Cockpit and deck paint
PostPosted: Tue Feb 06, 2018 12:23 pm    Post subject: Reply with quote
Ikea says it is "Solid acacia wood".
My people call it "Koa".
The KiwiGrip is a good alternative.
Dr Bob, the stuff has held up great! I am impressed, to say the least. Plus, it's water-based. My two brothers have used it on their boats (36' sailboat & 22' aluminum fishing boat) with the same positive results. Application was a snap and it can be touched up should it need to be.
PostPosted: Tue Feb 06, 2018 4:24 pm    Post subject: Reply with quote
Here is a piece of Koa I found on a beach someplace on Kauai. No laminate here, just one big piece of Koa.
PostPosted: Tue Feb 06, 2018 6:01 pm    Post subject: Reply with quote
Wow, a Koa dugout! What a find!
If I was to guess about the flooring, I would suspect not Hawaiian Koa--which is getting scarce. It is a beautiful wood, but can be hard to work...
Often "Australia Blackwood" is also called the poor man's Koa--and it is one of the same species as the Koa Acacia. (Many mass produced bowls, and figurines are from this.)
However, Locust, is a far more prevalent wood, and is called "False Acacia".
To even confuse it more--there area number of "asian Acacia's" There is a huge amount of "acacia" flooring made in China...and my guess is that is what this is.
It is like "Mahogany" There are only 3 which are true mahogany, one which is close enough that it is generally accepted, then outliers, who are of other Orders, and such as "Philippine Mahogany (Luan) has no characteristics of true mahogany....All of these have subgenus which give many different woods, which are at times called "Mahogany"...
PostPosted: Tue Feb 06, 2018 7:44 pm    Post subject: Reply with quote
My post was tongue in cheek. Hawai’ian Koa wood is extremely rare and expensive now. Dr Bob is correct, as usual. While it is a species of Acacia, I guarantee the ikea item is NOT Koa wood. That canoe is beautiful too, Harvey. I have my parent’s Koa wood living room furniture; hand built in 1952 by a local Japanese (Nesei) craftsman in Honolulu.
robhwa
City/Region: Anderson Island
Vessel Name: Marcia C
Photos: Problemadela
PostPosted: Tue Feb 06, 2018 11:21 pm    Post subject: "Acacia wood" as a description may be meaningless Reply with quote
There are over a thousand species of Acacia, some hard, some soft, some durable, some not, many utilized commercially, and varying in wood properties about as much as any tree. Saying "solid Acacia" is like saying "solid wood". What is really important is the specific Acacia species and its properties. For instance, Koa (Acacia koa) would be highly desirable, whereas Mangium (Acacia mangium) is a very fast growing species and would be less so. There are many species in between. A lot can be determined by looking at the wood before you buy it, but little can be determined by a simple description of "Acacia wood".
Rob Harrison & Marcia Ciol
Anderson Island, WA
2003 22 Cruiser "Mar-C"
PostPosted: Wed Feb 07, 2018 2:53 pm    Post subject: Reply with quote
I see Brazilian Koa/Acacia used in flooring. Beautiful, but I know nothing about it.
robhwa
PostPosted: Wed Feb 07, 2018 3:48 pm    Post subject: Exotic hardwoods for your boat Reply with quote
I work extensively in Brazil with the forest industry and universities. Brazilian Koa is neither Koa or Acacia. The botanical name is Astronium fraxinifolium (sometimes Astronium graveolens), commonly called"Gonçolo alves" or sometimes Tigerwood in Brazil. It was initially marketed as Tigerwood. When marketed as "Brazilian Koa" it sells better and for a higher price, because of Koa's reputation. This is kind of like calling Patagonian toothfish "Chilean Sea Bass" and shark meat cut into round pieces "Scallops".
However, this wood is generally a great product, very hard and rot resistant. However, it does vary in quality, hardness and price. It has "arrived" as a product, so it is not quite the bargain that it used to be when marketed initially as Tigerwood. Key is to get a look at the product before buying if you can.
PostPosted: Wed Feb 07, 2018 7:35 pm    Post subject: Reply with quote
Rob, Thank you for your expertise on woods. It is a pleasure to have someone aboard with your knowledge. Few things more beautiful than premier wood workmanship...on a boat....especially if some else maintains it!
san juanderer
City/Region: Stanwood
C-Dory Year: 1990
PostPosted: Thu Feb 08, 2018 12:00 am    Post subject: Deck Coating Reply with quote
I used a product called Tuff Coat, it was the smoother texture option . Ordered from Amazon with the epoxy primer. Used on the horizontal surface where the sunlight UV had caused the gel coat to craze. Been on a year so far, holding up very nicely. And the texture looks great. A water based product, applied with a special roller from the manufacturer.
Similar to a product called Kiwi Grip.
Cdory 22 Angler
SeaSport 24XL, Etec 250 hp (sold)
Rosborough RF246 (sold)
Commander 30 Sportfish (sold)
Olympic 26 XL (sold)
Glassply 19 (sold)
Olympic 23 (sold)
Bayliner 38 Motoryacht (sold)
Olympic 20 (sold)
Fiberform 16 (sold)
Olympic 18 (sold)
PostPosted: Thu Feb 08, 2018 2:41 pm    Post subject: Reply with quote
Ditto!
Page generation time: 0.0427s (PHP: 68% - SQL: 32%) - SQL queries: 23 - GZIP disabled - Debug on
