Composting head info
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Thu Jul 21, 2022 12:49 pm    Post subject: Reply with quote
Blast from the past! Just saw this email pop up. Hope all my C brat friends are doing okay!
<><><> Jason <><><>
PostPosted: Thu Jul 21, 2022 12:50 pm    Post subject: Reply with quote
Patty here. We put an Airhead in our 25' boat during construction in 2005. We still have it and have loved it. We took 8 months to cruise the Great Loop, used it every day, emptied the solids only 4 times.
bobjarrard
City/Region: Boulder City
State or Province: NV
PostPosted: Thu Jul 21, 2022 1:23 pm    Post subject: C-Head and other urine collecting toilets Reply with quote
On my C-Head the urine collection bottle is just plain old one gallon plastic water bottles, best the screw top kind with a good handle. Two fit in a canvas carry bag and off you go to find a toilet or urinal. If you garden, you can water with the urine but you may need to dilute first or along the way. If you dig in 3" or 4 "inch by 18" long perforated pipe sections around a tree or bush, the liquid is delivered below 12" or so and there never is any odor. I spritz the urine diverter with a weak cleaning solution (Pine-Sol is my favorite but you can use anything that smells good and leaves no residue - even the holding tank chemicals if diluted a lot work OK). I do not spray the "composting" media but suggest that fresh cedar works great - think "hamster bedding" from Walmart (smallest shaving or sliver size works best - more surface area). The C-Head comes with a second "further composting" five gallon bucket with screened vent but the seven gallon bucket with a screw-on lid adapter from HD or Lowes works better. You can add vents and all kinds of trick stuff. When I use the second bucket I put a double kitchen trash can liner in first so that the bucket is always clean (I add a nice layer of newspaper in the bottom just in case). If you are rich, you can use trash compactor bags but I find them hard to seal for disposal. See ya. Bob
forrest
City/Region: Chehalis
Vessel Name: Long Story
Photos: Long Story
PostPosted: Thu Jul 21, 2022 11:50 pm    Post subject: Reply with quote
Are there composting toilets that don't require 12 volt power? I have a cabin in the woods and the tall trees don't let enough sunlight through to run a solar panel for fan power. If you know of a composting toilet that works without power I would love to know the brand and model.
Forrest
bobjarrard
PostPosted: Fri Jul 22, 2022 9:16 am    Post subject: It is a bit complicated but........... Reply with quote
Forrest,
Only the large cabin/family sized non-flushing toilets require real amounts of power and that at 110V as they have conveyors, mixers, control systems, and heaters. If you need info on this kind of unit, give me a call as it is a "deep" topic.
The three major, actually really only contenders, in the small and easily installed units are made by AirHead and Nature'sHead who hate each other as they had a business issue and then Cap who makes the C-Head that I have. All three of these can have no vent/fan, a gravity vent (relies on air pressure and movement as does a dorade on a boat), a 12 volt computer muffin fan using almost no power 12 volts. a very small 110 volt fan and/or an open window.
Done right as you are not evaporating the urine and only desiccating the feces - not much moisture to get rid of if the use/loading is low as in two to three folks for regualr use or cottage use for shorter visits. The beauty is that you can get ahead of the loading by doing an empty out. The average person should void a liter/quart of urine a day so a a C-Head with a gallon bottle means once a day change out for a party of fur please.
The C-Head can be had with a diverter urine collector that can feed a five gallon yellow plastic diesel or something similar.
Being a recovered hippie from the 60's this is all second nature to me so feel free to call for your no cost consultation. Whatever you do, stay away from the incinerating toilets unless you have lots of 220V and love the smell of burning poop.
Unless your cottage use is in a very urban area, this whole even cycle gets to be organic if you know what I mean. Take a walk in a cow pasture, hard not to step on manure bombs, they are everywhere. I know all about cholera and typhoid, but the entire sub-continent of India uses the outdoors as their toilet of choice. The three units noted above are much more elegant, can be used indoors, and offer a safe way to handle waste. Urine is sterile and clorox is almost free at the 99 Cent Store if you want to put a gallon in each change out of the main chamber.
Here is the homework started for you: https://www.c-head.com/ and then https://airheadtoilet.com/ and then https://natureshead.net/ and there are a ton of DIY sites on the internet. Also, low cost units from Etsy at https://www.etsy.com/market/compost_toilet
Bob Jarrard 714 686-2728
bobjarrard
PostPosted: Fri Jul 22, 2022 9:17 am    Post subject: It is a bit complicated but........... Reply with quote
Forrest,
Done right as you are not evaporating the urine and only desiccating the feces - not much moisture to get rid of if the use/loading is low as in two to three folks for regualr use or cottage use for shorter visits. The beauty is that you can get ahead of the loading by doing an empty out. The average person should void a liter/quart of urine a day so a a C-Head with a gallon bottle means once a day change out for a party of four please.
Unless your cottage use is in a very urban area, this whole event cycle gets to be organic if you know what I mean. Take a walk in a cow pasture, hard not to step on manure bombs, they are everywhere. I know all about cholera and typhoid, but the entire sub-continent of India uses the outdoors as their toilet of choice. The three units noted above are much more elegant, can be used indoors, and offer a safe way to handle waste. Urine is sterile and clorox is almost free at the 99 Cent Store if you want to put a gallon in each change out of the main chamber.
pcg
City/Region: Sherwood
Vessel Name: C-Quest
Photos: pcg
PostPosted: Fri Jul 22, 2022 9:32 am    Post subject: Reply with quote
New composting toilet coming on the market...
https://www.compocloset.com/cuddy
Paul
bobjarrard
PostPosted: Fri Jul 22, 2022 11:27 am    Post subject: sorta in the middle Reply with quote
The cost in the sweet spot at $750 plus add ons and shipping. It looks good. Nice exterior design. Bob
PostPosted: Fri Jul 22, 2022 12:10 pm    Post subject: Reply with quote
Deleted. Accidentally posted before finished composing!
PostPosted: Fri Jul 22, 2022 12:13 pm    Post subject: Reply with quote
colbysmith wrote:
I've seen a few composting heads, and while interesting, and well liked by those that have them, I'm not sure I see the advantage. With a porta potty or marine head, you do either number, not worried about mixing the two. From what I understand of the composting toilets, you can't mix 1 and 2 together. Pee has to go in a separate hole, and you still have to dump that at some point, usually more often than the regular potti. 2 goes down the shoot and into it's composting bin. As for how long you can go before having to dump or pumpout with the regular potti's, one can extend that time by not flushing unless necessary, and just using some vinegar in a spray bottle to "spritz" the toilet after use. Then there is the expense... Composting toilets just seem to me like more trouble than they are worth, at least on a boat.
Got to seriously disagree, Colby! A composting toilet is the perfect solution for cruisers. We have had ours for 17 years now, and cannot conceive of using a standard marine head or PortaPotti for any significant cruising.
Initial cost was covered by the credit from C-Dory for deleting the conventional marine head on manufacture. As Patty posted, we only had to empty the solids container four times over eight months on our Great Loop. The composted solids were like garden soil, and were disposed of in ordinary garbage bags in dumpsters. BTW, there is no "flushing" of #2, the solids tank remains dry and is desiccated by the constant air flow over it. You simply turn a hand crank to mix recent deposits into the composting solids. In fact, the only time the composting toilet would NOT work properly is if the solids tank somehow should get wet.
The MAJOR advantage is not having to find a pump out (marine head) or shore toilet (PortaPotti, and I assume you do not dump yours overboard). Urine is diverted by the design to a separate tank and does not mix with the solids. Urine is not actually sterile, but "dilution is the solution" in deep water, and when that was not practical, I simply carried the liquids tank up to a toilet. The fan required is a simple 80 milliamp computer fan that could theoretically over a long time drain a battery but never has - our 200 watts of solar alone would power this fan many times over.
Your assignment is to write "NO PUMPOUTS" 100 times on the blackboard (or a piece of paper, your choice)!
Knipet
City/Region: Orcas Island
Vessel Name: Pan-A-C'ya
Photos: Pan-A-C'ya
PostPosted: Fri Jul 22, 2022 2:33 pm    Post subject: Reply with quote
Hey, possibly stupid question here, and tangently related to composting toilets:
Is it not cool to just piss overboard, of course provided you are discreet as to not get arrested for indecent exposure? It seems like every fishing boat I've ever been on that was always the way it was done.
So for you composting folks, no pouring the #1 (not the solids) into the ocean when out away from shore?
Steve & Joanie
2021 Venture 23 "Pan-A-C'ya
Formerly C-Sharp - 2006 22 Cruiser
PostPosted: Fri Jul 22, 2022 4:00 pm    Post subject: Reply with quote
Technically, it is not cool to dump untreated urine overboard. It is not sterile and can contain a lot of stuff (e.g. excess vitamins, hormones, ammonia, drug metabolites, etc.) that can be damaging to the marine environment. For instance, in the FL Keys there is a lot of damage to the reefs from ammonia in all the urine deposited in the water by tourist snorkelers.
On the other hand, if you dump your urine in already polluted rivers (e.g. western Lake Erie, Potomac River) it's not going to make a lot of difference.
PostPosted: Fri Jul 22, 2022 9:15 pm    Post subject: Reply with quote
Guilty on more than one occasion. However, a lot of fisherman have fallen over board while hanging on to themselves... I try to remind myself of that when I'm tempted. And I almost never tempt myself when solo on the Great Lakes or any large bodies or flowing waters.
I still like the idea of not straddling anything while using the head closet to shower in. I also know several that have used the solar vents. However, on more than one occasion my solar vent has failed to work... I don't know anyone with the composting toilet that has regretted putting it in. I'm just happy with my current set up. Colby
PostPosted: Fri Jul 22, 2022 9:24 pm    Post subject: Reply with quote
This could possibly make me a convert. The only question I have, is what size is the seat? There are only a few porta Pottis on the market for "adult butts". The rest seem to be made for children. The fact this might be easily removed out of the way for showering would be an advantage. I'm interested to see what kind of reviews this gets once they are available and in use. Colby
PostPosted: Fri Jul 22, 2022 11:29 pm    Post subject: Reply with quote
There are lots of things damaging coral reefs, and I would put "urine from snorkelers way down on that list.
As for the urine being infected-for healthy folks, the amount of bacteria in the urine is insignificant.
How much urine from marine mammals, Similar type of excretions from fish.
The literature seems to implicate sunscreens more than many other pollutants. But I have not been diving where there have been lots of snorkelers go--recently...
Rather than pee overboard, use a urinal--and then dispose of the urine how you think is best--in bottles to the nearest facility, or at sea where it would go naturally.
I'll admit I must have polluted a few rivers in my day....with urine.
Page 2 of 3
Page generation time: 0.0993s (PHP: 66% - SQL: 34%) - SQL queries: 28 - GZIP disabled - Debug on
