kaelc
Vessel Name: Island Magic
Photos: Stil-Afloat
Posted: Wed May 22, 2019 4:46 pm Post subject: |
thataway wrote: | "Water puppy" |
Thanks for reminder on the Water Puppy, I used to have kicking around. What model pressure pump are you keeping around as spare? My 07 label isn't readable. |
Joined: 02 Nov 2003 Posts: 21597 City/Region: Pensacola
Posted: Wed May 22, 2019 7:49 pm Post subject: |
kaelc wrote: | thataway wrote: | "Water puppy" |
Sorry, it is on the boat, and I am on the road, without boat.... _________________ Bob Austin
Hull#01
Joined: 09 May 2019 Posts: 6 City/Region: Steilacoom,
Posted: Sun May 26, 2019 8:35 pm Post subject: |
Sorry for late reply life took me away from this project for awhile. Anyways I took it apart and it is seized up tighter then a drum. Any recommendations for a pump that won’t break the bank would be greatly appreciated. Halls so much Doug.
For reference the pump that I have is a flow jet 4125-124 which noted similar to jabsco 31705-0092.
Thanks again _________________ 2006 Venture 23 |
Posted: Sun May 26, 2019 9:12 pm Post subject: |
A close match is the Flojet 1202.1050 04406-143A Quad II Water Pump. It should use the same hose fittings as your Flo Jet. The flow rate is enough, it is only 10 PSI--which is plenty for house use--but not for wash down. If you want wash down, there is a 50 PSI unit: Flojet 03526-144A Triplex Diaphragm . |
