CD25 Freshwater hose configuration
Micahbigsur@msn.com
City/Region: Big Sur
Vessel Name: Sierra
Photos: Sierra
PostPosted: Fri Aug 23, 2019 8:54 pm    Post subject: Reply with quote
I got tired of the hassle of trying to pull stuff through behind and under the head so now I have left in permanent pull though lines. The tug was an all molded interior and was hard to add on to without cutting access hatches everywhere.
Micah Curtis and Dana, RN
Micah, KJ6GUF, Dana, KJ6GXG
PostPosted: Fri Aug 23, 2019 10:05 pm    Post subject: Reply with quote
When ever I have to pull a wire or hose, I always leave behind a pull thru line. There was already a pull thru line from under the galley, below the shower pan, and into the step area where there is a bilge pump. However, that was so tangled it was worthless pulling a pulling the 10 gauge triplex 110 V wire for the new water heater. It was easy to push a steel fishing tape, under the head, and then pull the wire behind the steel tape. A second pulling wire was left in place.
I also label all of the hoses with colored Zip ties: Blue for cold, and red for hot. These labels (along with written labels) were placed anywhere a hose or wire set went thru a bulkhead--on both sides if possible.
Page generation time: 0.0199s (PHP: 74% - SQL: 26%) - SQL queries: 15 - GZIP disabled - Debug on
