1st use of composting toilet. Not sure I'll keep it.
Post new topic   Reply to topic    The C-Brats Forum Index -> Wastewater Systems
PostPosted: Wed Mar 29, 2023 6:08 pm    Post subject: Reply with quote
We deleted the standard marine head in 2005 prior to Daydream's build for a credit and installed an Airhead ourselves. We are so glad we did!
As Dr. Bob said, commercially available composting toilets have, or should have, a handle on the outside that rotates the bars inside to mix the poop and the medium after each use. We used cocoanut coir for the medium. It is important to slightly dampen the medium at the start, but never to let it get very wet - that is why they have separate solids and liquid receptacles!
We chose not to put TP in the solids container but you can, it is just slower to decompose. The exhaust fan is an ordinary 12 volt computer fan that runs all the time. I carried a spare fan since it is essential to have air flow but I did not need to replace it. The fan vents to the outside and the Airhead is basically odor-free in operation.
As Patty said, we bagged the solids up only four times over 8 months on the Loop and disposed of it in dumpsters. The liquid tank got carried up to a toilet at marinas or dumped overboard in deep water.
We really cannot think of a single reason NOT to have a composting toilet.
Avidmagnum12
City/Region: Ocklawaha
C-Dory Year: 2011
Vessel Name: C-Otter
Photos: C-Otter
PostPosted: Thu Mar 30, 2023 8:48 am    Post subject: Reply with quote
What brand of composing toilet do you have? I do not know of any that do not have a way of turning the solids. I have an airhead but have also used a natures way and a c-head. They all work well and I’d never go back to using a holding tank toilet again. We’ve had our airhead for over 6 years now and have had no issues with it. There can be a learning curve with the main problem being too much moisture in the material where the solids collect.
I have not heard of anyone removing a Airhead……yet.
Tom and Joyce Schulke
PostPosted: Thu Mar 30, 2023 3:20 pm    Post subject: Reply with quote
I wonder, does a composting toilet count as a permanent toilet for Ontario, Canada? Apparently a porta-potti does not.
However, since you don't need a pump out or plumbing for a composting toilet, is it a permanent installation?
This is not a question about the toilet itself (you can argue it either way), but how the Ontario legal system identifies it.
robhwa
City/Region: Anderson Island
Vessel Name: Marcia C
Photos: Problemadela
PostPosted: Thu Mar 30, 2023 4:19 pm    Post subject: Reply with quote
From what I have researched (this trip is in my plans, too), they will be looking for a deck fitting for pumping out. Since composting toilets don’t have them, then the answer from the refs is “no”, composting toilets are not legal in Ontario.
Has anyone encountered a different result?
https://www.ontario.ca/laws/regulation/900343
PostPosted: Thu Mar 30, 2023 5:05 pm    Post subject: Reply with quote
There is another issue. In Ontario you cannot have alcohol on boats that do not have a permanent sleeping area + permanent cooking facilities + permanent toilet facilities. For instance, a CD22 does not qualify for having alcohol on board because it typically only has 2 out of the 3 things. Apparently, the first offense is a $500-600 fine.
serpa4
City/Region: Melbourne
C-Dory Year: 2018
Vessel Name: DayLo
Photos: DayLo
PostPosted: Thu Mar 30, 2023 8:30 pm    Post subject: Reply with quote
Found the label today: Separett AB Model 7010. Its just a pee separating toilet. Poop in a bucket, pee overboard. Not a composing one. The PO had been putting coconut in it I guess. Not sure how he stired it though.
I'm going back to the factory holding tank head. 9 gallon, with macerator overboard discharge.
I exclussively boat in the ocean. Dumping 3 miles off shore is completely legal and at 25mph, just a few minutes out. Closer and easier than any dump station. I'll convert it to saltwater flush vice fresh and call it good.
It's about 1qt per flush, so I guess 3 times per day x 2 adults = 1.5 gallons per day + maybe 1.5 gallons a day of physical solids/pee. I'd go offshore every 3 days. I can easly deal with that. Besides, I have it. Buying a composting toilet is like $1,000 and this one only needs a missing macerator. All the plumbing and overboard ball valves, etc are in place.
2018 C-Dory Venture 26. Suzuki DF200A,autopilot, solar, 412ahr of lithium.
PostPosted: Thu Mar 30, 2023 10:49 pm    Post subject: Reply with quote
I am not sure if you are going to convert the original head/tank to salt or raw water. I would strongly advise against this, because of potential corrosion issues. You would also have to have a thru hull intake, and pump. I am not sure if a raw water wash down system could be adopted--but most likely that is possible.
serpa4
C-Dory Year: 2018
Vessel Name: DayLo
Photos: DayLo
PostPosted: Fri Mar 31, 2023 6:28 am    Post subject: Reply with quote
Yes I'll be tapping into the raw water system since it's already has a through hole and a screen and a pump for salt water. I'll simply tee into the line and run it into the bathroom as opposed to fresh water. I've had several Marine saltwater toilets.
PostPosted: Fri Mar 31, 2023 9:57 am    Post subject: Reply with quote
Having had marine toilets that use salt water and the RV-type toilet in the CD-25, I would have to recommend against using salt water. The smell that typical marine heads get is due to the critters in the salt water dying in the lines. With the fresh water flush and use of RV holding tank solution, you don't get that smell. You can put a ball valve in the toilet fresh water feed line and greatly control your use of fresh water.
We found we could generally get 5 to 7 days between pump-outs when spending extended time on the boat.
As far as the airheads, I have never used one, but I have been "downwind" of a close dock neighbor who did. Maybe it didn't stink in his boat, but is sure drifted our way. I gave him a hand one day getting a dinghy down, which put me right at the vent... yep, that's where that smell is coming from. I'd take the RV type with fresh water rinse every time.
PostPosted: Fri Mar 31, 2023 3:29 pm    Post subject: Reply with quote
. I have had more than "several" salt water heads--all except the C Dory Sea Land Traveler with the 9 gallon tank, have been salt water--electric or manual. Some boats had 2 marine heads, and these all are much different that the ones which come with the C Dorys.
As to Jame's comment---the composting head with a "odor" was not properly maintained or rigged. Unless a mistake is made there is no odor-a little urine mixed in or the base material too wet= smell. I looked into this very thoroughly before buying a boat with a composing head.
robhwa
PostPosted: Fri Mar 31, 2023 4:15 pm    Post subject: Reply with quote
For my camper and CD22, I initially thought I would need to rig up a powered vent (described in the instructions) for my composting toilet. It turned out that this was not necessary. As long as urine was kept out, enough coconut fiber (or peat moss) was added, and it was turned, it didn’t smell much. As someone that studied this at scales from a few lbs to hundreds of tons, The key was always aeration. If the system is kept moist, but not too wet, and there are aerating pores that can allow oxygen to get to it, decomposition will be aerobic and can’t produce many really bad smells, at least not for very long. The smaller the pile of poop+coconut fiber, the higher the surface area to volume ratio, increasing aeration. In the case of hooking up a vent, particularly a powered one, removing air from the “tank” will necessarily require outside air and its oxygen to migrate in to replace it (equalize pressures), which will increase aeration. We actually would set up compressors and force air through vented flooring or pipes through piles in larger scales. Temperatures from the microbial decomposition could reach 180 decrees inside of those piles, and they would steam a lot.
Conclusion: If the system is smelling really bad, it is anaerobic, and the answer is adding more fiber and mixing to increase aeration. Too much waste over short periods of time could also overwhelm any composting system. On the scale of a million or so people’s waste, the City of Tacoma actually injects pure oxygen into its wastewater treatment system to keep it aerobic.
Phil Barnes
City/Region: Colorado /San Juan Islands
C-Dory Year: 1991
Vessel Name: Swan-C
PostPosted: Tue Apr 04, 2023 4:54 pm    Post subject: Reply with quote
robhwa wrote "
Conclusion: If the system is smelling really bad, it is anaerobic, and the answer is adding more fiber and mixing to increase aeration."
That is our experience as well. It can be overwhelmed. More input needs more mixing. Don't let it get too wet in the tank as that precludes oxygen. We have not had complaints at our marina or at other docks. If it smells then something likely needs adjusted. If you put your nose at the vent you may get some slight odor but should not be offensive.
We have had an AirHead on a 25 for three seasons and it works very well for us.
Ken O
City/Region: West Yellowstone
State or Province: MT
C-Dory Year: 1990
Vessel Name: Ravens' Roost
Photos: Ravens’ Roost
PostPosted: Wed Apr 05, 2023 9:17 pm    Post subject: Reply with quote
Too bad about C-Head. We have one in the boat and one on our house construction site and they are great.
There's only 3 key elements to a composting toilet:
1) Separate the pee from the solids. A plastic jug works well. They key here is a urine diverter:
https://www.amazon.com/dp/B08CHMV5J6/ref=cm_sw_r_cp_apa_i_dlnCFbY8VP0YP
2) Use a good medium. The C-Head folks liked shredded aspen Gerbil bedding, available at Walmart, and it works well for us:
https://www.walmart.com/c/kp/aspen-pet-bedding
3) Stir it up after every use. The C-head came with a crank. Otherwise, you need to improvise.
These RV folks are offering free build-your-own plans:
https://timshannonltd.com/free-plans-for-build-your-own-composting-toilet/
I borrowed some from their plans and built a cockpit locker on the starboard side of our C-22 Cruiser that also has a super-insulated place for the cooler. It's also a great place to stretch out and have a beer. We get a week out of the ice and 2 weeks out of the C-head.
"If it were easy, everyone would be doing it." --Circumnavigator and author Larry Pardey.
Ken O
C-Dory Year: 1990
PostPosted: Wed Apr 05, 2023 9:22 pm    Post subject: Ooops--one more though on composting toilets Reply with quote
Key #4: Put the TP in a separate container. It's really not that hard to do. I found a tall thin plastic cereal container at Walmart, built a hinged lid over it, and it works great. The TP doesn't really interfere with the moisture absorption, it just wastes space. Line the container with a plastic shopping bag and toss when full. I bag of used TP isn't really as ugly as it sounds.
PostPosted: Wed Apr 05, 2023 9:41 pm    Post subject: Reply with quote
I reviewed the last link and several others related to it. These folks are not using an agitator, they are just putting more petemoss or or wood shavings etc on top of each poop. This is definitely not a composting toilet--it is cover up the poop toilet. When we were at a point of taking our "material" out of the airhead, especially after several trips before we disposed of the solid area content, it looked just like composted earth. Part of that I contend is due to the regular agitation and allowing oxygen to react and increased the composting process.
The gal said she "sealed" the plywood with a water based urethane varnish. I would be very uncomfortable with that type of "sealing"--I doubt that the end grain wood was really sealed. I would use epoxy, and perhaps even put a light fiberglass cloth over the wood. I can see down the line in the unit in the van, as being a real mess with the wood there.
Post new topic   Reply to topic    The C-Brats Forum Index -> Wastewater Systems All times are GMT - 5 Hours
Page 2 of 3
Page generation time: 0.0568s (PHP: 66% - SQL: 34%) - SQL queries: 28 - GZIP disabled - Debug on
