Joined: 27 Oct 2012 Posts: 3563 City/Region: SW Michigan
Posted: Sun Apr 30, 2023 3:53 pm Post subject: |
thataway wrote: | ... Also, does this thruster have time or temperature cut out on the pump to limit the time it runs? Many of the tunnel type have these "safety" features. Not so safe it the skipper urgently needs the thruster to get his boat into a close dock and the thruster times out or temperature's out. ...! |
The manual does say that there is a thermal cutout feature and not to run the thrusters more than 10 seconds at a time. The system also needs its own battery.
Since the power unit is a pump and not just a motor, you'd think that they'd be able to tap some water off as a cooling loop for whatever part gets hot and trips the thermal cutoff.
Yes, you should be able to manage your boat without thrusters and be ready in case there is a failure. But if there is something that makes your life a bit easier, why not get one? Might lead to a little less yelling at the crew when docking.
My boat also carries evidence of its experience. |
Joined: 02 Nov 2003 Posts: 21378 City/Region: Pensacola
Posted: Sun Apr 30, 2023 6:14 pm Post subject: |
Quote: | But if there is something that makes your life a bit easier, why not get one? Might lead to a little less yelling at the crew when docking. |
Eartec: solves these problems for $385 for a set.
 _________________ Bob Austin
serpa4
C-Dory Year: 2018
Vessel Name: DayLo
Photos: DayLo
Posted: Tue May 02, 2023 6:10 am Post subject: |
I"ve had them, bow and stern on a 30ft. Really nice and handy. I've also had them leak and suck in hidden lines. Gear lube leaks as well as water.
I like the the simplicity of a C-dory. Even if I had the money, likely would not add one. Just more to go wrong.
Small ones may not be as effective as imagined though. In a stiff wind or current, it may not hold or be strong enough to work; but would still help.
I get it, would make boating easier on a lot of situations, but is it worth it?
1) Practice
2) Lots of large fenders
3) spring like is great for thrusting the boat forward and thus into the dock.
4) then if all else fails, and you have funds, put some type of thruster on. I get it, they are great and do help reduce docking and trailering stress. _________________ 2018 C-Dory Venture 26. Suzuki DF200A,autopilot, solar, 412ahr of lithium. |
Avidmagnum12
Joined: 23 Mar 2013 Posts: 717 City/Region: Ocklawaha
C-Dory Year: 2011
Vessel Name: C-Otter
Photos: C-Otter
Posted: Wed May 03, 2023 12:35 pm Post subject: |
I called the distributor yesterday and they sent me photos of the installation of the mini. Very clean and compact. It will be interesting to see how well it works in high winds. This could make a great option for the factory. Some boaters purchase a Ranger Tug just because they have a thruster.
Tom _________________ Tom and Joyce Schulke
2004 CD 22 Commuter "Out2C" 03/10 to 06/15 |
theflyscot
Joined: 19 Apr 2009 Posts: 19 City/Region: Fort Myers
C-Dory Year: 2023
Vessel Name: The Flying Scotsman III
Posted: Sun May 14, 2023 10:33 pm Post subject: |
When I’m stuck somewhere, I’ll try to work out how to post Micro Thruster photos. All good so far on the Clockwise Great Loop. About to go up some of the Mississippi over the next three days. _________________ 🎶 Michael ⚓️ |
Posted: Mon May 15, 2023 9:55 am Post subject: |
theflyscot wrote: | When I’m stuck somewhere, I’ll try to work out how to post Micro Thruster photos. All good so far on the Clockwise Great Loop. About to go up some of the Mississippi over the next three days. |
Need to get the admins to set up a gallery for your account so you can post photos. |
