Cold Weather Boating
416rigby
Vessel Name: Foggy Dew
Photos: Foggy Dew
PostPosted: Tue Nov 08, 2005 2:14 am    Post subject: Reply with quote
We love that heater. There is no smell and the reason we bought it is because it says "For indoor use"...like tents, campers, etc. It warms up the boat easily and only set us back 80 bucks. You can get them at most any hardware store, I bet. Cabela's has 'em, too. Depending on how much you use it, and whether on low or high setting, a 1lb bottle of propane lasts 2 or 3 trips out fishing. We always have 2 or 3 extras in the boat at all times. It has an automatic shutoff if it tips over, as well as a low O2 sensor and will shut off if that is a problem. We love it.
hughpenk
City/Region: Waterford--Intersection of Hudson River/Chaimplain Canal and Mohawk River Erie Canal
State or Province: NY
Photos: CD 16 (hughpenk)
PostPosted: Tue Nov 08, 2005 1:52 pm    Post subject: Reply with quote
Fisherman, you said to tilt the motor down when you get home to drain the water out. What if the boat is left in the water and the air temp is less than 32? Do I leave the motor in the water and not tilt it up when I leave it over night? There are some winters here in upstate NY when the Hudson does not freeze since it is moving.
PostPosted: Tue Nov 08, 2005 5:53 pm    Post subject: Reply with quote
One thing I have found that is useful is a 12V electric blanket. The colder half (I mean better half AKA wife) will put it over her on while we are cruising/trolling and that really adds to her comfort level. In the evening, we use them to pre-heat the bedding in the v-berth prior to hitting the hay. They shut off automatically after 30/45 mins. Got our at Cabelas.
Roger on the SeaDNA
Chivita
City/Region: Hansville
Vessel Name: Chivita
Photos: Chivita
PostPosted: Tue Nov 08, 2005 6:02 pm    Post subject: Reply with quote
Hughpenk,
I just finished an in-depth 6 week Alaskan water training course that included one day of training with the local outboard mechanical genius. His statement on your motor question was for saltwater users, but he heavily recommended that the motor be left in the fully down position. According to him, very little marine growth occurs in the winter months in an cold area. He stated that if you keep you boat out of the water, you should also keep the motor in the fully down position or else water would be trapped around the hub area and will freeze, cracking the aluminum housing around the hub. Very expensive!
He also stated that if you happen to have left your motor in the up position during freezing temperature, that you should lower the motor down into the water (again, saltwater) and let it sit there for 15 minutes for it to thaw before starting the engine.
As a side note, he stated that the most frequent problem he has seen in his 30 plus years is outboards that have been dropped over the side and recovered. He said he knew one couple that did this nine times with the SAME motor and that he was able to recover the motor every time.
As to longevity, his recommendation will warm the hearts of Red Fox and Bill and El as well, - use the hell out of it!
Rabidfish
Dealer
City/Region: Noblesville, Indiana
State or Province: IN
Vessel Name: Les Poisson Enrage'
Photos: Rabidfish
PostPosted: Tue Nov 08, 2005 6:25 pm    Post subject: Reply with quote
I concurr with Chivita. The motor should be left down.
If it isn't left down, then it needs to be put down and not started until the ice that may be in the water pump can be thawed...
The best things in life come on a stick!
sally's sister
City/Region: chesapeake bay
State or Province: MD
Vessel Name: sallys sister
Photos: Sally's Sister
PostPosted: Tue Nov 08, 2005 6:40 pm    Post subject: condensation and cold weather Reply with quote
Just putting in a thought here.
We have been on Sally's Sister a few times when the outside temp at night has dropped to about 40. Most of the time we were plugged in, using a ceramic cube heater . We also have a small battery operation West Marine fan, two speeds...measures about 8 by 8 by 2. We prop it up in the hatchway between v berth and cabin and let it run on low all night. It seems to considerably reduce the condensation . The only wetness we tend to find in the am is all the way forward near the chain locker.
Redƒox
Guest
PostPosted: Wed Nov 09, 2005 8:44 pm    Post subject: Reply with quote
Chavita, great post Thumbs Up Last time I was out on my sisters boat there in Sitka, we had freezing spray! (brrrrrr) had the little Honda 2000 gen crankin, and runnin a small electric heater to keep MissLilys feet from freezing Crook (no this was not a nice enclosed C-D)
Bet this thread will rack up some innerestin replies Xmas Eek
Frozen Santa Xmas LOL
IE: .... make use of the old mountaineer's trick -- Hot water bottle in the cold sleeping bag Smile CoolSmile
Page generation time: 0.0497s (PHP: 33% - SQL: 67%) - SQL queries: 19 - GZIP disabled - Debug on
