Lifting an 85# Kayak to the rooftop (Ideas needed)
Morning Star
City/Region: Roseville
Vessel Name: Morning Star
PostPosted: Sun Apr 07, 2013 5:51 am    Post subject: Reply with quote
Casey & Mary,
The Garhauer lift installation looks great! How tall is the vertical support bar and how long is the horizontal lift arm? Which Garhauer part number did you use? Is it easy to setup, remove, and stow when underway? Where do you stow it on board between uses? I like it!
PostPosted: Sun Apr 07, 2013 9:09 am    Post subject: Reply with quote
Looks good, Casey & Mary! Thumbs Up Being able to keep the pedals and seats in while underway is a great solution for time AND space. Have a great summer - we'll be looking forward to the updates!
http://captnjim.blogspot.com/
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Sun Apr 07, 2013 11:05 am    Post subject: Garhauer comments and details.... Reply with quote
We should be able to leave the lift in place with the hook connected to the kayak straps (but loosened so it's not carrying a load). If leaving it in place doesn't work we can easily remove it and secure the main pole to the roof, collapse the boom, and store it 'somewhere. (We would prefer to leave it in place since dismounting while on the water would risk dropping something overboard.)
The lift (model LD 6-1 w/34" arm) can be seen at: http://garhauermarine.com/catalog_process.cfm?cid=41
The assembly consists of four parts. (1) the boom which hinges and fits into the upper pole, (2) the support ring which provides stability for the main pole, (3) the main pole (which we had made taller at 57" ... normally 27") to accommodate the higher lift necessary for the kayak to clear the cabin roof, and (4) the lower ball mount. The ball mount can either be screwed in place or through bolted (a backing plate is provided).
For highway speeds we will transport the kayak atop the truck then lift it to the boat at the launch ramp.
While at Lake Powell (SEP 2012) we found that the kayak rack on the boat worked fine - but getting the kayak up/down was NOT 'fun. As a result, we mostly towed at displacement speed. Now (hopefully) we'll be able to EASILY launch or retrieve the kayak in a matter of minutes, and cruise at either displacement or planing speeds.
Best,
Casey&Mary
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Sun Apr 07, 2013 11:46 am    Post subject: kayak Reply with quote
Casey it looks good Great job . Are you guys doing the Northwest again this summer or doing East Coast (Erie canal etc) Take care Jim
Casey
Photos: Dessert 1st
PostPosted: Sun Apr 07, 2013 12:14 pm    Post subject: Reply with quote
Jim,
We are currently in AZ and will head for Prince Rupert around the first of May, and plan to be in SE Alaska for Jun/Jul/Aug.
Best,
Casey&Mary
RobMcClain
City/Region: Summerlin, NV
State or Province: NV
Vessel Name: Freedom
Photos: Freedom
PostPosted: Sun Apr 07, 2013 12:17 pm    Post subject: Reply with quote
Beautiful job Casey & Mary. Gives the boat even more of that wonderfully rugged mini-trawler look. Should be great to have in Alaska! As time and technology allows, I hope you're planning on writing a cruising blog describing your upcoming trip. I definitely looking forward to reading it!
Rob
ghone
City/Region: Nanaimo
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
PostPosted: Sun Apr 07, 2013 5:13 pm    Post subject: Reply with quote
Looks great Casey! That should solve the heavy lifting. You guys enjoy your r and r in Hawaii. Then load up and hit the road. See you up north. George and Carolyn
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Sun Apr 07, 2013 8:45 pm    Post subject: Reply with quote
Casey & Mary,
Very well done! If the Mokai didn't tow so well, I'd be copying your project.
I'm sure envious of your three month Alaska plans this summer. We must wait for next year, but sure wished we could make it this year with the possibility of some shared experiences up there.
El and Bill
City/Region: Lakewood, CO
Vessel Name: Halcyon
Photos: Halcyon
PostPosted: Mon Apr 08, 2013 11:22 am    Post subject: Reply with quote
Good no. Casey. Hope to see you guys before you head north up the Passage.
Page generation time: 0.0333s (PHP: 63% - SQL: 37%) - SQL queries: 26 - GZIP disabled - Debug on
