Hydrofoil really necessary?
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
PostPosted: Mon Aug 24, 2009 2:07 am    Post subject: Reply with quote
My engine is as high as it can go without redrilling the top bolt. I can't do that since it is about an 1.5 inches from the top of the transom. With the Permatrim installed any rpm above about 4200 and fuel consumption jumps quickly. Without the Permatrim, I hit steep portion of the fuel consumption curve at 4500 rpm.
Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981-
PostPosted: Mon Aug 24, 2009 11:37 am    Post subject: Reply with quote
At least in the Tom Cat, it makes little difference in top speed or fuel economy. In this boat it runs on the surface. In the C Dory, it was under water, so i suspect a little drag, BUT, it got the boat on plane faster and my feeling was the fuel economy was better--speed about the same.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Mon Aug 24, 2009 12:00 pm    Post subject: Permatrim - Fuel Consumption Reply with quote
Tom,
I don't believe that I am seeing any great jump in fuel consumption with my boat. We have a Honda 90 with carburetors. I typically run (light load, full of fuel) at around 4200-4400 rpm and 20-22 mph when water conditions permit. WOT is around 5400+ for me, and I was surprised to see it hit 31mph when I cleared the bar into Tillamook Bay a couple of weeks back. On that trip, we were offshore for about 6 hours, probably ran 8-9 miles each way in moderate chop, and trolled all day on the 90. My guess is that I burned between 6 and 7 gallons of fuel.
I'll let you know about loaded cruise (and altitude effect) after the Lake Powell trip.
Steve
20dauntless
Photos: Retriever
PostPosted: Mon Aug 24, 2009 12:47 pm    Post subject: Reply with quote
Steve, Tom and I (and others I'm sure) have the EFI Honda 90, also known as the BF90D. This engine has all sorts of Honda technology like VTEC, BLAST, and Lean Burn Control. My belief is that at some point (based on load and RPM) the computer changes the timing fuel map and requires more fuel.
That being said, this is an excellent engine. It's smooth, quiet, starts instantly, and has no problem pushing the C-Dory even when loaded very heavily.
BaseCampAnne
City/Region: San Diego/Anacortes
Vessel Name: SEA COASTER
Photos: SEA COASTER
PostPosted: Mon Aug 24, 2009 11:28 pm    Post subject: hydrofoil Reply with quote
Back to the original question...I got one of these on the advice of Don Anderson of the Jenny B. Thanks, Don!
I have learned that it is very strong and have heard in a Coast Guard Auxiliary class that it can be used in an emergency (when the engine is OFF) to help with getting someone out of the water, or at least somewhat higher when trying to recover someone from the back of the boat. I don't think Gus, my lab, will find it useful, but someone with very little upper body strength can stand on it and find it useful to be lifted up out of the water a bit....
Anne Cox (in the process of joining the retired and wondering how to pay for everything) Question Exclamation
tpbrady
Photos: Bidarka
PostPosted: Mon Aug 24, 2009 11:49 pm    Post subject: Reply with quote
If you look at many of the prop test reports on Honda's web site, you will see a steep increase in fuel consumption occurring between 3900 and 4400 rpm on the BF90D versus a linear fuel curve for the BF90A. I really think they need to work on software to smooth it out some.
PostPosted: Tue Aug 25, 2009 12:20 pm    Post subject: Reply with quote
Fuel consumption is related to HP output. If the fuel consumption is going up, so is the HP--often max HP is at top RPM. There can be all sorts of things going on--more injector pressure, different timing of injection and valves. I suspect that you are having more effecient use of the engine at mid to high RPM, then at max RPM the fuel consumption goes up.
Unfortunately outboard manufactuers don't often post RPM/Fuel/Torque and fuel consumption curves. Just prop test curves can be miss leading because of the dynamics, of the boat hull, prop interaction and drag factors as the speed increases. Boat speed and HP are not linlear functions.
Page generation time: 0.0407s (PHP: 62% - SQL: 38%) - SQL queries: 24 - GZIP disabled - Debug on
