Window Screens on CD-25 Aft Windows
PostPosted: Thu Aug 06, 2020 1:32 am    Post subject: Reply with quote
I'm thinking I'm going to get some 1/4" hard plastic, starboard maybe, and cut to fit the tracks. Then cut out the inside leaving a parameter of maybe 1", and get regular screening material to fit in a groove I'll route out. Otherwise, probably velcro and find some surplus military bug netting. I'll go check out those links now to see if I"m interested. Thanks. Colby
PostPosted: Thu Aug 06, 2020 10:48 pm    Post subject: Reply with quote
We obtained enough of the military "no see um" netting to do a number of windows for about $10--it was a cover for a tent. Hot glue the velcro to the insect screen and you are good to go.
Although the Starboard is easy to work with standard wood working tools, it is costly, and hard to get "perfect" edges. I think there would be a lot of waste with cutting out of the window screen areas.
PostPosted: Fri Aug 07, 2020 12:17 am    Post subject: Reply with quote
Ended up buying some screen making materials at Menards. I'll post here later how it works out... Confused Colby
Blue Rose
City/Region: Montgomery
State or Province: MN
Vessel Name: Blue Rose
Photos: Blue Rose
PostPosted: Fri Aug 07, 2020 9:45 am    Post subject: Reply with quote
Colby-
Just another idea for you in case the "routing a groove to secure the screen" approach gets challenging....
Instead of cutting 1 frame out of 1/4" material.... How about cutting 2 thinner frames out of sheet aluminum and sandwich aluminum screen between them with epoxy? Then trim the screen off flush with the outside of the frames.
Blue Rose
PostPosted: Fri Aug 07, 2020 11:20 pm    Post subject: Reply with quote
Thanks Jim. I'll see what happens with this stuff I got from Menards first. But I like your idea. BTW, got a new screen (for the cabin door) made lickity split for C-Traveler. I think just a notch better than the one I made on Midnight Flyer. Thanks again for letting me check out how yours was put together! Colby
PostPosted: Mon Aug 10, 2020 1:01 pm    Post subject: Reply with quote
This is what I've accomplished so far. Next will be test fitting the frames in the boat, then installing the screen into the frame.
I purchased the frame channel from Menards. I made the round corners from some hard nylon plastic (starboard?) that I planed down to the appropriate thickness, and then cut out with my band saw. First I made a pattern from the window. These will be for the aft port window, and head window right across from it.
If everything fits properly, I'll install the screens. At the corners, since there is no channel for the screen rope to go into, I'll hot glue the screen directly to the corner piece.
PostPosted: Sat Aug 15, 2020 12:14 am    Post subject: Reply with quote
So I finally got the screens all finished up. The only problem is, they are a hair to thick. I think I'll try "pressing" them in my shop vice tomorrow to see if I can squeeze them down any. If that don't work, I guess I'm back to the drawing board. However, at least I have the plywood pattern for the exact size I need. Here are some photos of the finished product, along with a screen I made for the front middle window hatch, and for the main cabin door.
Aft screen with plywood pattern.
Front window hatch screen
Cabin Door screen
Small corner showing framing I installed around cabin door to velcro screen to
PostPosted: Mon Aug 17, 2020 12:20 am    Post subject: Reply with quote
Well, those aft window screens above went into the garbage can today. Wasn't able to get them to fit. And then repressing them in the shop vice pretty much ruined them anyway. However, with some left over PVC board, 1 x 12, I cut some new frames. Actually ended up pretty decent. Some day I'll perfect them as the rounded corner on the bottom is almost a little to small. However, for now they work quite well all things considered. Photos below, but here's the steps I took:
1-cut the board to the proper dimensions.
2- planed down the 3/4" pvc board to 1/4", to fit in the window track.
3- routed out a small groove where the screen retainer rope would fit.
4- cut out the inside material leaving just the screen frame.
5- pvc glued a small finger bracket to slide the screens and to also help glue the frame back together where my bandsaw passed thru.
6- installed the screen into the frame.
7- to strengthen the frame just a bit more, especially since it's bowed a little bit, I cut a piece of the earlier screen frame making material to glue to the back edge of the screen frame. (Just used a little bit of some 5200 I had left over).
8- will install the screen/frame into the window track as soon as I get the weather seal (bug seal) along the back edge of the frame to stay stuck on. May need to add some kind of spring material to the top of the frame to help keep it in the track, but for now it seems to work without a spring.
Main frame material cut out, planed down, and groove routed for screen rope.
Screen frame excess material cut out leaving just the frame.
Finished screen and frame.
BBlalock
City/Region: Ocean/ICW
C-Dory Year: 2013
Vessel Name: Finale
PostPosted: Tue Aug 18, 2020 4:46 pm    Post subject: Reply with quote
srbaum
Steve,
What parts did you order for the frames. Looks like several different sizes.
Thanks for finding this and posting.
Benton
Benton Blalock
'13 25' Cruiser "Finale"
'12 22' Fiesta pontoon(sold)
PostPosted: Tue Aug 18, 2020 5:29 pm    Post subject: Reply with quote
All done and installed. Very Happy Colby
Page generation time: 0.0597s (PHP: 53% - SQL: 47%) - SQL queries: 23 - GZIP disabled - Debug on
