Engine still not performing
Barry Rietz
City/Region: Sierra Vista
PostPosted: Thu Sep 03, 2020 9:32 pm    Post subject: Ethanol Reply with quote
I'm with "Johnbenj" on this issue and add that if nothing else is discovered in a survey of all the normal protocols, it has to be the "ethanol fuel". Have a read of the post I authored several years back that describes the problem, what needs to be done, and how to prevent it from occuring again in the future!
Barry Rietz
N9DXC
PostPosted: Thu Sep 03, 2020 9:52 pm    Post subject: Reply with quote
Anyone have any ideas on what could be wrong? Not taking it back to the idiots who worked on it, would like to find an authorized Honda outboard dealer/mechanic shop. Any good recommendations in the fort Walton beach, Pensacola Panama City area?
First do not run. that motor when leaking fuel like that. It is a bomb ready to explode!!!
Several had suggested Wefings at Apalachicola. I had also suggested Posner Marine in Pensacola on Barrancas Ave. Take it to either of these. I have also used Lou's Marine in Gulf Breeze-down toward the Zoo on 98.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Thu Sep 03, 2020 10:28 pm    Post subject: Reply with quote
Your carbs are pouring fuel because your float is stuck - at least probably. As far as your lack of power or speed, it could be so many things. If you get it running right again, and I think you will as these older non-fuel injected motors are pretty simple requiring minimal tools to work on, you really should get around 30 mph out of it or a little more with a light load. The RPMs will be around 5500-6000k. My personal preference for full throttle power is as close as you can get to redline. I feel bad for your situation - I'd take it back....maybe....they don't sound like they know what the heck they are doing and that makes things tough.
Page generation time: 0.0264s (PHP: 59% - SQL: 41%) - SQL queries: 20 - GZIP disabled - Debug on
