How to calculate load on bow eye (to size new one)?
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Thu May 15, 2014 12:35 am    Post subject: Reply with quote
The weakest link in your system is its maximum rating no matter which one of the suckers you put in.
PostPosted: Thu May 15, 2014 1:39 am    Post subject: Reply with quote
I'm not sure I understand what you are saying. I do get that ground tackle is a system, and that a system is generally no stronger than its weakest link. But I'm not sure that's what you mean (?)
If that is what you mean though, then the reason I posed the question is that I wasn't sure that the forces on a bow eye would be "equivalent" to, say, the shackle, which is otherwise my weakest link by quite a bit (because I have 1/4" high test chain, but it is not possible to get high test shackles to fit it). So in other words, say the shackle is rated at 1500# working load and 2000# breaking load (I'm making those figures up for the sake of discussion, although I have the real ones elsewhere for reference). Then does that mean the bow eye need only be rated that high to be "equivalent"? OR are the forces on the bow eye different so that in order to be "not weaker" it needs a higher WLL/BLL? In my lay-person's mind, it just seems like forces on the fixed bow eye might be greater than forces on the "fluidly placed" shackle (that is between the chain and the rope, and generallly gets a relatively straight-line pull). And what about trailering? These questions are why I posted.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Thu May 15, 2014 10:10 am    Post subject: Reply with quote
Having a better part is ok but proper installation is important too.. It seems to me that one limitation is the hull thickness in area. Is it re inforced with fiberglass mat or just buildup of extra epoxy ? With a strong pull, the eye could pull out like a tooth.
Brent Barrett
PostPosted: Thu May 15, 2014 10:30 am    Post subject: Reply with quote
This is the type of rig which is used for towing 25 foot boats at up to 25 knots across open water and the Gulf Stream. In these boats, the hull interior is re-enforced with layup of several layers epoxy/cloth, such as 1708 /then mating SS plates on the inside of the hull. The strength is probably limited by the shear load of the 5/16" Bolts--The shear strength of each of these bolts is at least 3,500 lbs. (total over 40,000 lbs) The weldment would be more than a 1/2" SS U bolt. The load is spread out over a substantially greater area.
So if the U bolt, and its specs is not enough--you can always go to this more substantial fitting.
BrentB
Photos: BrentB
PostPosted: Thu May 15, 2014 10:41 am    Post subject: Reply with quote
cool
thanks
Do we need twins? Wink
PostPosted: Thu May 15, 2014 1:33 pm    Post subject: Reply with quote
I will definitely be reinforcing the bow in this area. In fact, this is one (more) reason for a new bow eye - longer legs to be able to go through some backing. Not sure exactly how I'm going to do it yet, but there are numerous ways that can work well, and I will figure that out once I'm "in there."
At one time I was involved in a project to install a bow towing/anchor eye on a largish power boat (ironic, given this thread Very Happy). It was interesting following the loads along (because as you say, it's no good anchoring a strong piece to a weak substructure) and visualizing how to make it happen. A naval architect/engineer was involved, but we also had to figure out how this could work in the real world (installation access and procedure, etc.). In the end it turned out to be a combination of a tang (picture a chainplate, only parallel to the long axis of the boat), which carried most of the load to a reinforced bulkhead, and a plate much like shown above only larger (for looks, to have something to bed, and to carry some of the load to the skin).
Of course our small boats have smaller forces, but still everything has to "match up."
Back to the backing: I'll have to see how it looks once I'm in there again, but I'll probably do some combination of a few layers of biaxial cloth in the area, plus a fitted/epoxied backing block. Included will be making a flat/parallel surface on the after side for the washers/nuts to land on.
BrentB
Photos: BrentB
PostPosted: Thu May 15, 2014 11:19 pm    Post subject: Reply with quote
thanks
very informative
Page generation time: 0.0339s (PHP: 61% - SQL: 39%) - SQL queries: 24 - GZIP disabled - Debug on
