Storage compartment install in the Gunnel on a 19' ???
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Tue Mar 01, 2016 1:35 am    Post subject: Reply with quote
Hey Greg, I'll take that storage compartment. See you up in Friday Harbor in about 2 months, ok?
Patrick
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
Saxcrazy
City/Region: Kingston
C-Dory Model: 19 Angler
Vessel Name: Dreamboat Annie
Photos: Sassy
PostPosted: Tue Mar 01, 2016 1:58 pm    Post subject: Storage Compartment Reply with quote
Do you have a picture of your storage compartment and maybe some dimensions? How much are you looking to get for it? Thanks, Mike
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Tue Mar 01, 2016 3:08 pm    Post subject: Reply with quote
And it looks like Patrick takes the storage insert. I will have it up at FH for you.
The dimensions are shown here if you need that info. I simply don't need it so its yours.
http://ssicustomplastics.com/products/index.php?route=product/product&path=59_63&product_id=165
Greg
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Fri Mar 18, 2016 9:54 pm    Post subject: Reply with quote
I'm debating whether or not to do this mod. It would be nice to have some extra storage in the cockpit. What is behind the board? Is it just foam? What do I have to do to ensure a good, watertight seal after cutting and installing the insert?
<><><> Jason <><><>
Aurelia
Photos: Aurelia
PostPosted: Fri Mar 18, 2016 11:25 pm    Post subject: Reply with quote
If you used the same insert as we have. I think you could simply put a bead of sealant around the edge after mounting and call that pretty good. some sealant squeezed into each of the screw holes would be good too. There is a thin layer of fiberglass then just foam behind that. If you want any measurements or depths, I have a big hole in ours that is easy to access.
Cutting the hole and clearing the foam would be the hardest part of this job.
Greg
Wood Zeppelin
C-Dory Year: 1997
Vessel Name: C-Creature
Photos: Childhood Dream
PostPosted: Mon Aug 22, 2016 12:28 pm    Post subject: storage insert for aft bulkhead (?) 16' Angler (1988) Reply with quote
My '88 Angler does not have one of those rear storage slots in the Aft Bulkhead (terminology - not sure what to call it?). Not really the transom but on the inside of the boat just ahead of the transom and motor. I noticed in the pictures on here that a 1990 16' Angler has this storage slot. But my '88 doesn't. I really want one. Any tips!? Where to get an insert?
Thanks!
Current boats:
1988 16' Angler - "E-fishn-C"
Also:
Aurelia
Photos: Aurelia
PostPosted: Mon Aug 22, 2016 1:40 pm    Post subject: Reply with quote
Here is one source and I am sure there are other options.
Greg
Page generation time: 0.0278s (PHP: 62% - SQL: 38%) - SQL queries: 20 - GZIP disabled - Debug on
