outbackbill
Joined: 23 Apr 2011 Posts: 47 City/Region: Mocksville
Vessel Name: Blue Days
Photos: Blue Days
Posted: Wed Dec 16, 2020 5:08 pm Post subject: |
When our Bimini was first installed in Florida I followed the advice of the builder and what I had read here and booted it against the cabin top. We then headed to the Great Lakes and when we opened it for the first time we found two small holes and several worn areas where it had rubbed against one of the center cross bars. Since then we remove it and store it in the cabin if we will be traveling at highway speed for any amount of time. We leave the frame in the rear position and bungee it. After nearly 165000 miles of trailering my first mate has become very proficient at putting it up. When we launch the boat she usually has it up within 15 minutes of leaving the ramp.
Bill |
Foggy
Joined: 01 Aug 2013 Posts: 1524 City/Region: Traverse City; Northern Lake Michigan
C-Dory Year: 2014
Photos: W B Nod
Posted: Wed Dec 16, 2020 6:35 pm Post subject: |
Hey, Bill.
With that many miles of trailering, I bow to you.
Aye. _________________ "I don't want any cake" - said no one ever.
If someone tells you they don't eat cake, unfriend them. You don't need that kind of negativity in your life. |
Hunkydory
Joined: 28 Mar 2005 Posts: 2673 City/Region: Cokeville, Wyoming
State or Province: WY
Vessel Name: Hunkydory
Posted: Thu Dec 17, 2020 9:43 pm Post subject: |
outbackbill wrote: | When our Bimini was first installed in Florida I followed the advice of the builder and what I had read here and booted it against the cabin top. We then headed to the Great Lakes and when we opened it for the first time we found two small holes and several worn areas where it had rubbed against one of the center cross bars. Since then we remove it and store it in the cabin if we will be traveling at highway speed for any amount of time. We leave the frame in the rear position and bungee it. After nearly 165000 miles of trailering my first mate has become very proficient at putting it up. When we launch the boat she usually has it up within 15 minutes of leaving the ramp.
Bill |
That’s an extreme amount of towing if all those miles were towing your C-Dory. I’d appreciate your general sharing of this accomplishment. We’ve been towing our CD22 for the last 18 years with many long distance trips & are only about half your amount. The good part of our miles made was having only 2 flats, minor other problems & no bearing or brake trouble.
Baxter
Vessel Name: Baxter ll
Posted: Fri Dec 18, 2020 12:30 pm Post subject: towing with bimi up position |
I have towed about 20,000 miles with Venture 23.
Only first 10 with. up.
To hard on equipment unless going to tow at 35 mph.
I found not that big of deal to install before launch or
of not sure I will need right away will put up when needed.
My side curtains have only been use 3 times. Like new just haven't needed much.
Probably this is the same answer others give. _________________ What we do for ourselves stays here, what we do for others goes with us |
Chester
Photos: Chester
Posted: Sat Dec 19, 2020 10:07 pm Post subject: |
Chafe is the enemy of the two oldest professions, prostitution and sailing.
Any flapping in the wind will cause damage.
Before I got a cover (boot?) for the bimini I lowered it, wrapped it tightly around the frame and used numerous tie wraps with release triggers to prevent any flapping. Now the boot replaces the tie wraps for the most part, I still put them on the boot ends where wind could separate the zipper. |
