CTYankee
State or Province: CT
Vessel Name: Crescent Girl
Photos: Crescent Girl
Posted: Tue Dec 20, 2005 3:43 pm Post subject: |
Pat,
I've used one of those Mr. Buddy heaters for 2 years, but only oassionally during Spring and Fall as our New England winters are too cold for much boating. They work great, especially while moving so the condensation is vented out. I never leave it running while sleeping. For a cheap ($80) and easy temporary solution, they are great. Get a CO alarm and you'll be all set w/ the window cracked.
Dun (CTYankee) |
hughpenk
Joined: 12 Feb 2005 Posts: 64 City/Region: Waterford--Intersection of Hudson River/Chaimplain Canal and Mohawk River Erie Canal
State or Province: NY
Photos: CD 16 (hughpenk)
Posted: Tue Dec 20, 2005 4:04 pm Post subject: |
I've been using my heater buddy in my 16 cruiser. It puts out more heat than I use, the low setting is fine. Home depot around $80. I actually read the instructions since my body is with-in reach of the of the bomb as is my 6 gallon fuel tank- how much room do you think is in a 16 footer! Anyway, It advises an 8" square opening allowing fresh air in to feed the O2. The water out-put is considerable and you will need the cabin boy or girl keep the wind shield clear. |
416rigby
Joined: 31 Mar 2004 Posts: 1208 City/Region: Port Angeles
Vessel Name: Foggy Dew
Photos: Foggy Dew
Posted: Tue Dec 20, 2005 4:36 pm Post subject: |
Yep, sure love our Mr Heater Portable Buddy. We have plenty of ventilation through the seams of the canvas on our boat, but it has O2 sensor and tip over switch. Works great. They are made for indoor use. Good idea to crack a window, though, just for extra safety. Remember to turn it up to high setting when first starting up, then after the ceramic glows orange, you can turn it down to low if desired. It sure takes the chill off and helps us defog the windows. Bottles of propane last a long time and there's NO SMELL.
Rick _________________ "Life's too short to hunt with an ugly gun"
2001 22 Cruiser "Foggy Dew" 2006-2013 |
Byrdman
Joined: 06 Nov 2003 Posts: 3320 City/Region: Cumberland River, Clarksville,
Photos: FreeByrd and C-Byrd
Posted: Tue Dec 20, 2005 5:01 pm Post subject: |
Sounds like a plan. I will wait to see if Mike buys one 1st. He should have his boat at home prior to me getting back from Seattle....and my other brother (not Mike... but JB )... I could hear yall thinking.... has several kerosene heaters....that burn klean heat.... |
Joined: 23 Oct 2003 Posts: 5315 City/Region: Warrenton
Posted: Tue Dec 20, 2005 9:06 pm Post subject: |
Byrdman wrote: | Mount that puppy on the roof with a 20lb bottle of propane, run the hoses down the roofline into the side windows, blowing in and cross the windshield area..... |
Patrick, you might be over complicating this issue. Ain't you got a wheelbarrow? _________________ TyBoo Mike
Sold: 1987 22' Cruiser |
Byrdman
Posted: Wed Dec 21, 2005 11:53 am Post subject: |
yes I do....but I can't get it thru the side windows |
Adeline
Joined: 03 Nov 2003 Posts: 985 City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
dogon dory
Vessel Name: DogOnDory
Posted: Wed Dec 21, 2005 10:41 pm Post subject: |
Salmon Slayer
Joined: 05 Jul 2005 Posts: 132 City/Region: Juneau, Alaska
C-Dory Year: 1981
Vessel Name: Holly May
Photos: Holly May
Posted: Wed Dec 21, 2005 11:13 pm Post subject: |
I think I am traumatized from the whole malapropism issue. _________________ Salmon Slayer
Where did all those years go? |
El and Bill
Joined: 08 Nov 2003 Posts: 3200 City/Region: Lakewood, CO
Vessel Name: Halcyon
Photos: Halcyon
Posted: Thu Dec 22, 2005 6:07 pm Post subject: |
A few more malapropisms to ponder:
He had to use a fire distinguisher.
Dad says the monster is just a pigment of my imagination.
Isn't that an expensive pendulum round that man's neck?
Good punctuation means not to be late.
He's a wolf in cheap clothing.
Michelangelo painted the Sixteenth Chapel.
My sister has extra-century perception. _________________ El and Bill (former live-aboards)
http://cruisingamerica-halcyondays.com/ |
Chris Bulovsky
C-Dory Year: 1998
Vessel Name: SCOUT
Photos: SCOUT
Posted: Fri Jan 13, 2006 9:42 pm Post subject: |
Ok- I went out to Wal-Mart and purchased a Mr. Heater buddy for about 75$. It works very well. (for heat) Im able to bump around in the cabin with a t-shirt on in 20deg. weather. The one drawback is that it gives off a fair amount of moisture. It needs all windows cracked just a little bit to vent the steam. The floor stays cool despite the heater cranking. I still need to monitor the CO ppm. Its on my to do list.
Chris Bulovsky
Washburn Wi |
oldgrowth
Vessel Name: C-Voyager
Photos: C-Voyager
Posted: Sun Jan 29, 2006 12:30 am Post subject: |
I use a Coleman 3000 BTU Catalytic Heater that I added a computer 12 volt fan to. The fan draws very little current add does a good job of circulating the heat. The unit comes apart and folds up for compact storage. On a 16 you don’t have much extra room. With the camper back on and outside temperature in the lower 40’s, inside temperature is nice and comfortable. With the 16 oz canister it will run 7 hrs on high. No moisture buildup with the fan running, but with the 16 you don’t have an enclosed cab. I have photos of it in my Boat Projects album. They are near the end of the projects album. _________________ Dave
Posted: Sun Jan 29, 2006 12:53 am Post subject: |
Dave-
Clever use of a simple heater in a limited space!
My only thought, since you're using this within the somewhat ventilated confines of the canvas which should vent the moisture and other benign exhaust gases, is to be sure the fan doesn't blow on the catalytic burner itself, which might lower the "combustion" temperatures enough to create some carbon monoxide.
Don't ya' just love those little useful computer fans?!?!?!!!
oldgrowth
Photos: C-Voyager
Posted: Sun Jan 29, 2006 1:30 am Post subject: |
Quote: | Don't ya' just love those little useful computer fans?!?!?!!! |
I sure do.
I have a couple 7” fans from an old server I had. I will make stands for them and use them for cooling in the summer.
Quote: | be sure the fan doesn't blow on the catalytic burner itself |
As long as I keep the fan blowing on the back of the converter, I shouldn't have a problem.
Joined: 02 Nov 2003 Posts: 8555 City/Region: Birch Bay, WA
Posted: Sun Jan 29, 2006 10:55 am Post subject: |
Good work, Dave (all of it)! You got time to re-wire a CD25?
oldgrowth wrote: | I use a Coleman 3000 BTU Catalytic Heater that I added a computer 12 volt fan to. The fan draws very little current add does a good job of circulating the heat. The unit comes apart and folds up for compact storage. On a 16 you don’t have much extra room. With the camper back on and outside temperature in the lower 40’s, inside temperature is nice and comfortable. With the 16 oz canister it will run 7 hrs on high. No moisture buildup with the fan running, but with the 16 you don’t have an enclosed cab. I have photos of it in my Boat Projects album. They are near the end of the projects album. |
