Honda 135 HP engine shutdown-intermittent
marcagrin
City/Region: Sarasota
Vessel Name: Joseph Conrad
PostPosted: Thu Jan 21, 2016 8:38 am    Post subject: Reply with quote
I did check out the thermostat sensors and replaced one that appeared corroded after the initial shut down. Unfortunately, the engine shut downs continued.
Since arriving home and thoroughly checking out the situation per above, I have had no additional episodes. Ran the engines hard and erratically for several hours last weekend and the starboard ran perfectly.
Time will tell!
Marc G
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Thu Jan 21, 2016 9:15 am    Post subject: Reply with quote
Ok thanks for the update.
Do you have a Honda shop manual? What is the SOP to check the sensors?
First check continuity ? Then place in water at different temps and check resistance?
I am surprised it didn't throw a code.
Brent Barrett
BrentB
Photos: BrentB
PostPosted: Thu Jan 21, 2016 9:34 am    Post subject: Reply with quote
Maybe purchase an IR thermometer to check engine block temps
Page generation time: 0.0266s (PHP: 58% - SQL: 42%) - SQL queries: 16 - GZIP disabled - Debug on
