25/26 vs 22 in rough waters
PostPosted: Thu Jul 07, 2022 11:29 pm    Post subject: Reply with quote
On SleepyC I have an 1100 Rule-Mate in the forward cockpit bilge, and a 1500 Rule-Mate in the aft sunken dish bilge. On one crossing of Juan de Fuca, I apparently bumped my bilge switch off the auto position with my knee. When I realized that, I had about 8 inches at the aft wall of the cockpit. I was running about 7-8 knots in forward port quartering seas with a stiff 15+ breeze so the cockpit was loading with splash/spray from the waves. It took about 1 minute to empty. Boat sure felt better.Laughing ME TOO Shocked Cool
And Yes, I have smooth bore hoses.
PostPosted: Thu Jul 07, 2022 11:43 pm    Post subject: Reply with quote
If the rear deck on a boat is pooped, you need to move that water now. An 800 gph pump, if everything (including the hose) was at max efficiency, would move about 13 gallons per minute. Not much, not very fast.
That said, we had Wild Blue in a lot of conditions during the years, and getting any water in the cockpit was extremely rare.
We only had the 25, not the 22, but in traveling with a couple C-Dory groups, it seemed to me that the additional one ton of weight, more waterline, and beam of the 25 provided a better ride than the 22 at the same speeds. I agree that 2' chop would have us slow down, but the 22 would need to slow even more to get a similar ride.
For us, slowing down wasn't an issue... go for the best ride or fuel efficiency vs making miles.
The only time our scuppers were underwater was while tied to the dock with 7 adults in the cockpit (under the cover of our camperback to get out of the weather). Yes, it was a crowd.
PostPosted: Fri Jul 08, 2022 11:00 am    Post subject: Reply with quote
colbysmith wrote:
Colby, there are none of the bilge pumps in any of the C Dory line, which really move a lot of water!
My original bilge pump in the 22 was 500gph. I changed that to an 800, and added a 1100gph backup pump. I think I've got the same combination in my 25 bilge now. Combined they could pump a lot of water. 1000 gallons would probably sink any small boat... Colby
The reality is that none of these Rule pumps can put out anywhere near the "rated" capacity
This Boat US article shows that the 500 gal per hour pump may realistically be only capable of 100 to 150 gallons per hour. 100 gal per hour loss due to voltage less than 12.8 volts, 150 gallon per hour loss due to head pressure of pressure of 36", and 100 gallon per hour loss due to 3/4-inch corrugated hose.
Displacement pump do better than the free plastic vane pumps. When on our sailboats we always carried a Whale Gusher 30 double diaphragm manual pump. It was capable of 30 gallons per minute, if you could keep up the cadence of 30 pumps per minute. We had water intrusion thru companionway and some hatches during severe N. Atlantic Storm on crossing Bermuda to Azores. (40' breaking seas and 3 days of winds in excess of 65 knots) where solid water was regularly breaking on deck. I had to supplement our two 1000 gallon electric pumps. There was enough sawdust and dog hair in the far reaches of hull that it regularly plugged up the bilge pump strainers. (We had tried to get any debris out by washing with a hose behind all cabinets before our voyage started.) The manual diaphragm pumps can take all of that debris out with each stroke, If anything does plug up plug up the pump, a simple opening of the chamber will clear it in seconds.
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Fri Jul 08, 2022 12:02 pm    Post subject: Reply with quote
Those actual GPH numbers are why I have a 2000 GPH pump with smooth wall hose in my CD 16. I figure that gets me a realistic 600 GPH, about the same rate I could do with a bucket (probably not for an hour). For a serious wave over the stern, GPH likely won't help. I would have to rely on PFD and DSC.
C-Slug
City/Region: Ventura
PostPosted: Fri Jul 08, 2022 12:18 pm    Post subject: Reply with quote
Thanks for all the replies! Really appreciate the knowledge here and kindness to share.
Colby, I will be installing a second bilge on our boat too, just in case the primary ever gives out.
As for the scuppers on the 25, I figured you'd have to be up and moving for those to work, which makes some sense. What doesn't make sense is that when you stop to go fishing or spend the night they will fill up with water! I'm never going to remember to put the plugs back in before slowing down.
To be clear, I'm in the Santa Barbara Channel routinely with our 22. On a good day, it's a breeze. On an OK day it's still fun. But when you get wind and mixed swell at a few feet, plus the following (longer period) groundswell on the way home, it's less fun. It's a lot to rely on NOAA forecast to get right. I've been out a couple of times where I thought, "10 more knots of wind and two more feet of swell and I'd be challenged." These were days predicted to be relatively calm.
Sum total, sounds like a 25 gives a smoother ride (and a bathroom option). But not necessarily more peace of mind.
C-Wolfe
Vessel Name: Valhalla
Photos: C-Wolfe
PostPosted: Fri Jul 08, 2022 1:51 pm    Post subject: Reply with quote
I always said that there is no better bail out pump then a scared sailor with a bucket Laughing
Stephan
PostPosted: Fri Jul 08, 2022 9:03 pm    Post subject: Reply with quote
The amount of drainage, or where the scuppers were located are different in different boats. My 2007, 25 never had the water back up in the scuppers, and drained well. I know that C Otter moved his drain points up, which required fiberglassing the old holes in.. A fair amount of work!
PostPosted: Sat Jul 09, 2022 10:07 am    Post subject: Reply with quote
I'm not going to argue with the expert, but those scupper outlets are just above water level to allow water to drain out. In Journey On they went under water in the following conditions:
1. 4 or more people in the cockpit, when you're tied up at the dock. Rather disconcerting to have someone ask "where's that water coming from?"
2. When one is slowly cruising along with the stern somewhat buried, some water will come in. Not much, but some. And it will not drain out. Use the sponge.
We have plugs and usually use them after the fact.
PostPosted: Sat Jul 09, 2022 12:11 pm    Post subject: Reply with quote
My scuppers are just barely above the water with no additional weight in the back. That's with full fuel and potable water and our Engel freezer. (And with the Yamaha 150 and 9.9.) However if either Rosanne or I step to the very back, particularly if we stand in the corner, (ie, catching dock cleats to tie lines, etc.) the scuppers are then working in reverse. (letting water in.) Unfortunately, with the cockpit floor in the 25, at least on our boat, the scuppers can not be raised any more. (They have to be at floor level to work.) I have scupper plugs that I keep in when we are not moving or sitting in the cockpit. They are removed at night in case of rain (and while we are in the cabin) or when underway. Colby
mutski
City/Region: Homer
Vessel Name: Just Us
Photos: Just Us
PostPosted: Sun Jul 10, 2022 4:23 am    Post subject: Reply with quote
I'm new to the C-Dory game, but in my newly acquired 22 Cruiser, I find the downwind leg most disconcerting because there is an occasional tendency to broach on a large wave. I think the trick is not to travel close to the speed of the waves.
PostPosted: Sun Jul 10, 2022 5:07 am    Post subject: Reply with quote
My feeling is if the C Dory 22 is properly trimmed, and handled, that it does far better than most boats going downwind/waves. Keep the bow up, No excess weight in the bow, trim tabes up; with motor up (Permatrim plays a role here), Judicious use of the throttle is also important. (This why offshore power boat racers have a driver and a separate throttle man.) Although staying on the back of a large wave is best, there may be times that you accelerate and go over the face (not breaking and less than the waterline length of the C Dory, with longer period). Sometimes it helps to crack off to one side, or on others do to straight. This becomes a reflex, as do many other sports. The more the dead rise, the more difficult down way/wind is. Full displacement boats and deep V's are far more likely to broach.
PostPosted: Sun Jul 10, 2022 8:44 pm    Post subject: Reply with quote
Foggy posted
"On a sail from Newport to St Maarten, via Bermuda, I met a guy who sailed a Catalina 22 around the world, twice. Impressive, but not for just anybody. "
Now, I've owned a Catalina 22 for many years, OK 10 years. And it went to many places in California and Mexico. Foggy, sorry but I don't believe that anyone sailed a Cat 22 around the world. It's not built for that, it was an entry boat and it would have come apart in the Pacific Ocean. I would assume the guy was boasting and picked the most improbable subject.
Now, I took a Catalina 36 to Tahiti, among other places and it did quite well. Someone, I believe, took a Catalina 27 around the world years ago. I feel Catalina builds good boats, but each has a purpose, and the 22 was an entry boat, the first boat Butler built.
Sorry Foggy, but you can tell that guy he was full of bull. And my comment is unrelated to this thread, obviously. Just been thinking about it for a couple of days.
mutski
City/Region: Homer
Photos: Just Us
PostPosted: Mon Jul 11, 2022 2:08 pm    Post subject: Reply with quote
I've been putting the trim tabs up running downwind, but good point about trimming the motor up. My old home-built dory occaisonally tried to broach too, but it was easier to control. It had a wider, completely flat bottom slightly turned up at the nose.
PostPosted: Mon Jul 11, 2022 10:22 pm    Post subject: Reply with quote
Definitely have to bring the motor up, even if no Permatrim. The Permatrim I consider essential for going into the chop, as well as the trim tabs to get the bow down--and not as essential in bringing the bow. up doing down wind/seas,
I was in some pretty nasty seas in Johnston straits and was the only boat running (down wind), with wind against current--seas 6 to 8 feet, and short period. I just stayed on the back of seas and let her ride. No boats including the 80 footers were attempting to go into the seas.
mutski
City/Region: Homer
Photos: Just Us
PostPosted: Wed Jul 20, 2022 2:38 pm    Post subject: Reply with quote
Thinking more about following seas. These are good, although the one with the cargo ships is complicated.
https://www.youtube.com/watch?v=2CVwaYbyw5c&t=268s
https://www.youtube.com/watch?v=Zf5lhO4CCiI
https://www.youtube.com/watch?v=WfaL6NMUfYo
https://www.youtube.com/watch?v=uGQXe35--Jk
This also has some instructive moments:
https://www.youtube.com/watch?v=AS7FqXfeP7Q
Or, there's the bikinis and beer method. It's appalling, but interesting to watch after you see the instructive videos above.
https://www.youtube.com/watch?v=hH3nsTqdAd8
Page 2 of 3
Page generation time: 0.0545s (PHP: 69% - SQL: 31%) - SQL queries: 28 - GZIP disabled - Debug on
