Honda BF90A Stalling Problem..help me diagnose
PostPosted: Mon Aug 10, 2015 10:29 am    Post subject: Reply with quote
On a previous boat I had a Yamaha engine that had carbs. If the primer bulb was pumped up hard the engine would be flooded. Just took 2-3 squeezes before starting when cold. Never had a hard bulb and the engine ran fine.
I've never actually checked the bulb on my BF90D. Engine starts every time, and I never have to mess with it.
Kushtaka
City/Region: Cordova
Photos: Kushtaka
PostPosted: Mon Aug 10, 2015 2:14 pm    Post subject: Reply with quote
I have a similar motor, 2 years newer, with the opposite problem: I lose power at higher rpm, and it runs fine at lower RPM. I have two fuel filters with bulbs downstream from each. I need to regularly pump the first bulb to fill the second fuel filter. My honda tech says it's commonly a bad bulb in this situation and is replacing it, as well as all fuel filters. His list of possibilities were: bad bulb, old filter, clogged high speed jets, but a bad bulb is by far the most common culprit.
If it turns out to be something else I'll post here (still in the shop), but I suppose I'll never know if it was a bad bulb or old filters, as they will all be replaced at once. If it's the high speed jets I'll know, because the new bulb and filters won't work.
Blueback
City/Region: Qualicum Beach, Vancouver Island
C-Dory Year: 1990
Vessel Name: Blueback
Photos: Blueback
PostPosted: Mon Aug 10, 2015 3:20 pm    Post subject: Re: Fuel pumps changed...problem solved! Reply with quote
busski wrote:
Hi all,
Thanks so much for the assistance. It ultimately was the fuel pumps. Am very thankful that those are accessible right on the outside of the engine, with all but one bolt very easy to remove.
Purrs like a kitten now on the jump from Orcas to Friday Harbor!
Why in this thread are people referring to fuel pumps? One engine --one pump.
What I'm I missing here? BTW I just replaced my fuel pump as there was a small leak around the pump flange. After replacement I pulled the old pump outer flange cover off and as there was no gasket, or O ring to seal the flange cover I became convinced that its the diaphragm outer edge that creates the seal. Therefore, if there is a leak it a tell-tail indication the its the diaphragm that failing.
I'm in the third stage of life:
1-Learn to catch fish.
2-Catch fish -hopefully-
3-Work at rebuilding the endangered runs of salmonids on the West Coast
Avidmagnum12
City/Region: Ocklawaha
C-Dory Year: 2011
Vessel Name: C-Otter
Photos: C-Otter
PostPosted: Mon Aug 10, 2015 8:01 pm    Post subject: Reply with quote
The carburetor version of the Honda 90 has 2 fuel pumps. Don't ask me why.
Tom and Joyce Schulke
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Mon Aug 10, 2015 8:59 pm    Post subject: Re: Fuel pumps changed...problem solved! Reply with quote
busski wrote:
Hi all,
Thanks for sharing. I would not have suspected the fuel pump(s).
busski
City/Region: Crane Island
Vessel Name: Lucky linda
PostPosted: Tue Aug 11, 2015 12:35 am    Post subject: Fuel pumps Reply with quote
It definitely is odd that there are two fuel pumps on the BF90a carbureted engine.
As for the high rpm issues, I recently started to have the issues at high RPMs as well. Suspected it might be a bad bulb, and replaced, but no help with the problem.
I would go step by step from cheap to expensive (bulbs, tank senders, fuel filter, fuel pumps) but what you are describing sounds exactly like the problem I had which was only solved (and immediately) when the fuel pumps were replaced.
Oh, and my pumps did have a gasket to make a seal with the flange. They didn't include them with the replacements so had to reuse. Was easy to miss as quite small and look "mounted" on the originals.
Blueback
C-Dory Year: 1990
Photos: Blueback
PostPosted: Tue Aug 11, 2015 1:15 pm    Post subject: Re: Fuel pumps Reply with quote
I stand corrected and amazed-- 2 fuel pumps--hmmm? That sounds like double trouble when they pack it in and double the cost. My BF50-A fuel pump does not have an outer flange gasket - its the edge of the diaphragm itself the appears to double as a gasket.
Still scratching my head -- what in hell was the design engineering thinking when they placed 2 fuel pumps in that model motor. However, I will guess and say if they run off separate cams obviously they would pump double the amount of fuel- but why - who needs it.
waterworld
City/Region: Orillia
State or Province: ON
Vessel Name: Tillicum
Photos: Tillicum
PostPosted: Tue Sep 15, 2015 3:24 pm    Post subject: Reply with quote
Hi guys...real newbie here.
My Honda 2001 75HP (4 stroke) stalls at idle and occasionally when accelerating over 2000rpm
The season here (Ontario, Canada) only has about 1 month to go.
I am planning on changing all sparkplugs and maybe carbs rebuild / cleaned in the off season.
In the meantime, I will try seafoam is the gas tank.
I am hoping to learn how to maintain the outboard as much as I can.
Does my logic make sense?
PS: Btw, does anyone have the Service Manual (PDF) for that beast? I have the Owners Manual, but it does not cover much from the servicing side. Wouldnt mind knowing where the idle screw is, etc...
Thanks!
Steph
busski
PostPosted: Thu Sep 17, 2015 9:28 am    Post subject: Diagnosing a hesitation stalling Reply with quote
I would suggest a carb tune as one of the last steps in diagnosing an issue with the BF90A. There can be lots of reasons for stalling issues with this engine. The first and most common are fuel delivery issues. The last would be carb issues, and fixing those can be expensive as there are four, and they need to be synced after adjusting which requires a proprietary tool.
I would start with:
1) gas (is it new or gummy water infused ethanol blend?)
2) fuel lines from tanks to engine fully sealed at junction points?
3) sending unit from gas tank working properly?
4) primer bulb working properly?
5) In line water separator need replacing?
6) fuel filter in bottom starboard side of engine clogged/old/have water in it?
7) fuel pumps working as intended?
Cool has the "BF90A Fuel bog" been addressed:
http://www.boats.com/reviews/boats/outboard-expert-honda-bf90-bog-cure/
9) spark plugs gapped and clean?
10) carbs cleaned with sea foam?
11) carbs adjusted and synced?
waterworld
Photos: Tillicum
PostPosted: Thu Sep 17, 2015 9:43 am    Post subject: Re: Diagnosing a hesitation stalling Reply with quote
busski wrote:
I would start with:
Oh oh...is Ethanol not ok? Next tank I will try the premium gas see if that makes a difference.
Thanks!
busski
PostPosted: Thu Sep 17, 2015 10:11 am    Post subject: Reply with quote
Ethanol can be a big problem for marine engines:
http://www.alloutdoor.com/2013/06/25/fishermen-beware-ethanol-fuel-deadly-outboard-motors/
And buying premium fuel won't help the problem, as it still contains ethanol, it just also contains higher octane gas and additives to help clean engines. You need to seek out ethanol free gas stations, which are often marine locations:
http://pure-gas.org/
Finally, always use a fuel stablizer if you're going to use the engine infrequently or keep gas for more than a month or two. I use:
http://www.goldeagle.com/product/sta-bil-fuel-stabilizer
waterworld
Photos: Tillicum
PostPosted: Thu Sep 17, 2015 10:24 am    Post subject: Reply with quote
Awesome, the previous owner had told me gas with ethanol was ok.
My boat does not sit around long, a couple of days at the max.
Thanks for the enlightenment !
waterworld
Photos: Tillicum
PostPosted: Thu Sep 17, 2015 10:36 am    Post subject: Reply with quote
Page generation time: 0.058s (PHP: 68% - SQL: 32%) - SQL queries: 26 - GZIP disabled - Debug on
