Furuno 1623 Radar
PostPosted: Wed May 25, 2005 1:34 pm    Post subject: Reply with quote
C-Sick-
I've been reading around on the color issue since you've raised the issue, and the best answer to the color (TFT), CRT, or LCD question as far as I can tell is this-
If you want an integrated system, the color allows the system to differentiate among the radar, chartplotter, and even aerial images when overlaying, some systems even allowing you to vary the intensity of the images to suit your needs. Simply put, color is necessary when viewing multiple overlaid images.
For a stand alone radar:
1. The CRT units are best when viewed in dimly lit conditions, e.g., in the cabin or at night.
2. The LCD units work well except in shaded conditions where they lack contrast.
3. The Color TFT displays work well under all lighting conditions, including full sunlight, but carry a hefty price increase.
One key to successful use of any system would seem to be the legibility of the system under the conditions you anticipate to encounter. Where and when do you expect to need your radar?
Then again, one doesn't always anticipate every use to which necessity will force you to use your radar, or, for that matter, any other piece of vital equipment on your boat. Under what conditions would the color display be worth the additional cost?
Joe.
C-Sick
City/Region: Renton
C-Dory Model: R-25 Tug
Vessel Name: Gratitude
Photos: C-Sick
PostPosted: Wed May 25, 2005 10:35 pm    Post subject: Heavy Rain & Fog Reply with quote
Thanks for your research. In the Northwest the two conditions that I have encountered that require utter attention to what is going on is heavy rain and fog.
The good news of LCD for C-Dory is we do have the cabin and usually the lighting conditions are overcast.
Color is so much cooler but in my current situation it would be a real hunk of change.
C-Sick
In A Bad Way
Page generation time: 0.0247s (PHP: 57% - SQL: 43%) - SQL queries: 15 - GZIP disabled - Debug on
