USB Charging on Board
PostPosted: Sun Nov 29, 2015 1:32 pm    Post subject: Reply with quote
There has been a lot of information on The Hull Truth about the small battery atterpack Lithium ion batteries, and one of the respected members sells one.
Yes, they will act as any booster pack and start an outboards. They don't have a huge amount of residual life. Any lithium ion battery pack will slowly self discharge, but certainly for more than a month, enough to start our batteries. (This is not specific to the units found at Costco).
There are any number of battery packs for recharging both USB devices and computers. I have owned a battery pack which will recharge my MacBook Air 3 times, for a number of years. I have several smaller packs which will double the life of the I phone.
PostPosted: Sun Nov 29, 2015 1:46 pm    Post subject: Reply with quote
Pandion wrote:
hardee wrote:
I just found one of these at Costco:
Lithium Jump Starter and Portable Power Bank
Harvey, any idea how long that thing will hold a charge? And has anyone actually used one of these to start a boat engine?
I have not used it to start anything (except ion this thread) but I got interested in it when the motorcycle shop used it to start my bike after they let it sit with the lights on and ran the battery down. It started it right up. That was the 3rd time they had used it for a bike that week without recharging it. They had also used it to start a customers car. The owner said he had used it to start his Ford F-150 before, (not on that same charge though).
It is lithium ion so should hold a charge for a pretty good time, but I don't know how long for sure.
I liked it because of the size and weight and various output possibilities, and that it can be charged on either 110AC or 12VDC from my cig plug on the boat or truck.
SleepyCMoon
williwaw
City/Region: Portland
Vessel Name: Williwaw
Photos: Williwaw
PostPosted: Sun Nov 29, 2015 2:14 pm    Post subject: Reply with quote
I believe USB charger output is 5 volts with a quality charger outputting 2.1/2.4 amps or 10-12 watts. If you look at the 120 VAC charger that comes with the iPad, for example, it's only provides 12 watts. This is not high power stuff so, while possible, poor charging is unlikely to be a voltage drop issue.
More likely the problem is just that the device running navigation software with the display set to max brightness is using too much power. With my iPad running Navionics, the best I can do is maintain the charge over time and I know my wiring is good Smile
Btw, an easy way to add another 12 VDC socket to your dashboard area is to get an extension cord (like this) and hard wire it to fuse panel behind your helm. I just left the socket loose because it's rubber coated and behind my MFD so it don't notice it. Took me ten minutes to install and now I have a dedicated socket for my iPad.
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Sun Nov 29, 2015 2:20 pm    Post subject: Reply with quote
Harvey- you just solved my Christmas gift for my son. Thanks, now could you please get Santa to find a 14 footer for me? Xmas Eek
MartyP
PostPosted: Sun Nov 29, 2015 2:24 pm    Post subject: Reply with quote
I haven't tried mine on the boat yet, but I have an Anti-Gravity XP-1 and it will start my V-10 "land engine" without any noticeable strain (I disconnected the battery cable and used just the Anti-Gravity to start it since my battery wasn't actually run down.) I have to think it's easier to start a boat engine since my boat starting battery is much smaller, although I'm no expert on the topic.
It seems to hold a charge quite well in storage, although I haven't kept meticulous records or anything, so no facts and figures on that.
The XP-1 also has a cigarette socket you can use with it (so I could charge my laptop, for example), plus the usual USB, etc. ports. That said, I keep it just for possible jump starting (has the typical jumper cable type alligator clips) so I don't use it for other purposes much.
Page generation time: 0.0348s (PHP: 62% - SQL: 38%) - SQL queries: 18 - GZIP disabled - Debug on
