Joined: 02 Nov 2003 Posts: 21505 City/Region: Pensacola
Posted: Sun Mar 31, 2013 1:45 pm Post subject: |
You should be able to go to Home Depot or Lowes and look in the stock metal department. There will be aluminum which is about this size and thickness-you can bend it, or cut to shape. Then pop rivet in place. (I would use AL or SS/monel pop rivets. Drill out the old rivets.
Diamond Sea Glaze made the windows--and probably made those "guards"--they would be able to give you replacements--or the modern version. If you want plastic--then go to a plastic shop, and show them what you want--they can form it if you don't want to--but a heat gun and a few minutes you can make one out of plastic. _________________ Bob Austin
Bill K
State or Province: OH
Vessel Name: NIC'L PIC'L
Photos: NIC'L PIC'L
Posted: Sun Mar 31, 2013 4:38 pm Post subject: |
I just went back out to take another picture, ( I can not get the "add picture" line to do anything. )
I touched the guard and found out they are made out of something soft like rubber but formed like Sunbeam said. They look like his.
I have the same type of guards on my Bertram and I think they came with the boat.
Sea Wolf wrote: | Please note my On Edit comment above"
"***On Edit: The photo shows a guard made out of something other than aluminum/aluminum alloy or stainless. Note corrosion. Betcha they were not made or installed by Diamond Sea Glaze, or any other window manufacturer. They would not have used an easily corrodible metal. (Looks to be ferrous). Ditto on the pop rivets. Probably a home-made addition by a previous owner! Any clues about them?" |
_________________ KA8BFT |
Joined: 23 Oct 2003 Posts: 5329 City/Region: Warrenton
Posted: Sun Mar 31, 2013 4:44 pm Post subject: |
Bill K wrote: | I can not get the "add picture" line to do anything. |
Sounds like you might have a popup blocker preventing the add picture box from opening. _________________ TyBoo Mike
Sold: 1987 22' Cruiser |
Bill K
Photos: NIC'L PIC'L
Posted: Sun Mar 31, 2013 4:45 pm Post subject: |
Mine look just like yours but are gray and made out of rubber or something soft.
Thanks for the explanation on the photos, but right now I am having problems with the add photo button not doing anything.
Sunbeam wrote: | Just as a note, if you make your own or decide to buy (different) ones: I just looked out at my window guards (white windows), and, while they are the same basic size, there is a "bulged" section in the middle. It's kind of like there is a clamshell built into the center section (closed end on top, open end on bottom). Maybe that helps to prevent the corrosion where it is on yours, because the water/gunk doesn't "press" on the guard there. Seems like it might be a worthwhile improvement (?)
I'll come back with a photo.
Edited to add: Okay, sorry these are blurry, but if I went to re-take them I think I'd run past the editing time limit. They should give the idea anyway.
Here is how I get a photo from my album to a post:
1) I open up my album in another tab or window (just seems easier).
2) Get to the photo I want, and click on it once or twice to make it as large as possible.
3) Right click on enlarged photo and...
a) Mac = select "Copy Image Address"
b) Windows = I think select "Properties" and then within that there is something referring to copying the URL or address, select that.
4) Come back to the posting window on the thread you want the image in and paste what you copied in step three into it.
5) Highlight the address from step 4 and go up above the posting window and click on "Img."
6) Watch for the final Img tag getting separated from main string - you may have to manually delete to get them rejoined (I do).
7) Preview post. If photo comes out right, you are good to go; if it does not, it won't and you need to check on the tags (most likely they are the problem) (you can also manually type the tags in once you see what they are).
Voilá!
Sunbeam |
Bill K
Photos: NIC'L PIC'L
Posted: Sun Mar 31, 2013 4:48 pm Post subject: |
How did I get the first one in ? LOL
I will try to change that, Thank's
TyBoo wrote: | Bill K wrote: | I can not get the "add picture" line to do anything. |
Sounds like you might have a popup blocker preventing the add picture box from opening. |
Bill K
Photos: NIC'L PIC'L
Posted: Sun Mar 31, 2013 4:50 pm Post subject: |
I will send an email to Diamond Sea Glaze and see what they say. |
Bill K
Photos: NIC'L PIC'L
Posted: Sun Mar 31, 2013 6:41 pm Post subject: |
I am gaining, LOL I got two more pictures of the guards in my album.
One is the best one so it doesn't look so angry.
Will see if this works.
guess not
TyBoo |
Posted: Mon Apr 01, 2013 1:11 am Post subject: |
Bill K wrote: | One is the best one so it doesn't look so angry. |
Bill K
Photos: NIC'L PIC'L
Posted: Mon Apr 01, 2013 1:25 am Post subject: |
Sunbeam,
When I read this I really did laugh out loud !!! Thanks for the laugh.
Sunbeam wrote: | Bill K wrote: | One is the best one so it doesn't look so angry. |
Posted: Mon Apr 01, 2013 2:04 am Post subject: |
Very funny!!
Does anyone know if these smiling little fellows that cover the drain holes actually perform a useful function? (I speculated on the insect barrier theory earlier).
Are they mostly cosmetic?
What are the risks if yours are missing, in poor repair, or need a facelift?
What is their average life expectancy?
How come we've never (to my knowledge) discussed them before in the 15 years I've been a member of the various C-Dory clans?
Is it better to have singles or twins?
Etc., etc.
Bill K
Photos: NIC'L PIC'L
Posted: Mon Apr 01, 2013 7:49 am Post subject: |
A test picture.
Posted: Mon Apr 01, 2013 8:02 am Post subject: |
Those appear to be simple pop rivets, aluminum in all likelihood. You can buy sheet aluminum at most hardware stores, in various thicknesses and aluminum rivets too! Why not make your own?
K4KBA |
Bill K
Photos: NIC'L PIC'L
Posted: Mon Apr 01, 2013 8:06 am Post subject: |
Because I could not make the offset bends to make the overhang.
Captains Cat wrote: | Those appear to be simple pop rivets, aluminum in all likelihood. You can buy sheet aluminum at most hardware stores, in various thicknesses and aluminum rivets too! Why not make your own?
Charlie |
Posted: Mon Apr 01, 2013 8:31 am Post subject: |
You know, if they're not necessary, the boat might look better without them (?)
Of course, you do have two holes that would still have to be filled in with pop rivets or some other filler.
Will be interesting to hear what Diamond Sea Glaze has to say. However, if it's been too many years, the original thinking may be unclear in the memories of employees that didn't work back in that era.(!)
Joe.  |
Chris
Vessel Name: Rana Verde
