Carpeting Bunks for Trailer Loading Guides
zuunami
City/Region: Fort Bragg
Vessel Name: Oh Buoy!
Photos: zuunami
PostPosted: Sun Nov 21, 2021 9:28 pm    Post subject: Reply with quote
thanks all, will be checking it all out Smile We have side bunks about 14" up on the sides of our Magic Tilt trailer for the 16' cruiser, not sure they're even needed?
PostPosted: Sun Nov 21, 2021 9:29 pm    Post subject: Reply with quote
JamesTXSD wrote:
I used this type of bunk slick...
What are they called and where did they come from? Thanks.
PostPosted: Sun Nov 21, 2021 10:25 pm    Post subject: Reply with quote
I posted the link earlier in this thread.
PostPosted: Mon Nov 22, 2021 10:58 am    Post subject: Reply with quote
Right, I see you posted a link to Overtons. I have rollers on the trailer, and I just need something for the side guides, and carpet is looking more and more like what I need.
PostPosted: Mon Nov 22, 2021 11:04 am    Post subject: Reply with quote
Thanks, Jody! This looks like just exactly what I need if I go with carpet, which it is looking more and more like what I will need to do. I have roller bunks and what I need now is just for the side guides.
jkidd wrote:
Amazon has the stapler and the monel staples
Stapler
https://www.amazon.com/Arrow-Fastener-PT50-Pneumatic-Staple/dp/B00GLZZSN2/ref=sr_1_6?keywords=Arrow+air&qid=1637437951&sr=8-6
Staples
https://www.amazon.com/Arrow-Fastener-508M1-Stpl-Monel/dp/B07W7DFWDW/ref=sr_1_3?crid=3A0BT6ZGJYD40&keywords=t50+monel+staples+1%2F2&qid=1637438095&sprefix=T50+mon%2Caps%2C212&sr=8-3
PostPosted: Mon Nov 22, 2021 11:38 am    Post subject: Reply with quote
Pat,
I believe that the staple gun linked is compressed air driven. If you have a suitable compressor, then it is a very good choice. Although I have a 4 hp, 25 gallon compressor, the Arrow electric stapler works adequately for the carpet on boat bunks. I was able to find Arrow T50 staples in Monel metal, Also Stanley makes the staples in Monel metal. Sizes I have are: 5/16", 3/8" 1/2" and 9/ 16". The Monel metal will not corrode--I have found that most stainless steel staples will fair, especially if used in salt water.
PostPosted: Mon Nov 22, 2021 1:54 pm    Post subject: Reply with quote
Pat,
Thanks, Bob. I have a DeWalt compressor, it has a 6 gallon tank and says 165 psi. I have only used it for inflating truck and trailer tires, and works great for that, even though I sometimes have to wait a bit as it cycles on to recharge the tank. At this point, I could get either an electric or pneumatic stapler. Recommendation? I might find other uses for a stapler but it will be only occasionally used. I have a couple of heavy duty manual staplers but I no longer have the hand strength to operate them.
PostPosted: Mon Nov 22, 2021 6:19 pm    Post subject: Reply with quote
Pat your compressor should handle the stapler with no problems. I also have one of the "Pancake" 6 gallon tank by Porter Cable. That is the one I move around the property.
Page generation time: 0.0414s (PHP: 67% - SQL: 33%) - SQL queries: 25 - GZIP disabled - Debug on
