Single Axle Trailers
letitride
City/Region: San Jose
Vessel Name: No Limits
Photos: Letitride
PostPosted: Wed Nov 01, 2023 9:08 pm    Post subject: Reply with quote
Here in sunny california our freeways are so bad that towing with a single axel is just painfully bumpy for both the tow rig and boat, it can be done but a dual axel heavy trailer rides so much nicer Very Happy
Karl Konecny
City/Region: Glide
Vessel Name: Nowhere Fast
Photos: Nowhere Fast
PostPosted: Thu Nov 02, 2023 11:58 am    Post subject: Reply with quote
Since aluminum trailers were brought up, I have a question about them. Does anyone mount anodes on them to counteract potential corrosion near the steel axel?
PostPosted: Thu Nov 02, 2023 2:15 pm    Post subject: Reply with quote
Not sure how anodes would help. Trailers are not usually in the water long enough for much corrosion prevention to occur. You can argue that there might be some dissimilar metal corrosion to occur when the Al touches the steel, but if that were actually a big deal, the trailer manufacturers would already have done something about it.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Thu Nov 02, 2023 2:41 pm    Post subject: Reply with quote
Most if not all of the hardware has nylon washers/spacers to help prevent galvanic corrosion between the steel hardware and the aluminum superstructure on the better quality trailers I have seen and worked on. I don't think putting an anode on a steel axle would help with corrosion as they were designed to work in the water and not the atmosphere. I have seen rusted axles that had to be replaced, but they were well over 20 years old and the trailers were at the end of the lifespan anyway.
Page generation time: 0.0273s (PHP: 59% - SQL: 41%) - SQL queries: 21 - GZIP disabled - Debug on
