Flashyfish
C-Dory Model: 19 Angler
Vessel Name: Kraken
Posted: Sun May 21, 2023 10:58 am Post subject: |
The smooth factory crimped fuel hose bands are called an Otiker clamp. You need the bands and crimping tool to do it right. The stainless bands I referenced use a 7mm socket or flathead screwdriver to tighten. Nice clean installation and no leaks or corrosion. |
ThumbsUp
State or Province: NV
Vessel Name: Thumbs Up
Photos: Thumbs Up
Posted: Sun May 21, 2023 6:24 pm Post subject: |
Ordered two 10 packs of high quality 13-15mm 304 stainless fuel clamps on Amazon. West Marine fuel clamps are going back, they cut the fuel jacket. Thank you Flashyfish and Almas! Project is coming together
Mark |
tsturm
Joined: 01 Nov 2003 Posts: 1165 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Sun May 21, 2023 9:48 pm Post subject: |
ThumbsUp wrote: | Ordered two 10 packs of high quality 13-15mm 304 stainless fuel clamps on Amazon. West Marine fuel clamps are going back, they cut the fuel jacket. Thank you Flashyfish and Almas! Project is coming together
Mark |
Don't over tighten them  |
ThumbsUp
Photos: Thumbs Up
Posted: Sun May 21, 2023 10:39 pm Post subject: |
Tsturm, good point - hard to know when to stop cranking. Running new fuel lines and using Oetiker clamps.
Great shots in your photo album! I noticed you mounted the water/fuel separator on the stbd side splash well, above fuel tanks. Did you remove anti-siphon valves? My water/fuel separator is located down low, between the tanks. If i remove ASV's from fuel pickups, need to move separator above fuel tanks. |
ThumbsUp
Photos: Thumbs Up
Posted: Wed May 24, 2023 1:35 pm Post subject: |
Broken fuel pickups. I used penetrating oil for several days on the starboard fuel pickup removal and it was still a bear to remove and threads are damaged. Can the tank be salvaged or would it be best to install new tanks? |
ThumbsUp
Photos: Thumbs Up
Posted: Wed May 24, 2023 2:33 pm Post subject: |
It was suggested to me that I could chase threads out with a tap becuase there is still plenty of thread left. New tanks are $450 so I am highly motivated to reapair damaged threads. |
Flashyfish
Vessel Name: Kraken
Posted: Wed May 24, 2023 9:30 pm Post subject: |
Unless there are spider cracks in the plastic fuel tank around the aluminum bung fitting, I would chase the threads.
There is no pressure involved at the point the fuel pick up screws into the tank, so it should seal just fine.
Put a little thread sealant on to help keep the threads from seizing. |
ThumbsUp
Photos: Thumbs Up
Posted: Sat May 27, 2023 1:14 am Post subject: |
No spider cracks and the threads cleaned up nicely. I am relieved because replacing both tanks is expensive and I'm not sure they still make the 25 gallon tanks.
