Intermittent Engine Starting Problem
Pacificcoast101
City/Region: Torrance
Vessel Name: No Pressure
Photos: No Pressure
PostPosted: Fri May 31, 2019 9:44 pm    Post subject: Reply with quote
We actually had two problems at the same time. We were only a couple hundred feet outside the marina when the port motor stopped. We didn't know it at the time, but the fuel line was being pinched. When I tried to start the starboard motor I had the same symptoms you described. After waiting an hour for Vessel Assist and then being towed back to our slip, both motors started right up. The mechanic found the crimped fuel line but by then, the swing arm had gone back into place against the switch.
Phil Garner
2008 Tomcat 255
No Pressure
My Photos
Page generation time: 0.0222s (PHP: 56% - SQL: 44%) - SQL queries: 14 - GZIP disabled - Debug on
