Repower Time
cdoryfan
City/Region: New England
State or Province: RI
Photos: cdoryfan
PostPosted: Sat May 18, 2024 12:17 pm    Post subject: Reply with quote
Interesting discussion. Regarding the weight my boat has all chain and a windless (and I increased the anchor size to a 14lbs) so maybe this will improve balance.
Dropped off the boat today for the repower so we'll see how it goes! The dealer was really excited to look at the c-dory, they are pretty rare in New England.
The only thing is I have one more week to change engine order as they de-rig current engine and the 140 is only marginally more money. I know it's not necessary but as it's the same engine block, a part of me is intrigued. We shall see however!
PostPosted: Sat May 18, 2024 12:37 pm    Post subject: Reply with quote
I understand the idea of 30 more HP for a few hundred dollars. But I would advise against it. You get that higher HP at the top end of RPM's, The 115 will take the boat right up to its stability max speed. The boats do not run as well over 30 mph. It depends of the trim and conditions.
One of the eastern dealers equipped the boats with 50 or 100 feet of chain, to give more weight in the boat, making up for more weight on the stern. Fine until you get caught going down wind/seas, and the boat's bow not rising as promptly and tending to broach. I much prefer to use trim tabs, and the foil. Yes both are "bandaids". The foils give more versatility, and the ability to run into a head sea/chop with an improved ride.
cdoryfan
Photos: cdoryfan
PostPosted: Sat May 18, 2024 3:22 pm    Post subject: Reply with quote
Thataway, I hear you on the 115 vs 140, it's just so hard to say no to more HP, even thought I understand I'll never use it. The only other consideration is I think the 140 has a better oil cooler which sounds like more reliability to me, but really I'm just looking for excuses for a 140... probably going to stick with 115.
I just installed new trim tabs, so I'm hoping I can avoid the permatrim for now. The idea of so much chain does seem crazy for me (I have something like 75 feet), but I came from a sailing (racing) background where any chain over necessary was considered a capital offense.
PostPosted: Sat May 18, 2024 7:28 pm    Post subject: Reply with quote
Also racing sailboat background, and any weight in the ends of the boat is no-no. With my cruising. sailboats boats that was violated often. 200 feet of chain, heavy anchors, Dinghy on davits or on deck like a purse seiner.
With the C Dory I also like to keep the bow light--I tried several boats (22, 25 and TC 255) The first two without trim tabs, then trim tabs, and trim tabs with Permatrims....conclusion--both. The Tom Cat 255 was a different story. of course no trim tabs, but the permatrims did not give me that much a lower planing speed, which was my goal.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Mon May 20, 2024 10:11 am    Post subject: Reply with quote
While I have no personal experience with the particular 140 hp outboard on the back of a 22, in looking at all the specs and the fuel burn data, it looks like a better choice than the 115 to me. And I suspect, if the prop size is dialed in correctly to utilize all of the power available up to about 30 ish mph, it will perform a tad bit better than the 115. But with all that said, other posters are correct that the difference may not be actually noticeable for the average user. I personally think the only time you'd be able to tell is with a very heavily loaded boat. With the correct prop, it should be able to move a heavier load at a faster speed than the 115.
cdoryfan
Photos: cdoryfan
PostPosted: Tue May 21, 2024 3:12 pm    Post subject: Reply with quote
So my final final answer after much hemming and hawing... I am going to stick with the 115.
While, I believe (apart from the marginal upfront cost) there is no material benefit to get the smaller engine, and I think the 140 would be better. I know the difference would be negligible, and many smarter folks than I are advocating the 115.
A few other things influenced my decision
1) Resale: it seems like the community prefers the 115, and that matters to me
2) when I asked the folks at the dealer, everyone said they liked the 115 hp more. When I asked why, the response was (paraphrasing) "I don't know, I just really like that engine". I put a lot of stock in that gut feeling by a pro and that was a bit of a clincher.
3) Safety: There is a non-zero chance friends and family will borrow boat, I don't want to have a safety discussion of how much throttle is too much.
There is a final point which is my wife told me to get the 115... so I guess the other points are actually erroneous.
cdoryfan
Photos: cdoryfan
PostPosted: Mon Jun 10, 2024 2:05 pm    Post subject: Reply with quote
UPDATE: Repower is now complete - ended up with a (white) Suzuki 115. I'm on hour 6 of the break in period so have only gotten to just south of 5k RPM and haven't gone full throttle. Speed at that rpm topped out at 21-23knots on GPS (it was a windy day with current). I suspect I'll be able to go in the high 20s flat out but not sure. If not I guess I'll adjust the prop from it's current 19. I also got hydraulic steering fitted.
I know folks will be curious and I hesitate to say but logically can't think why it isn't okay to share... All in, repower was just about $15k. In rough numbers, $11k for outboard, $500 for control, $1.5k for the steering and $2k in labor (~14 hours). The install genuinely looks like it came out of the factory and the shop filled the old holes with West Systems epoxy / seemed to do everything right.
Should note that I got a trade in for old engine, but really not much as I had totally messed the thing up. This new engine will be dealer serviced!
Thanks for everyone's input. This was a big deal to me - a lot of money and I didn't want to make the wrong choice!
The remaining question is if I extend the warranty from what it currently is (5 years) to 8 years.
PostPosted: Mon Jun 10, 2024 2:54 pm    Post subject: Reply with quote
Congratulations--and you have added $15K to the boat's value. I would expect close to 30 mph (or 26 Nautical miles an hour.)
T.R. Bauer
PostPosted: Mon Jun 10, 2024 5:22 pm    Post subject: Reply with quote
I think you're going to love it. And why not post how much the repower costs? I've never understood why it had to be a secret. I think you got a fair deal, and quite possibly a great deal as I have heard 20k being the going rate up here. I still say there's a lot to like about the 140 as well. But, I also stand by the average user will not likely utilize the extra hp. Now, go out and enjoy that thing. I'm excited for you!
cdoryfan
Photos: cdoryfan
PostPosted: Tue Jun 11, 2024 8:48 am    Post subject: Reply with quote
I too have never understood the secrecy around prices, but there ya go. As I got a bunch of different quotes, I feel comfortable with the cost. This place was thousands cheaper than anything else I could find, I really can't say enough good things about how they were to work with and the quality of the install.
For those in New England area, it's called Stateline Boatworks in Warren RI. They do Tohatsu, Honda and Suzuki. It's funny as a Yamaha dealer is next door (Warren / Bristol RI is a boatbuilding town, very cool cutting-edge boatbuilding happening around there - especially if you are into super high-end sailboats/ America's Cup type stuff).
Both dealers had been recommended to me as doing a very good job, but I found the folks at Stateline so easy to deal with and the price so good it made the choice easy for me (this is nothing against the Yamaha dealer, again, I hear good things about their work too).
cdoryfan
Photos: cdoryfan
PostPosted: Mon Jun 17, 2024 4:19 pm    Post subject: Reply with quote
Have taken a few trips on the boat now, including an overnight with my family to Cuttyhunk, MA (tiny island that is about a 33 mile trip for us each way).
Love the engine, we cruise at 23 knots if it's flat and 17 knots in the ocean on a fairly calm day with a little chop and some swell (realllly long period though so kinda dipped in and out on the little boat).
After the break in I was able to push her. Loaded with three people, stuff (but we pack light), a dinghy with outboard, water and 60% fuel I was able to hit 30 knots (34 mph). I won't lie though, wondering what a 140hp would do Smile.
Initial impressions of the boat (and c-dory 22 cruisers in general) Boat is very cool, a lot of livability in a really small package, and I can actually afford to fuel it. Also, I feel I use all 115 hp, and the hydraulic steering is a borderline must have.
I would say however, compared to a heavier built boat like a downeast type thing we see alot of around here, it's pretty uncomfortable in the open ocean at anything over 14 knots boatspeed.
Final thought (unrelated), I HATE the wallas stove/heater thing, sometimes it works, but not very fast, and I feel like it has its own personality. It's gotta/gonna go. Final, final thought, who the heck needs non-skid that grippy? I think I'm going to have to use kneepads to get the mooring... I'm not that old!
If those are my gripes though, this boat is pretty awesome and I'm a very happy customer.
WCF
City/Region: Central
PostPosted: Mon Jun 17, 2024 9:59 pm    Post subject: Reply with quote
From the numbers shared elsewhere almost no difference in top speed for the 115 vs 140 given the same conditions/similar propping. 34 MPH is the highest number I see anyone consistently report.
PostPosted: Mon Jun 17, 2024 10:22 pm    Post subject: Reply with quote
I doubt that you will find many conditions where any more than 30 knots is a safe speed for the C Dory 22. They begin to be a little "squirrelly" at over 30 knots. I know of one boat which put 150 on the transom, and was sorry afterward (The 150 weight is more than the 115/140 Suzuki.)
The non skid is a standard pattern found on many boats. There are some which are more aggressive. No problem for me, and I will be 88 in a couple of months.
The Wallas stove, if in good condition and all of the instructions are followed works well. It is a compromise, as many items are in 22 foot cruising boats. I have had one in all of our boats except the last 25, where we did induction burner cooking. Much cooler in Florida.
Enjoy the new motor, and it sounds as if you are getting a lot of boating in since it has been installed.
cdoryfan
Photos: cdoryfan
PostPosted: Tue Jun 18, 2024 8:42 am    Post subject: Reply with quote
I was kinda joking about the 140, I’m very happy with the 115 but on a zero wind and no wake day, the boat felt like she would do 30 knots happily, I don’t want to run at wide open throttle though so will only rarely do it.
Regarding the wallas stove. I moved from a complicated sailboat with many systems to a c-dory because of the simplicity . The wallas strikes me as anything but, and against the entire ethos of the boat. I’m afraid I just don’t get it - also the thing being 3k blows my mind. But to each their own and I understand the appeal in general… it’s nice to be comfy.
All in all though, the boat is fantastic and I can’t think of anything I’d rather own/operate. I get why they are so popular and have a loyal following and am proud to be an owner.
PostPosted: Tue Jun 18, 2024 1:17 pm    Post subject: Reply with quote
My 22 will do over 30 mph on a 90hp motor when light. This is only for flat water and straight lines. Getting into the mid-30s on the 22 is playing with fire IMO.
Page 2 of 3
Page generation time: 0.0509s (PHP: 68% - SQL: 32%) - SQL queries: 32 - GZIP disabled - Debug on
