Washdown Pump
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Sun Aug 07, 2005 3:30 am    Post subject: Reply with quote
I have my wash down pump (a Shurflo Blaster) installed on the port side of my transom. The intake hose is routed from the pump across the motor well and down the outside of the transom to the bottom of the boat. The hose is secured to the transom with nylon hose holders and SS screws. My switch has been a giant PITA in that the saltwater eats them up like candy. I have resorted, temporarily, to spade connectors when the pump is needed.
I certainly appreciate the tip about keeping the inlet of the pump below the high point of the hose loop. That may solve my intermittent water problem.
The Shurflo pumps are improved over the older ones that seized up in salt water after a week or two.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Mr. Fisherman
Vessel Name: Sea Lion
Photos: Sea Lion
PostPosted: Sun Aug 07, 2005 4:37 am    Post subject: Reply with quote
Myself I'd settle for slim anything... well except wallet. I don't think that COULD get any thinner Laughing
Live to Fish
Fish to Live
Forty Two
City/Region: Prince William Sound
C-Dory Year: 2017
Vessel Name: Black Cat
Photos: Barrel O Monkeys
PostPosted: Sun Aug 07, 2005 2:33 pm    Post subject: Reply with quote
I hung a Shur-flow washdown pump beneath my home made downrigger mount - 3rd photo in the Barrel-o-Monkeys album. Waterproof switch mounted beneath the rigger mount, dunk a short section of garden hose with a brass strainer over the transom when I want to use the pump. No thru-hulls. On a boat, eventually, everything will fail.
John & Susan
Mr. Fisherman
Photos: Sea Lion
PostPosted: Fri Aug 12, 2005 3:47 am    Post subject: Reply with quote
Thanks for the replies so far.
Have you had any problems with the pump being in these locations?
I was thinking about putting it in the splash well or maybe under one of the gunnels. Not sure where to put the pump just yet. It showed up today so I can take it out to the boat and tinker with it.
Thanks for the tips on orientation Tyboo and for confirming that the pickup tube will work so I can avoid the through hull fitting. You guys are alright Thumbs Up
Page generation time: 0.037s (PHP: 62% - SQL: 38%) - SQL queries: 17 - GZIP disabled - Debug on
