Lithium Conversion
PostPosted: Fri Apr 11, 2025 2:33 pm    Post subject: Reply with quote
kennharriet wrote:
That makes sense thank you. I read where some of the dc-dc chargers sense the alternator being on eliminating the need for a wire.
Depends on whether you have a "smart" alternator or not.
A dumb alternator is easy to detect from the bus voltage. A smart alternator has variable output depending on the load (this is to increase fuel economy). With a smart alternator, you have to "tell" the charger that it the engine is on.
PostPosted: Fri Apr 11, 2025 2:45 pm    Post subject: Reply with quote
If you take the "Best" to the next level, then why not use Battleborn or one of several batteries which are better built and marketed to the marine trade? Yes they are about 4x the cost of the "LiTime". I have the "LiTime" in my large home system, but on the boat, I used what battery seemed ot be the best at the time. The BB are more robust, and there is an electrical engineer available to talk to if there are questions. (He also facilitated my direct contact with engineers at Victron.). Our boat batteries can take a real beating if we get into heavy seas.
Something like 98% of the lithium batteries sold are manufactured in China. The difference between a US manufactured battery and a Chinese battery may be in the assembly of the component parts and the case. I think you'd have a hard case saying that all US batteries are better than all Chinese batteries.
freedomvango
City/Region: Jacksonville
PostPosted: Fri Apr 11, 2025 3:05 pm    Post subject: Reply with quote
totally correct
there's tons of ways to do it from "old school" that people swear by,, all the way to current tech.
Do what you'd like, but more data is always better than less data. Ill pay more for knowledge of what my system is doing any day
-Grant
Freedomvango
ABYC Electrician
2022 Ranger R23
shad
Vessel Name: C-Squatch
Photos: C-Squatch
PostPosted: Fri Apr 11, 2025 4:01 pm    Post subject: Reply with quote
The Victron Orion-Tr Smart DC-DC and XS chargers have engine auto-detection and Bluetooth. For what it's worth, engine detection and charging works fine with my old 2014 Evinrude E-Tec 90 and Tohatsu 9.8 kicker. The chargers have the option of connecting an ignition switch wire if the auto detection is not sufficient. When a 120V Victron Blue Smart IP65 Charger is connected to the lead acid battery, the DC-to-DC charger automatically turns on and can charge the lithium battery, too.
The cheaper non-Smart Victron units DO NOT have Bluetooth or engine auto-detection, so a manual switch or wiring to the ignition circuit will be required. Monitoring will require extra components.
An important distinction if evaluating the Victron ecosystem.
kennharriet
City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Sat Apr 12, 2025 10:08 am    Post subject: Reply with quote
Sure appreciate all of the experienced wisdom from the group. I ended up ordering the Renogy 20amp non MPPT dc-dc charger (50% of BF90D alternator output of 44 amps). I also ordered two 100ah Renogy Core mini Li batteries, mostly because of their small size and fit in the lazerette. My planned layout is AWG 4 ga wire from the motor to an 85 ah Vmax AGM located in the port lazerette. Then 8 ga wire from the AGM through a 30 amp ANL fuse to the dc-dc charger in the starboard lazerette. From the charger through a 40 amp ANL fuse to the Li batteries also in the starboard lazerette. 200w of solar will also feed the Li batteries through a 40w MPPT charger and 50 amp ANL fuse. The house load will be fed through a 60 amp breaker to a new Blue Seas distribution panel and fuse panel. Everything is marine tinned wire and connectors. Per Bobs earlier advice the windless is on the house battery. I like he simplicity of this set-up. I removed the Yardina Combiner used in the previous system.
Does anyone see any holes in this setup? Looking forward to three months on the water starting in Skagway May 18, with our heads full of stories from Jay and Jolee. Thanks again for the discussion, Ken
shad
Photos: C-Squatch
PostPosted: Sat Apr 12, 2025 11:44 am    Post subject: Reply with quote
Not a hole, assuming I am looking at the correct Renogy DC-to-DC charger docs, but I would use 8AWG and 40A fuses for input and output of the charger. That way you only need one spare fuse size and wire size for the charger. 8AWG should be over-sized for the 20A load and distance between the lazarettes, so you should be good.
The lithium and lead negatives can usually be tied together for a non-isolated circuit on our boats. Non-isolated will save you from running an additional heavy gauge negative wire between the lazarettes. My setup has a negative bus bar in each lazarette with a single port-to-starboard 4AWG negative wire connecting the two batteries. Batteries with 4AWG to respective bus bars. Motors, house panel, dc-to-dc charger, and other accessories attached to the closest negative bus bar using appropriate wire gauge.
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Sat Apr 12, 2025 1:46 pm    Post subject: Reply with quote
Great points Shad! I’ll incorporate your suggestions. 🙂. I will need to make a custom battery tray for the group 22F lithiums as I don’t see anything commercially available that small.
robhwa
City/Region: Anderson Island
Vessel Name: Marcia C
Photos: Problemadela
PostPosted: Mon Apr 14, 2025 1:22 am    Post subject: Reply with quote
Depending on your usage and need for charging from the alternator, it seems a shame to only get 20A from the alternator. If you look back at my configuration with the 50A (max) charger, you can set the DC/DC charging between 10-50A in 10A increments. Mine is currently set to 40A and it shows no sign of overheating. I earlier set it to 30A and then, with experience, upped it to 40A, nearly the Honda 44A output. The setup with the single DC/DC MPPT unit saves a little money and simplifies wiring a bit. You would also only need to buy one BT2 if you want to monitor charging with a smart phone (a nice touch). The only downside I can see is that if there is enough sun for solar charging, my system won't also charge from the alternator, but that hasn't been a problem that I can see. I have a switch to cut off solar when motoring. With your configuration, I guess you could possible get 60A total charging (40A from solar plus 20A from alternator) when you are running on a sunny day. The downside is that it doesn't appear that your system will use your solar panels to keep your charging battery charged when the boat is sitting unused. You should always run your motor when using the windlass, and mine works fine from the house batteries. I also often use the house batteries to run a bow-mounted trolling motor, which is a heavy load on the batteries when trolling.
Rob Harrison & Marcia Ciol
Anderson Island, WA
2003 22 Cruiser "Mar-C"
PostPosted: Mon Apr 14, 2025 1:39 pm    Post subject: Reply with quote
Are you monitoring the output of the DC to DC charger amps as it runs through out the voyage? Does it remain at 40 amps? I set mine to 30 amps with the 44 amp outputs. You most likely have a carburetor Honda 90. The more recent fuel injected outboards require a fair amount of current for the EMC: up to 18 amps.
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Mon Apr 14, 2025 2:38 pm    Post subject: Reply with quote
Thanks Rob and Bob. My newer Honda BF90D is fuel injected with 44amp output. Everything I read suggested the dc-dc charger should be rated not more and preferably less than 50% of the alternator output. I may have errored on the side of caution and ordered the 20 amp non MPPT unit. I will have the BT2 for remote monitoring. When motoring, the Alaska series dingy will be on the roof and cover the 200w solar panel. It is true that I will not be able to maintain the start battery with solar but then its only load is motor starting when it is immediately getting charged by the alternator. Worse case scenario the Honda 90 can be started with a pull rope which I have practiced just in case. After this season if not adequate, I may want to upgrade to the MPPT dc-dc charger. I’ll report after I’ve used the system.
Thanks again for the great advice. Interesting stuff. I’m enjoying learning from you all. Good thing I made a living as a wildland firefighter rather than a marine electrical engineer. 😂
PostPosted: Mon Apr 14, 2025 3:00 pm    Post subject: Reply with quote
It will be interesting to see to what the actual output is. With the magneto type of "alternator" it should not overhead, as a belted alternator may. Let us know how it works out!~!!
Punkin Drublic
City/Region: Port Alberni
PostPosted: Mon Apr 14, 2025 7:12 pm    Post subject: Reply with quote
I may be "technically" over fusing the circuits--but there is a relatively huge amount of current and a short could cause a fire in very short order. Anything going into or out of the LiFePO4 battery is fused within a few inches of the battery. Same for current going from DC To DC charger off the engine--with a fuse before the wire run to the Li battery.
Saw the title post and came here to say something to this effect. It is not over fussing/fusing. I would strongly suggest fuses directly the battery posts.
Personal favourite style, cube/block fuses. Compact.
https://a.co/d/7YDVYCB
Adequate if line side (between battery and this holder) cabling is short and larger than required AWG.
https://a.co/d/2iRK9Dr
If your batteries only have lead posts I'd suggest this for bolting cube fuse holder. Example
https://www.canadiantire.ca/en/pdp/motomaster-marine-battery-terminal-lead-0113508p.html?gclsrc=aw.ds&gad_source=1&gbraid=0AAAAADojZpgvdo7g-IwehF98BSuk8n8SW&gclid=CjwKCAjw5PK_BhBBEiwAL7GTPVqjTmrohJSWCyNLhR-TepNhTbPiLoeb8irmYHVIIK4-QsEJTtpwyBoCr2YQAvD_BwE#store=488
With these, loose pinch bolt so clamp will spread. Gently tap down so clamp is below top of post. Then tighten pinch bolt. Check threaded bolt size matches fuse holder/cable lug hole size.
https://a.co/d/2RIXfL0
Handy for small, emergency, direct to battery cct's. Bilge, lights, sensors, gas detection and what have you.
Liquid electrical tape is nice for covering/sealing terminations. Removes easier than nailpolish.
Information sheet (see temp ratings)
https://www.permatex.com/wp-content/uploads/tds/85120.pdf
Hope this is helpful to some. Stored energy in these batteries is serious business. For reference I'm an electrician, I work in mining in locations that utilize salt to keep drill water from freezing. Salt concentrations can be as high as 15%, fat higher salinity than any ocean.
2017 Weldcraft Rebel 188 - Skeleton Crew
robhwa
PostPosted: Fri Apr 18, 2025 7:05 pm    Post subject: Reply with quote
Bob had asked what kind of output I actually see (I read that as amps from the alternator) from the nearly-new Honda BF100, and Ken had cautioned that conventional wisdom is that you shouldn't use a DC/DC rated or set to more than 50% of rated outboard output, which I have greatly exceeded at 40A for my BF100. Since the outboard charging system isn't a belted alternator I thought temperature wouldn't be as much of a problem as with a conventional alternator...maybe a mistake. I'm currently fishing in Brazil, but will put a shunt on my alternator side when I get back to test output. I'll also test the system charging depleted batteries and monitor temperature with my Flir. Normally, you connect a DC/DC between the starting and house batteries, as I have, so alternator output might be "filtered" a bit by the starting batteries resistance (it is standard Pb-acid). I'll put the shunt on the other side to see, and see if I can get temperatures high enough to be concerned. I don't want to dial back (via reduce the DC/DC setting) the potential charging from the engine if I don't have to. I want all of the charging I can get. Ken; I was a forestry professor for almost 40 years, and greatly appreciate the firefighter community. I wish you luck in the future.
Page generation time: 0.044s (PHP: 74% - SQL: 26%) - SQL queries: 26 - GZIP disabled - Debug on
