Winterize fresh water system
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Mon Nov 25, 2013 6:19 pm    Post subject: Reply with quote
rogerbum wrote:
Another downside to the alcohol antifreeze is that alcohol is flammable and burns with a nearly colorless flame.
From Wikipedia - An ethanol-water solution that contains 40% ABV (alcohol by volume) will catch fire if heated to about 26 °C (79 °F) and if an ignition source is applied to it. This is called its flash point. The flash point of pure ethanol is 16.60 °C (61.88 °F), less than average room temperature.
So, once things warm back up sparks from any source (like a pump that wasn't designed to pump flammable liquids or the wallace stove), could set the water/ethanol solution on fire.
Thanks Roger, that's a pretty significant downside I hadn't thought of. Preventing a funky flavor in the tank is not worth risking setting your boat on fire! My tank already tastes so terrible the red antifreeze would be an improvement I think.
Page generation time: 0.03s (PHP: 59% - SQL: 41%) - SQL queries: 14 - GZIP disabled - Debug on
