Radar Interpretation
PostPosted: Mon Dec 31, 2012 2:01 pm    Post subject: Reply with quote
colobear wrote:
...official rules in the collision regs. require you, if you have radar, to have the it on when underway.
Although I think radar is a wonderful tool, and there is nothing at all wrong with having it on, say, a clear, sunny day with 10-mile visibility, it is not required indiscriminately, as I understand the regulations.
Here is an excerpt:
RULE 5 Look-out
Every vessel shall at all times maintain a proper look-out by sight and hearing as well as by all available means appropriate in the prevailing circumstances and conditions so as to make a full appraisal of the situation and of the risk of collision.
Emboldening is mine.
The way I was taught this rule is that the section I emboldened does apply. That is, if you have radar and the prevailing circumstances and conditions mean that it's something you should have on, then yes, it is part of keeping a proper lookout, and keeping a proper lookout is required. Thus in that circumstance the radar would be required.
However, in the example I used above, of a clear, sunny day with 10-mile visibility, then, the way I learned it, radar would not be required in order to keep a proper lookout. Thus it would not be required.
Not that there is anything wrong with using it to practice (in fact, I think it's a good thing), nor is there anything wrong with having it on just because you feel like it. And certainly if conditions are marginal, the rules infer that one should err on the side of "proper lookout" (i.e. use the radar).
Sunbeam Hot
PostPosted: Mon Dec 31, 2012 3:34 pm    Post subject: Reply with quote
The only way I've found for learning to use the radar is to use it when you don't need it. Saying that, operating the radar (at least the ones I've used,) isn't easy so keep the manual handy.
Also, let me stress after you've learned to use it by comparing visual scenes with what's on the radar, keep using it for practice. I relearned this in So Cal fog a couple of months ago, when I nearly pronged a boat because I hadn't adjusted the radar for the prevailing conditions: smooth water and going at 12 knts. Luck beats skill, again. So learning and keeping in practice are two complementary skills, practice being more important in the long run.
Also, on the manual's cover, I make my own index of what I think important.
Radar is wonderful, but it's a skill that needs to be learned and maintained.
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Mon Dec 31, 2012 3:41 pm    Post subject: Reply with quote
Your quote is from, I think, Navigation Rules Part B Steering and Sailing Rules, Section 1-Conduct of Vessels in any Condition of Visibility, Rule 5 Look-out.
If you go a little further to rule 7 Risk of Collision, (b) you see: "Proper use shall be made of radar equipment if fitted and operational, including long range scanning to obtain early warning of risk of collision and radar plotting or equivalent systematic observation of detected objects."
The Colregs 1972 edition which is afik the latest; says:
"5. Look-out
Every vessel must at all times maintain a proper look-out by sight (day shape or lights by eyes or visual aids) and hearing (sound signal or Marine VHF radio) as well as by all available means (My bold) (e.g., Radar, Automatic Radar Plotting Aid (ARPA), Automatic Identification System (AIS), GMDSS...) in order to make a full assessment of the situation and risk of collision."
I'm not interested in getting into a contest here but as far as I know if you have a collision and your vessel is equipped with a working radar; and if you were not "standing a radar watch" you are automatically in violation of rule 5 above and at least partially liable/at fault.
Patti and Barry
formerly C-Cakes, now
rving around N. America
PostPosted: Mon Dec 31, 2012 3:50 pm    Post subject: Reply with quote
A little pricer at about $140 (you may find it used) is Starpath Radar trainer for the computer. It is highly recommended.
Agree that using it is the best way to learn on clear days.
You should be able to pick up Kayaks with that radar. You will pickup rain squalls and approaching weather fronts.
I recommend tuning the radar manually, not using the auto magic mode. Look at Gain, Sea Clutter rain clutter etc. Learn what ghost images look like--and what is "real".
Never travel faster than you can stop in time to avoid a collision. I don't run that fast in fog, or at night (unless very clear and on other boats around) It just makes traveling at 6 knots safer--not allowing you to trail at 25 knots.
You may need a heading sensor for overlay. I personally prefer it on its own screen.
The AIS is easy, be sure you have the right com port, and baud rate set. Then go to the menu. I have really enjoyed the Garmin AIS thru the Standard Horizon radio. Picks up all of the targets. Some times it seems like too many! But that is all safety. This is also one of the reasons we run two GPS platters. One is only GpS--no sounder, no AIS, no radar etc.
PostPosted: Mon Dec 31, 2012 4:36 pm    Post subject: Reply with quote
Me neither.
colobear wrote:
...but as far as I know if you have a collision and your vessel is equipped with a working radar; and if you were not "standing a radar watch" you are automatically in violation of rule 5 above and at least partially liable/at fault.
My understanding is that one is not required to "stand a radar watch" in times of good visibility (it is optional of course). One IS required to keep a proper lookout. But, I'm comfortable with "agreeing to disagree."
One nice thing about a powerboat is that you do have the ability to run the radar anytime you are underway, with no real "penalty." So it's an easy choice.
When sailing, for example, it's not always possible. Amp hours are precious, and fuel and other means of recharging are limited. That doesn't mean that one doesn't keep a proper lookout, including running the radar when it is prudent. But if under sail for long periods of time one doesn't typically run the radar constantly during periods of clear weather and good visibility, but rather keeps an eyeball/binoculars/etc. lookout. I don't believe this is contrary to the rules, but I see this is where we differ. I'm fine with that as anyone who reads this thread can do research for themselves.
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Mon Dec 31, 2012 6:59 pm    Post subject: Reply with quote
I've always interpreted the content of the Navigational Rules COMDTINST M16672.2SD the same as colobear.
Aside from how an individual may interpret the rules, I consider the following:
Even when in times of uninhibited visibility from weather, the design of our C-Dorys alone does not provide with a clear 360 degrees visibility without contorting yourself from the helm to look out past the stern when on plane. (Of course, if you have others on board, you can position a stern lookout). Having a radar on and easily seen at the helm, provides a 360 degree watch that gives you a bit of an edge in collision avoidance.
The radar is just one more tool that if it is installed, functional and used may become the one entity that prevents a collision.
It all boils down to using all means possible to increase your situational awareness.
Sunbeam, I can certainly appreciate your observation of a sailboat's inability to keep the batteries charged while under sail. (At least you have a plausible argument if you were questioned).
These are great discussions for us to explore.
Dave S.
"Sea Shift"
C-Brat #16
Bill K
City/Region: Toledo
State or Province: OH
Vessel Name: NIC'L PIC'L
Photos: NIC'L PIC'L
PostPosted: Thu Jan 03, 2013 5:59 pm    Post subject: Reply with quote
Somebody said that Dusty had made a radar tutorial, here is the link to it.
http://www.c-brats.com/viewforum.php?f=22
Bill Kelleher
Levity
City/Region: Shippensburg
Vessel Name: Levity
Photos: Levity
PostPosted: Thu Jan 03, 2013 7:39 pm    Post subject: Reply with quote
Levity runs a Garmin 18HD with a Garmin 4210 plotter/display. I, too, prefer using the split screen mode and learning to interpret in clear weather. It is surprising how many small, fast moving boats have little or at times, no radar reflection. Radar does afford rear vision even when you are facing forward. Radar is great when your eyes aren't.
Mike-Levity
Page generation time: 0.0353s (PHP: 65% - SQL: 35%) - SQL queries: 21 - GZIP disabled - Debug on
