Axle Ratios
Chester
City/Region: home
Photos: Chester
PostPosted: Sat Sep 03, 2016 3:20 am    Post subject: Reply with quote
colbysmith wrote:
... I have had the 302 (5.0L) in earlier Fords, and was pretty happy with it... Colby
Unless your earlier Fords were pretty new they didn't have the Coyote 5.0 which is much more advanced than the older Windsor 5.0s.
PostPosted: Sat Sep 03, 2016 10:58 am    Post subject: Reply with quote
Chester, we are definitely talking the older 302. A 74 Bronco and an 87 Bronco. lol I'm sure all the newer engines are a lot more advanced and efficient! Speaking of which, I wish Ford would bring the Bronco back! Colby
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Sun Sep 04, 2016 9:40 pm    Post subject: Reply with quote
I don't believe the 3:55 gears will impact your mileage any more than the 3:31 gear will impact towing. There is only about 7-8% difference in these gear sets. I have a 2015 F150 crew 4x4 with 3.73 gears and it still gets 20-23 mpg on the highway with the 5.0. I just got back from a long trip with the boat in tow and it got 13 mpg (again) at 60-70 mph. Honestly, the 5.0 has way more than enough power, gets good mileage, and seems like it makes way more power than the 387 hp it is rated at. I love mine so far.
PostPosted: Sun Sep 04, 2016 10:47 pm    Post subject: Reply with quote
I've been killing a lot of time on the Ford Forum reading all the posts on the F150 drive train combinations. I've also looked at the 2016 Ford Tow ratings and all things considered, see that at least with the 3.5 eco boost or 5.0l, they provide quite a bit more leeway than my Highlander. However, the truck I am looking at has the 5.0, and the numbers don't give the 6 cyl ecoboost any better mileage. (Probably because of a lower geared rearend.)
As an example, my 2010 Highlander with it's 6 cyl and tow package has these specs:
HP 270 @ 6200 rpm
Torque 248 @ 4700 rpm
Compared to the F150 Super Crew cab, 5.5 box and 145" WB (4x4)
HP 385@ 5750 rpm
Torque 387 @ 3850 rpm.
Highlander curb weight 4321, GVWR 6000, Payload 1679
F150 curb weight 4850 GVWR 7000, Payload 2072 GCWR 14,300
Highlander tow limit 5,000
F150 Tow limit 8,900
Highlander axle 3.48 F150 3.31.
As I've stated before, I've been quite impressed with the Highlander's actual capability towing over the Rockies. But with the comparisons above, I have to believe that the 2016 F150 SuperCrew I'm looking at, would tow just as well, if not much better. The mileage is probably the disadvantage. In the Highlander, not towing, I average 19 in town and 23 hwy. Towing has been anywhere from 7 (very strong headwinds) to 14 (flat with some tail wind) with a no wind average of 12-13. Towing in the Rockies was around 9. Towing speeds are 55-61, normal hwy of about 70. The Ford Excursion I owned previously, with the V10 only got about 9 towing, and 15-17 Hwy. I'd be quite happy if a newer F150 could get me 20-22 Hwy, and no worse than the Highlander towing.
Back to the forum stuff, seems like a lot of guys are recommending the 3.55 or 3.73 axles for towing. I also see from Ford Specs that the 3.5 turbo boost with the 3.55 axle increases the tow rating to 11,500 and GCWR to 16,900. However the payload is only 1570, if I read the numbers right. Either way, seems like all the specs point to the 5.0l with the 3.31 axle (and the 6 speed electronic trans) should be plenty of truck to tow with. Colby
T.R. Bauer
PostPosted: Sun Sep 04, 2016 10:58 pm    Post subject: Reply with quote
The aluminum F150 with the 5.0 will easily get 20-23 mpg on the highway. With 331 you might even get more as I have 373 gears. I doubt you'll see a huge difference, but maybe a 5% increase.
Discovery
City/Region: LOA, UTAH
Vessel Name: Discovery
Photos: Discovery
PostPosted: Tue Sep 06, 2016 12:17 am    Post subject: Reply with quote
When I bought the F350 in 2012 there were two axle ratios and two tire/rim sizes. The higher number axle ratio came with 18" rims and the lower number ratio came with 20" rims. The effective ratio turned out to be the same for both combinations.
Steve, I'll have to look at the display and get back to you.
I'm in the process of putting a 2015 5.0 Coyote engine in a '51 Ford F1 Panel truck I'm restoring. Paired with a 4R75E transmission and a '72 Ford 9" 3.5 rear end and 16" rims. I hope I can get over 20 MPG.
Brent and Dixie,
1984 22' Classic sold 2003
2003 24' TomCat sold 2005
2006 CD 22' Angler Sold 2014
PostPosted: Tue Sep 06, 2016 1:48 pm    Post subject: Reply with quote
Well, in time I'll let you all know. I went for it. 2016 F150 Super Crew cab 4x4 with the 5.5 box (145"wb) 5.0L, 3.31 gearing. Fleet rental trade in with 20,000 mi. No tow package, but I'll put a hitch and wire in a 7-pin plug with electric brake controller. Kept the Highlander and traded in the wife's CRV. So we have a spare tow vehicle if needed. Very Happy Colby
PostPosted: Mon Mar 30, 2020 3:01 pm    Post subject: Reply with quote
Thought I'd resurrect this thread with the outcome. A few days ago I traded in that 2016 F150 for a 2019 F150, with pretty much the same set up. 5.0L V8 with 3.31 gearing. The newer one with a 10 speed tranny as opposed to the 6 speed in the 2016. Also came with the Tow package.
The 2016 worked flawlessly towing the 5100 lb CD-22 over the Midwest, Rockies and other mountains out west. Running without trailer, at 80 mph out west, I was getting around 19.5 mpg. Back at 70 and slower, I could get 22.x mpg. Towing, depending upon the wind and mountain range, anywhere from 9-13.4 mpg. Average flat land no wind seemed to come in around 12.3. Pulling the boat up the Rockies with the 2016, there were times the tranny would shift all the way down to 2nd gear, while running 65. Because it was sitting just under red line, I would let up on the peddle and slow to 60. It'll be interesting to see where the 10 speed in the 2019 downshifts to. The F150 felt very solid pulling the CD-22. I did install a standard Tekonsa Electric Brake Controller, which also worked well with my tandem axle electric brakes. With the new truck, I elected to go with Ford's Electric Brake Controller. Hope it works as well. The new truck also has the Electric Locking rearend, something my 2016 didn't have, and a factory backup camera. I added a backup camera to my 2016, but don't think the aftermarkets are ever as good as the original factory installed units. I expect the electric locking rearend will help on slippery ramps or starting up on icy roadways. (As the non locking rearend on the 2016 basically became 1-wheel drive on anything slippery, unless I locked in 4WD.) Colby
PostPosted: Mon Mar 30, 2020 6:05 pm    Post subject: Reply with quote
I'm not sure I'd really need the oil cooler or larger radiator that also comes as part of the tow pkg. I kind of suspect that is more for pulling closer to max load in warmer climates.
I never heard a truck owner say "I have too much cooling capacity."...!!! That is the cheapest upgrade you can buy. Price out a new transmission!
PostPosted: Mon Mar 30, 2020 9:21 pm    Post subject: Reply with quote
I agree, but that was on the 2016, which ended up working out fine. I'm pretty sure the 2019 comes with all that since it has the "tow package" included. Then again, one never knows without crawling under and looking. Smile Colby
PostPosted: Mon Mar 30, 2020 9:43 pm    Post subject: Reply with quote
For the first time Marie spun the tires of a vehicle pulling a C Dory out of the water when we hauled out at St John's River this year. I suspect the Yukon had much more weight in the rear than the Ford 250.(even with the locking rear axle) She popped it in 4x and pulled right on out. The boat was not all of the way up on the trailer, so the tongue weight was not "available" when pulling out. This is not the first case of a pickup being light and spinning rear wheels I have seen. Marie could see the truck sliding back down into the river--I reassured her that the thrust of the outboard would prevent that, if it started to slide....!!
(we use the EarTec 2 way communication system--a real wife saver!!
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Mon Mar 30, 2020 11:19 pm    Post subject: Ford Reply with quote
Colby we have the 2018Expedition with the Ecoboost V-6 and a3.31 rear end We pull our CC23venture about 5500lb no problem at all Coming back from Hontoon we got almost 16mpg using the tow mode
With your 2019 truck look into the Timbren Srs rear helper bumper stops that will help with your new cd-25 Good luck with that also Take care Jim
BTW my friend has a truck camper on a F150 he replaced the air bags and put the Timbrens on He said night and day difference
PostPosted: Tue Mar 31, 2020 12:54 pm    Post subject: Reply with quote
with your 2019 truck look into the Timbren Srs rear helper bumper stops
Hey Jim,
Had them on my 2016, and pulled them back off putting the original axle stops back on, before trading it in. Several of the nuts seized off the bottom mount U bolts, but Timbren said they'd send me new bottom mounts as soon as they are back to work. Great customer service there! Once I get those new bottom mounts, I'll install the set on my new 2019. (Or I may get bored waiting, cut the old U bolts off the bottom mounts, buy some new U bolts, and re-weld them up. And Yes, they work great!
Page generation time: 0.0725s (PHP: 73% - SQL: 27%) - SQL queries: 26 - GZIP disabled - Debug on
