Why does my steering stiffen up at speed?
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Tue Mar 29, 2022 9:50 pm    Post subject: Reply with quote
Check to be sure the new cable push pull steering is a "non feed back system". What this means is that the pressure on the cable is not pushed back on the helm. If you have a NF system, it will be much easier to steer. A motor that small should don't be an issue. The NF systems are a few dollars more expensive, but well worth it. The helm itself is less than $150.
There may be something binding when the boat comes up to speed, and pressure is on the steering tube. Even if greased--it may pay to put further grease, until if is oozing out of the end of the tube. Then with steering disconnected, try turning back and forth--see if any place is binding.
It's has to be something like this. It's a bit weird that in a static situation it doesn't do it. Then again, motors are much harder to turn when underway. I sort of suspected the pivot tube on the engine, because they can get corroded and seize, but I don't think that is it since there are two different engines involved. There is a reason it has a new cable - not a coincidence in my opinion. I would be taking it all apart back there.
Roamad
City/Region: Sacramento
C-Dory Year: 1988
C-Dory Model: 22 Classic
Vessel Name: Fika
Photos: Roamad
PostPosted: Wed Mar 30, 2022 8:34 pm    Post subject: Reply with quote
How do I tell if my steering cable is of the “non-feedback” type?
Now: 1983 22’ C-Dory Classic, 2001 Honda 90hp
Then: 1988 16’ C-Dory Angler, 2008 Mercury 60hp
johnr
City/Region: Bellingham
Vessel Name: Stillwater
Photos: Surf Scoter
PostPosted: Wed Mar 30, 2022 9:43 pm    Post subject: Reply with quote
The way it was explained to me when I had it installed, with a non-feedback system, you eliminate the torque from the outboard, so if you let go of the steering wheel, the boat is still going straight, more or less. Without the non-feedback, the torque will cause the steering wheel to turn immediately, so you always have to keep your hands firmly on the steering wheel to keep the boat from turning.
For me, this was true and very obvious. Do you have to keep your hands firmly on the wheel to keep your boat from turning?
PostPosted: Thu Mar 31, 2022 11:49 am    Post subject: Reply with quote
Isn't the purpose of the trim tab on the lower unit to counteract the motor torque loads on the steering? On my boat you're supposed to adjust the tab until the steering forces (left and right) are the same.
Desert Dory
City/Region: Tucson
Vessel Name: Desert Dory
Photos: Desert Dory
PostPosted: Thu Mar 31, 2022 1:56 pm    Post subject: Reply with quote
My boat was very hard to turn, at speed, even with a new cable. I did some research and found my engine was mounted way too low on the transom.
Basically you want the anti-cavitation plate to be just out of the water at speed. Getting it splashed is ok, but out of the main flow.
I ended up raising the engine 2 mounting holes, which did lessen the steering effort at speed. I could actually stand to raise it one more hole.
Roamad
C-Dory Year: 1988
Vessel Name: Fika
Photos: Roamad
PostPosted: Fri Apr 08, 2022 3:39 pm    Post subject: Reply with quote
So, yesterday I greased the pivots on the transom mount and that seemed to help. I also experimented with trimming the motor up and that helped a bit too. So between the two, I’m going to monitor for a while and see how things go, then turn to the steering cable if I’m still having issues. Thanks everyone!
Page generation time: 0.0482s (PHP: 65% - SQL: 35%) - SQL queries: 19 - GZIP disabled - Debug on
