOP manual, or from a Honda shop... Anyone know?
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Wed Jul 16, 2025 7:05 pm    Post subject: Reply with quote
Do yourself a favor and buy the pump attachment that screws onto the bottle. Most of those will have multiple threaded tips for all manufacturers and the Honda, too.
Found a maintenance kit for 90 HP. I would think it would work for 100 HP. Might want to give them a call to find out for sure. Do you have an owners manual? Found an online Honda owners manual and the specs are same for 90 HP as 100 HP.
https://www.boemarine.com/outboards/honda-marine/maintenance-kit.html
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
PostPosted: Wed Jul 16, 2025 7:27 pm    Post subject: Reply with quote
The lower case oil is easy. To empty remove the bottom plug then the top (less oil on your hands). Let the oil drain. Using a pump attachment on the gear oil bottle (commonly available, see example in link below) pump the gear oil into the drain hole until it just starts coming out the fill (top hole). Insert the plug in the top hole, then remove the fill hose and insert the drain (lower) plug.
I change the washer each time. The plugs get changed when the slot for removal tool gets too torn up.
https://www.amsoil.com/p/amsoil-marine-gear-lube-pump-g3456/
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Thu Jul 17, 2025 3:18 am    Post subject: Reply with quote
Salmon Fisher,
yes, thanks for the reminder! I've used one of those before.
Been out fishing lately?
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Thu Jul 17, 2025 3:51 am    Post subject: Reply with quote
Yes, thanks.. It IS easy! Problem I've having is that the owners manual does not give a SPEC for the gear oil. 90W or 75W90? GL-4 or GL-5 (apparently GL-5 is bad for gearboxes with yellow metals in them)... Just not sure what to use!
PostPosted: Thu Jul 17, 2025 10:54 am    Post subject: Reply with quote
Online BF100A owners manual says "API Standard (GL-4) SAE 90 Hypoid gear oil"
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Thu Jul 17, 2025 4:37 pm    Post subject: Reply with quote
Yes, and my 2006 Honda outboard says GL-4 OR GL5. So it would seem that a 2021 specifying GL-4 would be for a reason.(?) the "internet" says GL-5 can be "corrosive to soft metals such as brass and bronze". There's no brass or bronze in there, but isn't the entire casing made of aluminum (soft metal)!?
Problem is I can't find any GL-4 that is also 90W "marine"... Confusing!
Anyone?
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Thu Jul 17, 2025 4:42 pm    Post subject: Reply with quote
srbaum wrote:
WZ,
I work on all makes of outboards as a hobby and have done this for years, I also provide local outboard training. My go to 99% of the time for parts is boats.net easy to work with, they have real people to speak with, they take returns and they can get my my parts quickly if I need them.
Hi Steve, I'd be curious of your input on my above inquiry about the Gear Oil (see above).. Why is my 2021 BF100A specifying only GL-4, and then the Honda gear oil they sell is GL-4 & GL-5 (Honda part# 08739-90W). The internet is saying GL-4 is a specific type and not just "superceded" by GL-5...
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Fri Jul 18, 2025 10:29 pm    Post subject: Reply with quote
Looks like I need a shop manual just to do routine maintenance items. Anyone know where to get one!?
robhwa
PostPosted: Sat Jul 19, 2025 9:50 am    Post subject: Reply with quote
I find the shop manuals to be hard to follow until I already know the procedure. You can find some good Youtubes that show better how to 1) change oil, 2) replace lower unit lube, and particularly, 3) flush cooling system, and particularly 4) replace the impeller.
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Sat Jul 19, 2025 1:21 pm    Post subject: Reply with quote
Thanks Robhwa,
Good Point!
BTW, i did a south sound cruise a few years ago and camped at the Eagle Island marine park. Great area you're in!
robhwa
PostPosted: Sat Jul 19, 2025 5:32 pm    Post subject: Reply with quote
Thanks Robhwa,
Good Point!
A great place. If you catch the pass between McNeil and Anderson at Eagle at low tide, about 50 seals will be on the shoal there. We've had a lot of Biggs orcas here lately, and the seals are very nervous.
Page 2 of 3
Page generation time: 0.0337s (PHP: 78% - SQL: 22%) - SQL queries: 32 - GZIP disabled - Debug on
